Question about Chaintech SK8T800 Motherboard
Front panel connectors cn1a - Chaintech SK8T800 Motherboard
    Brigadier General:
  • Chaintech Master
  • 3,400 Answers
Emachine W3653 motherboard manual
Intel 945GCT-M3 motherboard,
http://support.gateway.com/s/MOTHERBD/Shared/4006188R/4006188Rmv.shtml
Above shows main view, and is labeled.
http://support.gateway.com/s/MOTHERBD/Shared/4006188R/4006188Rnv.shtml
Click on Product Views for Pinouts and connectors for;
1) 4-pin ATX +12 Volt power cable; B - Processor Core Power Connector
2) Processor fan cable connector on motherboard; D - CPU Fan Connector
3) 24-pin ATX main power cable; F - ATX Power Connector
4) Floppy Drive 34-pin connector on motherboard; G - Floppy Disk Drive Connector
5) CD/DVD drive that is IDE (PATA) type -> connector;
H - Parallel ATA IDE Connector. (Harddrive goes to SATA connector)
6) Computer case fan connector; I - System Fan Connector
7) Audio connector on motherboard for CD/DVD drive's small audio cable, (Main drive if there are two)
M - AUX-IN Connector
8) Front Panel is front of computer.
N - Front Panel Audio Connector is where the front panel audio ports connect.
9) R - USB 2.0 Connectors = Front Panel USB connectors on motherboard
10) Front of computer is the Front Panel. Area of contact pins on the motherboard, that the main wires from the Front Panel go to, is the Front Panel header.
T - Front Panel Connector = Front Panel header
Motherboard manual from ECS Support,
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=719&CategoryID=1&MenuID=16&LanID=0
(Note photo is distorted. Click on - More pictures for clearer view.
{More pictures / Where to buy / Print )
Click on the Download tab.
(Features / Specification / Download / Support / CPU / etc)
Click on Manual.
(Driver / BIOS / Manual)
Scroll down, click on the country NAME nearest yours.
A PDF file motherboard manual will come up.
For additional questions please post in a Comment.
Regards,
joecoolvette
Nov 16, 2012 | Computers & Internet
Front panel connection to mother board Power switch pin
Hi careyfraser,
1. There are 8 wires from the front panel's casing, excluding USB connectors and front audio cable.
2. Just plug the front panel switch headers to the F_Panel main board connectors. 1 & 2 are positive, if the led do not light change polarity but Im sure it will.
Note:The mainboard provides a front panel connector for electrical connection to the front panel switches and LEDs. JFP1 is compliant with Intel® Front Panel I/O Connectivity Design Guide.
Hopefully this information helps.
Thank you for using FixYa.
Sep 23, 2011 | Asrock G31M-S Motherboard
Plugigng of wire in board
Hello there,
Below is an image of *********** Board with number indication and wiring explanation. From your manual page 1-6 you can see the image below and 1-7 for the connector, jumpers, slots. as indicated in your problem I will only answer problems related to the wirings.
  • For the Front Panel
  • For the USB connectors
1. If your casing has a USB header on the front bezel you can put it on any connector. You can also purchase a USB module cable or an internal card reader and plug the headers to any of those connectors.
Note: Observe Polarity, do this Vcc, -Data, +Data, Gnd ,(NC) ground is always near to NC.
Plug it at your own risk, reference image are already shown.
  • Front Panel Audio connectors
1. Look for FP_Audio header from your casing and plug it to the connector.
*Asus recommend you connect a high definition front panel audio module to this connector to avail of the motherboard's high-definition audio capability.
Aug 19, 2011 | ASUS P5KPL-AM SE Motherboard
Were does the LH mirror on a 2011 f-250 connect. Removed mirror but disconnect is located some were in door or body. need to know what needs to be removed to gain access
  1. Remove the front door trim panel.
  1. Position aside the front door watershield to gain access to the exterior rear view mirror control switch electrical connector.
4.Disconnect the exterior rear view mirror control switch electrical connector
as you see you have to remove the door panel to have access to the electrical connector in case that you dont know how to do it here are the instructions
NOTE: Left front door trim panel shown, right front door trim panel similar.
  1. Remove the sail panel.
    • If equipped, disconnect the electrical connector
  2. If equipped, lift up and remove the exterior rear view mirror control switch panel.
    • Disconnect the electrical connector.
  1. If equipped, lift up and remove the window control switch panel.
  1. If equipped, remove the window regulator handle.
    1. Position the window regulator handle cover aside.
    1. Remove the window regulator handle screw and regulator handle
5.Remove the door trim panel center screw cover
6.Remove the 2 door trim panel center screws
7.Remove the 2 door trim panel lower screws
  1. NOTICE: Do not pull directly outward on front door trim panel as damage will occur.
    • Lift upward to remove the front door trim panel.
  1. NOTICE: Insert the lower panel tabs first or they can break when installing the front door trim panel.
    To install, reverse the removal procedure
Feb 20, 2011 | 2011 Ford F-250 Super Duty
How i can replace the gearshift?
SECTION 501-12: Instrument Panel and Console 2003 Expedition/Navigator Workshop Manual
REMOVAL AND INSTALLATION Floor Console -Front, Navigator Removal and Installation
  1. Apply the parking brake.
  1. Position the front seat forward.
  1. Remove the two front floor console rear bolts.
  1. Position the front seats rearward.
  1. Disconnect the battery. For additional information, refer to Section 414-01 .
  1. Remove the pin-typ retainer and the window control switch panel.
    • Disconnect the electrical connectors.
  1. Move the shift lever to NEUTRAL and position the shift indicator bezel aside.
  1. Remove the screws and the center console finish panel.
  1. Disconnect the shift cable.
  1. Disconnect the front floor console electrical connectors.
    1. Loosen the electrical connector bolt.
    1. Disconnect the connector.
    1. Disconnect the electrical connector.
  1. Remove the front floor console side finish panel.
    • If equipped, disconnect the electrical connector.
  1. Remove the front floor console front bolts.
  1. Remove the floor console.
Feb 13, 2011 | 2003 Lincoln Navigator
Gateway 506GR motherboard configuration
Item Description Item Description A Rear Panel I/O Ports M Front Chassis Fan Connector B Auxiliary 12-V ATX Connector N Serial ATA Interfaces C CPU Socket O Front Panel Header D CPU Fan Header P Front USB Connector E Memory Slots Q Front USB Connector F Standby Power Indicator LED R Front Panel IEEE-1394a Connectors G Floppy Disk Drive Connector S Speaker H ATX Power Connector T PCI Express x1 Connector I Parallel ATA IDE Interface U Front Panel Audio Connector J Battery V PCI Slots K Intrusion Switch Header W Rear Chassis Fan Connector L BIOS Configuration Jumper
Aug 21, 2009 | Gateway 506GR PC Desktop
I have the same problem!!!
Diagonally opposite to where you connect your mouse and keyboard, there will be pins for connecting front panel connectors. You can identify them by the names like SPK or Speaker written near them. You just have to match the front panel connectors with that of the pins. USB pins will be near these pins and will be labled as USB5 or USB4 on the motherboard. USB front panel connector can be inserted in only one direction.
Aug 14, 2009 | IBM (49P1599) Motherboard
Does my dell dimension 2350 have a dvi port?
No, it does not.
Check the specs of your desktop PC here:
Ports and Connectors
Externally accessible:
Serial
9-pin connector; 16550C-compatible
Parallel
25-hole connector (bidirectional)
Video
15-hole connector
Keyboard
6-pin mini-DIN connector
Mouse
USB
two front-panel and four back-panel USB 2.0–compliant connectors
Network
RJ-45 connector
Audio
three back miniature connectors for line-in, line-out, and microphone
Headphone
one front miniature connector for line-out
Serial
Parallel
Video
15-hole connector
Keyboard
Mouse
USB
Network
RJ-45 connector
Audio
Headphone
http://support.dell.com/support/edocs/systems/dim2350/specs.htm#1107078
Jul 26, 2009 | Dell Dimension 2350 PC Desktop
How can I remove gear shift knob on a 2003 Navigator?
it looks like you disconnect the shift cable and remove the center console finish panel with the shifter.
REMOVAL AND INSTALLATION Floor Console —Front, Navigator Removal and Installation
Apr 17, 2009 | 2003 Lincoln Navigator
Where to hookup front panel (PIII-3754LMR - AMPTRON)
Front Panel Connector The front panel header is where the connectors of hard disk drive activity lights, case speaker, reset button, power on/off button, computer power on light, and key lock, are connected to make them function smoothly. In the past days, users always have difficulty connecting the front panel due to a lack of standard location on the motherboard. Today, AOpen integrated all these disorder but essential front panel connectors into one 20-pin connector for easy usage. Connecting the front panel would no longer be the headache of installing motherboard anymore. Below is a view of this user-friendly front panel connector of AOpen motherboard.
please rate this post.
or donate on madridtelecom@gmail.com
Feb 08, 2009 | Intel Motherboard
Chaintech SK8T800 Motherboard Logo
236 people viewed this question
Top Chaintech Computers & Internet Experts
Ed Mac
WTF Chuck.....
WTF Chuck.....
Are you a Chaintech Computer and Internet Expert? Answer questions, earn points and help others
