Question about Mission Grill Co Island 5 Burner Gas Grill
The grill lights do not turn on. Manual states to connect power plug to properly ground the outlet. Cannot find this outlet.
I have a Ducane 30400042 that I want to convert from LP to NG. Maybe we can work up a parts trade. Email me at tomcollins1228@yahoo.com
Posted on Jul 10, 2013
Grill will not light
I assume the grill is configured for natural gas (propane generally requires a different pilot orifice unless the owner's manual states otherwise; they are not interchangeable). The following is written as a generic explanation; see your owner's manual for a diagram of the internal gas piping. If you need further assistance, please ask in the comment box. If you do not have a sediment trap in the gas piping, the pilot tubes may be clogged with white sediment similar to the lime from tap water. In this case, you will not be able to smell any gas at the pilot outlet. The clog is usually right at one or both ends of the tube, inside the fitting. It is important to get both ends properly tightened after repairs. The end connected to the supply obviously needs to be tight for safety, and the flame end needs to be tight to maintain proper pressure for the flame. Test with soapy water; there should be no bubbling when it is applied to the connection.
Jun 27, 2014 | KitchenAid KBNU367VSS Gas Grill
Blows cold air
From Traeger:
"Why won't my Grill Ignite?
  1. If your grill is plugged into an electrical outlet with a GFI (ground fault interrupter) plug, chances are the hot rod has absorbed or been exposed to too much moisture and is leaking to ground causing the plug to trip.
  2. Open your cooking chamber lid, remove cooking grill, angled drip pan and U-shaped firepot cover. Is there ash build up in the firepot and/or around the firepot? If so, this needs to be cleaned out. The ash is choking out the fire.
  3. Check the fuse on the back of the control board. To do this, first UNPLUG the grill from the electrical outlet. Then, unscrew the control board and look at the fuse-is it blown or not?
  4. If the fuse is good, check for power by switching the colored plugs first. Unplug the purple plug and the orange plug. Plug the purple plug into the orange plug. Now plug the power cord back into the electrical outlet and turn the grill on. Does the induction fan operate? If so, you will need a new hot rod and fuse. If not, you will need a new control board. Unplug the purple from the orange and reconnect the plugs together to their correct color plug.
  5. Always start your grill on the SMOKE setting.
Feb 14, 2014 | Traeger Industries Grilling
Won't light
From Traeger:
Jan 22, 2014 | Traeger Industries Grilling
Traeger trip gfi
Could be the hot rod igniter has accumulated too much moisture.
From Traeger:
Feb 03, 2013 | Traeger Industries BBQ075 All-in-One Grill...
Traeger tripping gfi
Check this out: may be your hot rod has absorbed too much moisture
From Traeger:
The heating element will not heat up.
From Traeger:
Jun 26, 2011 | Traeger Industries BBQ070 All-in-One Grill...
The power will not turn on? The green light on the back is flashing, but nothing will trun on. how do i get it back on?
Thank you for posting to Fixya.com and it is my pleasure to guide you.
I have located the manual, click or copy paste to download the manual for future reference.
Getting Started Guide 9.11M http://h10032.www1.hp.com/ctg/Manual/c00230513.pdf
From the manual : Power - Troubleshooting page 101
QUOTE
Symptom: PC will not turn on or start.
Problem: PC is not securely connecte
Solution: Ensure that cables connecting the PC to the external power source are plugged in properly.
Problem: Green power supply light on back of PC is out.
Solution: When the cables connecting the PC to the external power source are plugged in properly and the wall outlet is functioning, the green power supply light should be on; if the light is not on, refer to the Warranty and Support Guide to contact Support.
Problem: Monitor is not connected or is not on.
Solution: Connect the monitor to the PC, plug it in, and turn it on.
Problem: Line voltage selection switch is not in the proper position for your country/region (115V/230V).
Solution: Set the line voltage selection switch to the correct setting for your country/region, or refer to the Warranty and Support Guide to contact Support.
Problem: Wall outlet is defective.
Solution: Test the outlet by connecting a different electrical device to the outlet.
Problem: Wrong memory modules were used in an upgrade, or memory modules were installed in the wrong location.
Solution: Reinstall the old memory to return your PC to its original state. Refer to the Upgrading and Servicing Guide for instructions.
Problem: Hard disk drive is damaged.
Solution: Press the Help ? button on the keyboard to open the Help and Support Center, or refer to the Warranty and Support Guide to contact Support for replacement details.
Problem: After an upgrade or repair, the drive power, data, or power supply cables may not be properly connected.
Solution: Reseat drive power, data, and power supply cables. See the Upgrading and Servicing Guide for instructions.
UNQUOTE
Good luck and please post back that you are successful and give thumbs up if my solution has worked for you. If I can be more helpful just reply.
Jun 21, 2011 | HP Pavilion a749c PC Desktop
Grill wont fire up
From Traeger:
Jun 13, 2011 | Traeger Industries BBQ100 All-in-One Grill...
My traeger smoker will not ignite
From Traeger:
May 06, 2011 | Traeger Industries Grilling
I plugged in my new grill and it does not power up. The only thing that works on the grill is the rotisserie. Can you help?
Presumably you have the grill connected to your 120v house power via an extension cord to the electrical box attached on the outside rear of the grill.
And that is where your rotisserie is plugged in, into one of the two available outlets at that same electrical box.
The other outlet is meant for the hood light, which connects via a pigtail from the little transformer inside rear of the grille. (If that connection is made and the light still does not work, check the bulb for burnout.)
Does the ignitor work? You probably already know this from reading the manual, but there is an AA battery which powers the ignitor--not the 120v system. Unscrew the cap on the ignitor button and ensure a new alkaline AA battery is installed correctly, put - (negative) side of battery in first.
Hope this helps!
Apr 04, 2010 | Fiesta Blue Ember Gas Grill
Mission Grill Co Island 5 Burner Gas Grill Logo
165 people viewed this question
Top Mission Grill Co Grilling Experts
paulcarew
Dan Webster
Dan Webster
Are you a Mission Grill Co Grilling Expert? Answer questions, earn points and help others
