Question about Sewing Machines
Elna club 500. Sewing in reverse only
Have tried to sew forwards again, any suggestions please
  • 323 Answers
SOURCE: Elna 2002 Sewing Machine
Can't get a manual for you but here's how to wind a bobbin.
Guide your thread from the spool holder to the bobbin thread tension device on the top left side of the machine.(That's the round assembly that is about 1/2 inch in diameter with a screw in the center of it.) Pull the thread in the front and wrap it to the back and continue towards the bobbin winder on the right side top. Wrap thread around the bobbin, place the bobbin on the spindle sticking up. Release the handwheel(either by pulling out on the center of the wheel or twisting on the center of the wheel). Press on the foot control. It should stop winding when it is full.
To thread the machine
all machines thread the same. TTN tension, take up, needle.
Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way. Flat side to the back and it threads front to back
Sewman7
Posted on Jun 19, 2008
SOURCE: Elna sewing machine, the timing is out.
Hi, Purchased an elna contessa 130. could anyone advise threading procedures , as we do not have a manual with it.......problem with top tension.
Many thanks
Maureen
maureen.reinberger@gmail.com
Posted on Aug 02, 2008
  • 14 Answers
SOURCE: ELNA 7000 SEWING MACHINE
If you bend over the front of the machine, you will see a slider switch on the back of the machine, and there is a small "button" at the bottom right of the switch (your right). If you push this button down, you can slide the slider switch to your right and the feed dogs will go up.
Posted on Mar 26, 2009
Sewtech1
  • 69 Answers
SOURCE: elna su motor won't turn off
it is only your Capasitor that is faulty and can be by passed
Posted on May 01, 2009
  • 6 Answers
SOURCE: Manual for Elna Contessa 310
www.janomestuff.com
Posted on Sep 18, 2009
Elna Club 500 sewing machine manual
Try Googling (Elna)(500)(manual) without parens.
May 08, 2017 | Elna Sewing Machines
My Elna club 500 is not stitching properly. What can I do?
We need specifics of what the symptoms are. There are a lot of issues that will cause a sewing machine to not stitch properly.
Feb 20, 2017 | Elna Sewing Machines
Which is the stretch stitch on my elna club 500
Here's a copy of your owner's manual:
ELNA 500 ELECTRONIC Manual Page 16
Although it does not show a "stretch" stitch per se, there are several that can work. Machines without any stretch stitch can simply use a zig-zag.
Jun 10, 2016 | Elna Sewing Machines
Elna dealers my elna super is stuck in reverse. Nearest repair shop is 200 mi. They recently servised it. can a person with better than average mech skills fix it ?
I just had the same problem.
I had a look around inside the machine, without taking off too many covers. By taking off the bottom panel I was able to look up inside and see what the 'reverse' lever was doing . The lever appeared to be moving another part inside the machine, except it wasn't returning to its original position (so it was stuck in 'reverse'). I used a long stick to push it back, and sprayed some WD40 onto it and after that the lever was able to move the part back and forth, and hey presto the machine works forward and reverse again.
Hope this helps if anyone else has this problem
Jun 09, 2011 | Elna 2007 Mechanical Sewing Machine
I have an elna 1010. It seems to be stuck in reverse, and I can't get it to go forwards. Can you help me?
try spraying some wd-40 or silicon spray on the reverse button or lever & let it set for awhile & try to work it
Nov 23, 2010 | Elna 1010
Bobbin Elna 500?
I found listings for two different Elna 500 sewing machines.
You can download or view the information that pertains to your model - http://safemanuals.com/reference-ELNA/1
The site will give you the security code to enter for the download.
Apr 08, 2010 | Elna 2007 Mechanical Sewing Machine
Sewing Machines Logo
32 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
