Record from one cassette tape to another
I have no manual or remote control. can i still record from one cassette tape to another without the remote
    Problem Solver:
  • 31 Answers
Yes
Posted on Dec 04, 2013
robotek
  • 1512 Answers
SOURCE: Remote control for Technics RS TR 272 Dual Cassette Deck
a system remote is the only option for you here. The deck does not have its own remote receiver. Sorry to break the bad news to you.
Posted on Jan 26, 2008
  • 121 Answers
SOURCE: audio tape cassettes,old pre-recorded and home
A good cleaning to the rollers and tape head with a qtip and a small amount of rubbing alcohol should do the trick
Posted on Feb 26, 2009
farr64
  • 121 Answers
SOURCE: cannot get dual cassette deck to record, denon DRW-660
check the drive belts inside the unit could be broken or slipping. farr64
Posted on Apr 29, 2009
SOURCE: Static in the middle of a recording.
I had the same problem, but the reason for it seemed to be that the USB cable from the cassette deck wasn't plugged directly into my computer, but via a hub. When I plugged the cable directly into my computer (PC, using Windows XP), the problem disappeared, or seems to have disappeared so far.
Posted on May 23, 2009
djtatty
  • 417 Answers
SOURCE: Need to find user manual.
for a start your title says "Problem with the Technics RS-TR272 Single Cassette Deck"
So is it a single or double?
i'm assuming it's a double,right only one of the decks records so put the blank tape into it make sure the tabs on the top of the tape haven't been broke or you'll need to cover the holes with the labels you get with the tape.
put the tape with the music on it, in the other deck rewind them both then press "sync rec" & they should both set off.
Posted on Mar 01, 2011
Phillips Pocket Memo 381 The button you press in when recording will not press in! Any ideas tThe machine plays back tapes OK
You cannot push it in without a recordable tape in the unit. The mini cassette tapes have a removable erase prevention tab on each side in the front. If removed, you cannot push record. Try another tape. Otherwise the recorder needs repair.
Aug 16, 2011 | Philips Pocket Memo 381 Handheld Cassette...
Need the manuel original lost or misplaced and can not find. want to record cassettes to cd's
Insert a blank CD-R or CD-RW into the unit. Press the Function button on the remote (key above Vol+ on the bottom right of the remote) or the turntable itself (top left of the control panel) until the unit is in Phono mode. Then insert the pre-recorded cassette and press Play to advance the tape to where you wish to start recording. With the cassette playing, press the CD Record button (recording will flash on the display). The CD Record button is to the left of the fast reverse button on the unit; it is labeled Record on the remote and is below the Stop button. When one side of the cassette finishes playing, press Stop. Wait for the display to return to Phono. Then eject and turn over the cassette to play side 2 (if you want to record both sides of the tape). Press Play again to advance the tape and then press Record. When this side finishes, press Stop and then Finalize. Finalize is at the bottom left of the remote buttons and to the left of the stand by indicator on the turntable.
The manual is available at Crosley: http://www.crosleyradio.com/Product.aspx?pid=1790 . The direct link to the manual is http://www.crosleyradio.com/Manuals/CR248_Manual.pdf . Recording a cassette to CD is on page 11 (page 12 of the pdf).
I hope this helps.
Jun 10, 2011 | Crosley CR248 Turntable
My neighbor is having trouble setting his VCR to record when he is not home. He said the VCR comes on, but does not record. He does not have the original remote control. Is there some place I can...
I hope you are not making the simple mistake of trying to record on a cassette which has a broken write protect tab. If you are, tape it up with some cellophane tape. Or try a new cassette.
Is the instant record function working otherwise ?. If so forget about the record protect tab.
Apr 29, 2011 | RCA VR692HF VHS VCR
How do you record onto a tape from a CD?
I couldn't find the exact manual but the XL-HP505 may be close enough...
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Sharp-XL-HP505-manual/id/285dj790/t/2/
Apr 27, 2011 | Sharp XL-HP500 CD Shelf System
I can't find the manual to my Technics RS-TR272 Stereo Cassette Deck. How do you tape something on one cassette to another?
Place the tape you want to record into the left deck, Then the blank tape into the right deck. Press play on the left deck and record on the right deck.
It may be opposite depending on which side your recording deck is on.
Which ever deck has record, place blank cassette into that one and the cassette you want to copy into the other deck.
Hope this helps and please rate thanks
Mar 13, 2011 | Technics RS-TR272 Single Cassette Deck
Cannot get dual cassette deck to record, denon DRW-660
Apr 29, 2009 | Audio Players & Recorders
Zenith xbv713 won't record on vhs tape
is the tab on the cassette in place? if it has been removed the cassette will eject automatically when pressing the record button.
Jan 05, 2009 | Zenith XBV713
Permanent standby
The machine is in a "fault mode", as you have figured, but it's much more likely that a motor has not completed it's cycle upon power-up. It's also possible that the load carriage is out-of-time, and will need to be set according to manual specs...accordianman
Dec 14, 2008 | Televison & Video
Jan 09, 2008 | Technics RS-TR272 Single Cassette Deck
Sony SLV-D350P DVD/Video cassette Player
I have the manual. Are you trying to record something live? if so:
1) Turn on both the DVD/VCR and your TV.
2) Switch the input selector on your TV so that the signal from the player appears on the TV screen (this is usually something like 'input 1' or 'line 1' and so forth)
3) On your remote, set TV/DVD-VIDEO to DVD-Video, then press SELECT VIDEO to control the VCR. These buttons are at the upper left hand corner of the remote controller.
4) To record from a cable box, turn it on.
5) make sure the tape is longer than the total recording time.
6) insert a tape into the VCR.
7) press CH +/- on the remote to select the channel or line input video source to record.
8) select the tape speed SP/EP (SP provides better quality, EP provides three times the recording time as SP)
9) Press the record button to start recording. The VCR display will display the message REC.
Nov 25, 2007 | Sony SLV-D350P DVD Player/VCR
 Grubhead
Grubhead
