Depending on your operating system you need to use Windows Explorer or just use the find command. Use the key words you are looking for to search. Also, some operating systems have "recent downloads" to check.
Keith, if you just Google the same thing you entered, "manual for iomega 31882100" the very first hit that comes up (I'm using Google Chrome, other browsers may and do list these hits in a completely different order) is: Get This Manual-support site and in green below this is the website name, which is iomega-na-en.custhelp,com... Search engines are an awesome tool and are so easy to use. I've copied the link for your below. Get This Manual - support site
Your keyless entry system is going bad and you need a battery for your keyless entry system once you replace your battery with the new one thing should work properly
The manual says 'turn down water pressure.' It looks to me like this timer opens and closes the valve with or without water pressure. Sounds like it would be perfect timer for above ground cistern where gravity cause water to flow when valve is opened.
