Question about Dell Latitude D630 PC Notebook
Screen flickering, flashing colors,
Screen flickers, and flashes colors, kind of like tv static but in color
  • 369 Answers
Disconnect the power cord and battery. Hold down the power button for a minute and then connect only power cord.
If not fixed:
Please scan your computer with free version of superantispyware:
http://www.superantispyware.com/
IF not fixed: It is a screen hardware issue.
Posted on Jul 10, 2013
5 Suggested Answers
  • 57 Answers
SOURCE: i get screen lockups
Could be an overheating problem... Get a hardware monitor and see what the cpu temperature is. PC Wizard is a good program and it's free.
Posted on Jul 30, 2009
  • 9 Answers
SOURCE: flickering screen with color bars
flickering screen with color bars may point to a problem with your fibre and this may call for you to change the fibre to prove if its a problem with the fibre connect to an external monitor if the problem does not occur then you can conclude that you have to change the fibre
Posted on Oct 28, 2010
stuart_cory_
SOURCE: screen flashes
What is the screen resolution set to? It may also be the refresh rate-some monitors are only capable of displaying 60Hertz-75Hertz. Did you choose an incompatible refresh rate? Could also be the connection.
Posted on Jul 20, 2012
  • 42 Answers
SOURCE: Laptop monitor bad color and flickers continuely, but when attached to external monitor, works fine
I'm going to take an educated guess here, because it sounds like the monitor's interface controller is bad. I forgot the name of the thing, but it's a small circuit board that's normally located at the bottom of the panel frame, between the flat ribbon cables and the round hinge cables.
"Inverter Board"
Posted on Mar 19, 2013
Flickering screen onto extended monitor
It could be the graphic card is out. You might have to buy a new laptop. sorry to say that though.
Jul 09, 2013 | Dell Vostro 1510 Laptop
Emerson flat screen tv just flashing colors
There are so many reasons for this fault. Check all the flat cable connections that goes to panel from T'Con board first. Re-seat them. This fault is technically called flickering. If you want to know more check this link.
Jan 24, 2013 | Emerson LD195EM8 19 in. LCD TV
Rear projection tv colors flickering
Two types or more of sets: regular TV sets with a picture Tube, big rear projection sets, Plasma, LCD, DLP
A model number would allow me to give you the answer--I suspect you have a set with a picture tube(regular tv)
Let me know which so I can try to give correct answer.
Mar 28, 2012 | Televison & Video
Hi I have a Samsung HLN467W, a 46" DLP TV. And after 50-60 minutes, it starts to flicker white, like lightning flashes. But the whole screen is not blank white, it's more like the images are...
It seems color wheel problem in your tv that gets problem after some time and you hear high pitch noise along with picture flicker.
Color wheel need to be replaced to solve this issue. Required color wheel is available with PartStore.com (click to view image of part and price info) and it is job of qualified tv repairman because light engine will take apart for that.
Hope these info will help you.
Thanks.
Mar 15, 2011 | Samsung HLN467W 46" Rear Projection HDTV
After the tv has been on for about 30 minutes the picture starts flickering really bad and eventually will go completely white like where it looks kind of like negatives? it works perfect for that first...
The colors wheel could dies at any time of the tv life,at any monent without any period of times.The colors wheel run at RPM spinning revolution are 1000 RPM a min. to make colors for this tv.The problems u discribing are one problem of the effect of the colors wheel is dying and worn out.The colors flashes like film negative,the picture flashes Black&White withtin the picture.Replace the colors wheel again,will solved this problems.
Nov 20, 2010 | Samsung HLN617W 61" Rear Projection HDTV
The colors pulsate from light to dark
There was a problem with the sony projection tv's that they called a flicker. Do a google search on your TV and flicker or search sony and flicker. There is all kinds of info about a service bulliten that Sony sent out. There were fixing it at no charge but Im not sure if this fix still applies since the tv's are getting older now.
Jan 01, 2009 | Sony KP-51WS500 51" Rear Projection...
DLP TV starts to loose picture after 1 - 1/2 hours of use
This tv has a 3 board video path. Analog main pcb --->Digital main pcb --->DMD pcb. see which inputs have the problem to narrow it down. if only some inputs, suspect analog board. if everything flickers(all inputs and menu), suspect the dmd or engine. you can see the lamp shine out the back. if the lamp is flickering, suspect lamp or ballast.
Nov 22, 2008 | Samsung HLN5065W 50" Rear Projection...
Ghosting, Flickering, Green Sparkeling Lines, Color Washout.
There is a component failure on the board inside the display. Since you did not post the model number that is all that I can tell you.
Mar 17, 2017 | LG Studioworks 700B (White) 17 in.CRT...
Screen/Picture Flickering
alo all..
i got problem wif my TV... sony wega trinitron 29inch..
- last 2 night... the TV @ screen slowly lost color for 2-4second... and after that it suddenly turn off for 5-10second and turn back on itself. the led blink 3-5times....
what the problem to my TV?
Jan 09, 2008 | Sony KP-46S25 TV
Dell Latitude D630  PC Notebook Logo
117 people viewed this question
Alun Cox
