Question about GE DBXR463EDWW Electric Dryer
Removal of plastic face panel
Does the plastic face panel that has the Start, Fabric care and Cycle Option knobs on it simple pop off? Perhaps with a screwdriver? I have to remove it and do not want to break it by forcing it off.
  • GE Master
  • 15,478 Answers
Usually not. Take the knobs off, they pull off and look for screws under them. Check the back of the panel to make sure there are no screws holding it on also
Posted on Jul 09, 2013
Testimonial: "You were 100% correct - 3 screws on the back that were very difficult to see if you weren't specifically looking for them. Great advice - thank you!"
How do i remove a front passenger side door panel on a 2010 jeep patriot
There should only be screws at armrest and behind door release lever..they will have small plastic covers that covers them ..You will have to remove window crank if it doesn't have electric windows which takes a special tool..The complete outer part of panel is just popped in with plastic pop locks..You can carefully pop it off by hand..You will see how simple they are attached..They also make a removal tool for these..It is possible for some to break however you can by a pack of them at a local parts store.If it is electric windows be very careful because you will have to disconnect wiring to the switches before removing complete panel...Top of panel is just slides under rubber window seal..
Feb 18, 2015 | 2010 Jeep Patriot
Htwp1200doww where does fabric softner go
You have to do it manually. Ugh. See below from manual:
Liquid Fabric Softener (Manually add during rinse cycle)
1. Turn OPTIONS knob to FABRIC SOFTENER
2. Measure liquid fabric softener carefully, following instructions on the bottle, and add during the rinse cycle.
OPTIONS (on some models)
Set this option when planning to manually add fabric softener during the rinse cycle or when you use extra detergent or bleach to clean hazily soiled items. It provides an enhanced rinse.
Oct 04, 2012 | Hotpoint Washing Machines
G155
You have to do it manually. See below from manual:
Sep 09, 2012 | Hotpoint Washing Machines
Removal of passenger door panel on 2001 Galant
simple there are 4 or 5 screws you need to remove. Sit in the car and facing the door panel theres one in the coin pocket, another in the door handle( you have to hold the handle out to get to this screw) one one the top left and two more on the right of the panel ( your car may have the last 3 screws exposed already if not they look like two plastic dots and you need to open them with your finger or a flat head) make sure all the screws are out and then grab the whole panel from the bottom and it pull it up and towards you. it pops right out theres maybe 8-10 or these points that need to be popped off then the panel will hang from the window trim then just pull it up carefully. Careful now the panel will be just hanging by the power door lock electric plug. unplug it and your good to go. Follow in reverse these instructions to replace panel.
Mar 21, 2011 | 2001 Mitsubishi Galant
2007 pontiac vibe gear shift light replacement. How do I get console apart to replace bulb.
On the 2004 Pontiac Vibe that I owned, I ended up taking it to the dealer. Perhaps this advice can avoid having you end up at the same place!
Remove the middle environmental control knob (fan blower speed, I think) by tugging on it until it comes off. Underneath you will find a single Phillips screw. Remove the screw and gently (so you don't mar it), pull at the plastic trim surrounding the environmental control area. It should pop out. You may also want to remove the two-prong AC outlet by prying it gently out with a small slotted screwdriver before attempting to pry out the trim panel.
After that panel is out of the way, you are ready to tackle the plastic trim surrounding the shift knob. Begin by removing the small holding compartment at the base of the shift knob. There is a single Philips screw holding the plastic piece to a supporting brace on the lower end. Four additional screws on the upper end are revealed by the removal of the environmental control trim piece as previously described.
Okay, from there, you're ready to gently pry loose the trim panel surrounding the shift knob.
The bulb can be located on the driver's side. It's a 'funny' looking bulb that is integrated into a two wire bundle. You may end up having to replace the bulb+wire bundle as a unit. The electrical connector is on the opposite side of the shift knob.
Feb 20, 2010 | 2004 Pontiac Vibe
Wash cycle dial wont turn...will still push in and pull to start
We have a GE WJRR4170 washer, with the same problem. At first I thought I might have to unscrew the entire control panel just to replace the knob. However, replacing the knob turns out to be easy.
Right behind the knob, holding it in place, is a nylon/plastic retainer clip. If you pull out the knob (into the "start" position), you will get easier access to the retainer clip. You can use a flathead screwdriver to push the clip out. The knob then will slide easily off the metal stem. A GE replacement knob costs $9 or $10, depending on the source.
Shame on GE, but the knob is designed terribly. The part of it that engages the dial has eight, flimsy plastic teeth. At any time, four of these are supposed to engage four little slots in the dial. However, the way the knob is designed, there will be a lot of wear and tear on these plastic teeth, so they'll wear out on every single machine.
Good luck to the many people who will have this problem!
Jul 26, 2009 | GE WJSR4160DWW Top Load Washer
Fabric softener cup on Maytag Neptune washer is full of fabric softener after the cycle. Checked valves in output mode. Both the main and the bleach valve turn on and dispense water, but no water dispenses...
Hi. your problem is actually a rather complicated one.
Timer and selector switches The timer switch is usually the largest dial on the main control panel. It can be either a mechanical device much like a simple clock, or completely electronic with just a digital readout.
The timer runs the washing machine in a pre-determined pattern. It provides the electricity to all of the washing machine components at the correct time and for the correct length of time.
The Start switch is usually part of the timer knob. When you set the timer to the proper cycle, you either pull or push the timer knob to start the cycle.
The selector switches or knobs vary from machine to machine. Most washing machines have one or several switches or knobs on the control panel besides the Timer/Start switch. These let you adjust certain settings; for example, the water temperature, spin speed, timer cycle, and so on. Normally, the washing machine completes the cycle selected on the timer, regardless of how you set these switches and knobs.
Jul 14, 2009 | Maytag MAH2400A Front Load Washer
Removing face panel on Kenmore clothes washer 417.40412700
If you suspect you have a defective timer it can easily be replaced by performing the following steps:
1. Unplug washing machine... and pull out the timer knob. Some knobs have a removeable center cap and hidden screw. Some are simply slip-fit. Remove the knob.
2. Remove console. This can be accomplished in one of two ways depending on which type of console you have.
a. If the console has removable end caps, the caps lift off by prying on the top from the back of the washer.
The cap will pull off towards you as you are facing the unit from the front of the washer.
There will be a screw under each end cap that you will need to remove.
b. If the console does not have removable end caps, you will need to slide a putty knife under the front corner of each side and push in while lifting up.
There is a retaining clip under each side that has to be released.
3. Once the console has been released it will lift up and fold back over the back of the washer in its resting position. Use care not to stress the small plastic hinges that hold it on. They can break easily.
4. Disconnect all power plugs and remove the timer's mounting screws.
5. Reinstall reverse of removal.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 09, 2009 | Kenmore Washing Machines
Removal of cycle time knob waching machine whirlpool lsr5233a
push knob in ,with the front panel unscrewed lift up to back side of the knob,there is a black plastic pin in the center of the knob.pull the pin out and it releases your knob
Dec 01, 2008 | Whirlpool 3362624 Washer Control Timer...
GE DBXR463EDWW Electric Dryer Logo
89 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
Are you a GE Dryer Expert? Answer questions, earn points and help others
