Kenmore 24'' Laundry Center w/ Electric Dryer
Where do i buy a new belt?
    Top Expert:
  • Washing Mach... Master
  • 12,223 Answers
Go to www. repairclinic.com and get it
God bless you
Posted on Jul 10, 2013
aborcass
  • 2651 Answers
SOURCE: Kenmore/Whirlpool 417.99170120 Laundry Center
5303281153 comlete rear bearing kit, should come complete with insrtuction's
Posted on Mar 10, 2008
  • 958 Answers
SOURCE: dryer drum wont turn- burning rubber smell
could be a stuck gear box. burning rubber smell is coming from the belt sliding .
or the belt is just loose and can not turn the drum to spin it.
tnx 4 using fixya,
drcool
Posted on Oct 11, 2008
  • 686 Answers
SOURCE: how do you replace drain hose kenmore laundry model 41797812700
take off the hose clamp and pull it right off
Posted on Apr 03, 2009
SOURCE: Frigidaire Laundry center blows circuit when w/d run at same time
Okay, here's the best I can do from this distance.
The combo unit is on a 30-amp, 220-volt circuit. One cord supplies both washer and dryer.
The breaker does not trip until the washer motor starts running simultaneous with the dryer drying.
My guess is that (if the combo unit is connected correclty to the one supply cord) the dryer motor runs off the 110 volt supplied by the red/white wires & the washer motor runs off the other 110 volt leg, black/white (could be vice-versa, but that's irrelevant).
The dryer heating element runs off the 220 volt supplied by the red/black wires.
There are two most likely causes (but not the only possibilities):
- The breaker is bad -- could just be oxidation on the breaker contacts in the bteaker box -- I havae seen this conditon -- small amounts of oxidation can cause the breaker to overheat and trip -- of course, the more current the load draws the hotter the breaker gets.
- One of the motors (washer or dryer) is beginnig to fail (windings beginning to short) and drawing more than rated current which is overloading the breaker.
Checking thes two theories requires some not-so-standard equipment, and some more-than-handyman expertise. And if neither of these theories pans out, the troubleshooting gets more complicated.
So, to address your original question, "Can I fix it myself, or should I hire someone?, I would say you should hire someone. This wirite-up may give them a head start.
Let me know if you have any questions.
Charlie
P.S.
A third possibility (only possible if this tripping condition ahs existed from the beginnig of the w/d installation) is that the power cord is connected to the unit such that both motors are powered by the same 110 volt leg. Not being there to assess this, I can't say how likely this is, but it's a long shot for sure.
Posted on Jun 02, 2009
emissionwiz
  • 79865 Answers
SOURCE: I have a Kenmore laundry
please go to the attached link, there is a picture of the part that causes this problem as well as the belt, there is also a link to the factory repair manual that explains how to install the belt and pulley in a Kenmore stacked laundry center, the file is large so once you click the link at the bottom of the part picture give it a few min's to load the pdf file of the repair manual, it is free.
http://forum.appliancepartspros.com/dryer-repair/51107-dryer-squeaks-real-loud.html
Posted on Aug 25, 2010
I have a stacked Frigidaire FEZ831CA washer/dryer combo and when running the dryer it makes a very high pitched (AND LOUD) screeching sound. Any ideas as to what might be the problem? Thanks, Sean
screeching sound
Sean, Bad felt gasket body to drum, if belt drive on dryer, it could be worn and slipping, making a screech, or if not the belt, the drum may have a worn bearing on its hub allowing it to run crooked and rub where it should not.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Disassembling reassembling stacked clothes dryer
Frigidaire Stacked Laundry with Noisy Dryer
How to Replace an Electric Laundry Center Dryer Drive Belt Kenmore...
Mar 29, 2016 | Frigidaire Washing Machines
How do I replace the dryer belt?
Hello Philip, I appreciate your inquiry!
Based off the information you have provided you need help with replacing the belt on your Frigidaire laundry center. In order to access the pulley you would need to disassemble the laundry center. I would recommend seeking assistance from a professional technician for proper disassembly of your laundry center. Incorrect disassembly could cause personal harm or future issues within the laundry center. Best of luck! -Matt
Dec 15, 2015 | Frigidaire FFLE2022MW Electric...
Washer not working, dryer is
You should really provide a LOT more information than that. Such as what specifically is not "working".
If that panel is off, make sure it's unplugged. Be careful and good luck.
Dec 03, 2017 | Kenmore 24" Laundry Center w/ Electric...
Won't stay on when button is pushed, HOLD button down it will run but not heat !!!! PLEASE HELP !!!
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Apr 04, 2011 | Kenmore 9781 Electric Laundry Center with...
Washing Machines Logo
21 people viewed this question
Top Washing Machines Experts
