Toshiba portege overheat
Hello there? I have toshiba portege m900. I installed linuxmint 14 on but the system is overheating. Please can you offer me some help? Thanks.
4 Suggested Answers
  • 8909 Answers
SOURCE: Toshiba portege m900 - installed
If you go to www.computers.toshiba-europe.com and let the web site find your laptop. Tell the system that you are using XP and a list of updated drivers will become available for free download.
It is an excellent system!
Hope this fixes your problem.
Posted on Nov 15, 2010
joecoolvette
  • 5660 Answers
SOURCE: Hi, My laptop turn off automatically
Try cleaning the Air Intake Duct first.
The laptop is shutting off because it's dirty inside.
A Processor has a Thermal Limit. This is the maximum operating temperature it will operate at.
If the Thermal Limit is exceeded, the Processor turns off.
(BIOS turns it off)
This is a built-in fail safe system so that the Processor will not burn up.
The Air Intake Duct is on the bottom of the laptop, to the left of the,.......better still, let me show you,
http://howtosolvethat.blogspot.com/2010/07/how-to-disassembly-toshiba-portege-m900.html
(Click on the photo to enlarge)
Where it states - Slide the latch -, go to the label above it, the label above that, then to the vent grille.
Air Intake Duct.
ALL power removed from the laptop.
Remove the AC adapter (Charger) and Battery.
Attach the plastic straw provided to the nozzle of the can of air. Break the plastic lock tab off of the top of the nozzle.
You may wish to place a soft cloth, such as a towel on a table, then stand the laptop up on one side on the towel. (Towel, or soft cloth to prevent scratching the laptop, and table)
Hold the laptop with one hand, the can of air with the other. Apply jets of air to the Air Intake Duct grille. Slowly go back, and forth across the top of the grille opening, then drop down to the next opening, (Slot), and repeat.
Squeeze the trigger in all the way as you start, let go when you reach the other side. Apply air as a painter would apply paint with a paint gun.
Refrain from tilting the can of air as much as possible. Tilting the can makes more propellant than air come out. This results in the can of air's nozzle freezing up. The nozzle will eventually freeze up. The velocity of the air coming out freezes the moisture in the air.
When this happens sit the can of air down for a while. Let it warm up.
As stated due to the velocity of the air there will be moisture 'produced'. After you are satisfied that the Air Intake Duct is clean, let the laptop sit.
The moisture will dissipate. (10, 20 minutes)
Reinstall the battery, and AC adapter.
WAIT 1 minute, turn the laptop on.
Still no?
Looking at Page 8 of the above link, click on the photo at the bottom of the page.
(Page numbers are below the last photo on every page. Click on Page 8))
At the top right of the photo is the Fan Assembly. It's the silvery looking round object with three curved openings in it. (Some of the fan's blades can be seen through the opening)
Observe the flat copper tubing, and how it leads up to the Fan Assembly.
(Copper tubes are Cooling Tubes. They connect to a Heatsink sitting on top of the Processor,
and further to the left, to the graphics chipset. Part of the Processor's socket can be seen. The purple rectangle is one outside edge. The graphics chip is encircled in red)
Where the cooling tubes meet the Fan Assembly is a type of Filter. (Rectangular in shape)
This filter can become clogged, and using just a can of air from the outside of the laptop may not do the job.
The fan's blades, center hub, and surrounding cage, (Shroud) will also need to be cleaned.
The laptop would then need to be disassembled, and the clogging debris physically removed.
(Q-tips, small soft brush, and air)
Due to the high heat involved when the Processor is operating, (Graphics chipset too), the Thermal Paste may have dried up.
To regress;
Heatsink:
Typical construction of a Heatsink is a flat plate of metal with tall, thin fins protruding from it. The plate of metal absorbs heat from whatever object it is placed against, and the tall, thin fins absorb heat from the plate of metal.
The tall, thin fins then radiate the heat away. The fan pushes air over, and through the fins of the Heatsink, and the air helps carry heat away.
The bottom of a Heatsink, and the top of the Processor's case are not perfectly smooth. A magnified view would reveal 'Pits, Hills, and Valleys'.
These imperfections create air pockets in-between the surface of the Heatsink, and Processor.
Air is an Insulator. Not a Conductor.
Thermal Paste, (Also known as Thermal Grease, or Thermal Compound), fills these voids, and is an excellent conductor of heat.
Should you decide to disassemble your laptop please post in a Comment.
We need to discuss Anti-Static Precautions, providing labeled compartments for the individual screws, and proper disassembly techniques, for a start.
Reply in a Comment.
Regards,
joecoolvette
[ More disassembly information,
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-toshiba
Go to the second Portege heading down.
Click on M900D
(This is a PDF file. Allow up to 30 seconds to download. Additional time may be required once you see the first page. Watch the download progress bar. There is no 'junk' nor malware attached]
Posted on Jun 14, 2011
jadiazq
  • 2878 Answers
SOURCE: I just format my toshiba m900 portege and I can't
Reload the NIC drivers. Download LAN driver, uzip, and run setup.
XP
http://www.toshiba.co.th/beta/th/support/download_Por_M900.html
Win 7
http://www.toshiba-drivers.org/toshiba-portege-m900-drivers-download.html
Posted on Oct 14, 2012
I need to replace my fan for my toshiba laptop, nad need to know how to disassemble the laptop to get to the fan.
Toshiba Portege A100 http://www.irisvista.com/tech/laptops/Toshiba-Portege-A100/remove-systemboard-replace-fan-1.htm Toshiba Portege A600 or A605 http://www.irisvista.com/tech/laptops/Toshiba-Portege-A600-A605/disassemble-laptop-1.htm Toshiba Portege M700 http://www.irisvista.com/tech/laptops/Toshiba-Portege-M700/take-apart-tablet-pc-1.htm Toshiba Qosimo F40 or F45 http://www.irisvista.com/tech/laptops/Toshiba-Qosmio-F40-F45/laptop-disassembly-1.htm Toshiba Qosimo G25 or G20 http://www.irisvista.com/tech/laptops/toshiba-qosmio-g25/replace-cooling-fans-1.htm Toshiba Qosimo X305 http://www.irisvista.com/tech/laptops/Toshiba-Qosmio-X305/laptop-disassembly-1.htm Toshiba Satellite 1955-S805 http://sites.google.com/site/electrochain/toshibafan Toshiba Satellite 2410 http://mardou.dyndns.org/Privat/homepage_cms.ns5/content/homepage_tutorials_toshiba_satellite_2410_-_luefter_tauschen.html?Open&lang= Toshiba Satellite A35extlink.png http://www.irisvista.com/tech/laptops/ToshibaA35/Satellite-A35-fixing-overheating.htm Toshiba Satellite A60extlink.png http://tech.icrontic.com/articles/clean_laptop_heatsink Toshiba Satellite A105extlink.png http://www.paulstravelpictures.com/Toshiba-Satellite-A105-Laptop-Overheating-Dust-Removal-Guide/index.html Toshiba Satellite P10extlink.png http://loblog.wordpress.com/2006/03/08/toshiba-p10-schaltet-sich-ab/ Toshiba Satellite P305Dextlink.png http://www.insidemylaptop.com/clean-cooling-fan-toshiba-satellite-p305d/ Toshiba Satellite X205extlink.png http://www.irisvista.com/tech/laptops/Toshiba-Satellite-X205/take-apart-laptop-1.htm List of a lot of pc fan repair guides:http://repair4laptop.org/notebook_fan.html
May 09, 2011 | Computers & Internet
Hello I have just bought a toshiba nb250 and the buyer has on the website this message NO OPERATING SYSTEM how do i get this sorted await your reply, many thanks pamela
Well you download for example LinuxMint from here http://www.linuxmint.com/download.php and install it. Or you buy Ms Windows for about €100.- and install it.
Feb 13, 2011 | Computers & Internet
Toshiba portege m900 - installed windows xp although the recommended OS is windows 7. I am having trouble with my USB video device(web camera). Night time, the video appears dark and I am not able to see...
Nov 15, 2010 | Toshiba Computers & Internet
Does Toshiba Portege 3490CT ram can be bigger than 128. If so adv availability & selling outlet please.
The motherboard has 128 MB memory (soldered on board). However there is still empty slot for further upgrade. You can install another 128 MB PC100 SDRAM memory to get maximum of 256 MB.
CompQ
May 09, 2010 | Toshiba Portege 3490CT Notebook
My portege s100 cannot boot, screen full of garbled
hello
If your system is not properly booting you can try the system restore..
and if the system restore does not work please mention the error message it is showing and elaborate your problem..
Thank you
Jul 15, 2009 | Toshiba Portege S100-S1133 Notebook
Memory upgrade.. toshiba portege 3500
hi..the one of memory located at the lower or under the one slot memory installed..thanks...^_^
May 13, 2009 | Toshiba Portege 3500 Tablet PC
Toshiba Portege M400 screen turned off - can't get back on.
reboot, keep tapping F8 key, until you get to the system start up page ( black screen with writing )
the top offer is called
" last known good"
Choose this, let it roll, see how you do.
Or same reboot, keep tapping F8, til you get into start up menu, choose safe mode,
when it boots up, do a system restore,
start,all programmes,accessories, system tools,
system restore, choose the date it offers you,
Let it roll,
Should be good, if no hardware problems
Regards
Richard.
Apr 21, 2009 | Toshiba Portege M400-S4032 Notebook
Toshiba Portege M400 to Vista
Here's a link for Toshiba's UK site. I looked around a bit and they don't seem to offer much in the way of drivers. You might try driverguide.com I've found it to be a good place to find those hard to find drivers, plus it's easier to use than most manufacturer's sites.
http://www.toshiba.co.uk/
Jul 04, 2008 | Toshiba Portege M400-S4032 Notebook
Computers & Internet Logo
69 people viewed this question
David Payne
David Payne
