Question about Kenmore Washing Machines
Kenmore H2 front loader washer wont run
Machine did put in water then stopped. I replaced the door switch cleaned the trap and got it to spin out the water, but now we are back at a point of it does not work
    Top Expert:
  • Kenmore Master
  • 12,223 Answers
See this steps and fix it. God bless you
Check Power
Check the outlet by plugging an appliance into the same outlet the washer was plugged into an running the appliance a hair dryer works good for this it will draw some amperage. If it works fine move on.
Control
To check the control remove the top panel and then remove the console to access the wiring to the control. Find the wire feeding the control from the main power cord. If you cannot visually see this refer to the tech sheet or service manual. Connect voltmeter to the 2 wires feeding the control if it is recieving power and it does not respond replace the control
Posted on Jul 10, 2013
  • 1531 Answers
SOURCE: Water doesn't drain
you could have a bad drain pump.
have you checked the hoses that come from the bottom of the tub to the drain pump for anything that might be stuck in there,also check the hose that comes off the drain pump to the wall and look for an obstruction.
Posted on Jan 31, 2010
SOURCE: kenmore 417.29042992 front loader washer
If front loader washer quit spinning, check the wax motor switch. You can make a temporary fix by providing a short on the door lock contact. The Kenmore 417.29042992 front load washer provides a test connector that's readily accessible behind the front lower panel. Insert a wire between connector pins 1 and 2 (red and white/red color wires) and your washer should spin during the spin cycle. Hopes this helps.
Posted on Jan 28, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: washer will not do a spin cycle for rinse or end of cycle
you can check two things,. One is, is the belt broken or stretched, the other is the motor, is the motor turning if the motor is turning then replace the belt. If the motor is not turning replace the motor.
Posted on Feb 08, 2009
  • 117 Answers
SOURCE: Affinity front loader ATF7000FGO E23 ERROR
E23 error code means the drain pump relay on the control board failed or wire off pump. You already replaced control board so check the wire at the pump and make sure it's secure.
ftp://ftp.electrolux-na.com/ProdInfo_PDF/Webster/134879700.pdf
<a href="http://tclaundryrepair.com/">St Paul Appliance Repair</a>
Posted on Feb 25, 2009
  • 1294 Answers
SOURCE: kenmore front load washer wont drain gives F2 error
There is an awesome guy on fixya with this:
http://www.fixya.com/support/r622155-kenmoreelitewhirlpoolduetdoorjammed
http://www.fixya.com/support/r615354-fherrorcodewhirlpoolduetkenmore
Posted on Mar 28, 2009
Changed door switch on my kenmore h2 plus cause of error code and it still wont work
Whirlpool & Kenmore Dryer Repair #01 - Won't Start or Run ...
? 8:50
https://www.youtube.com/watch?v=2WF71WdGn_g
Oct 19, 2011 - Uploaded by canyonman1963
This one deals with testing and replacing the door switch. ...sears wont work wont spin wont wash wont heat wont start fix repair bad noise noisy ... how to change a 4 to a 3 prong cord, to figuring out my door switch problem.
Dryer Door Switch - How To Replace - YouTube
What to do when your washer won't fill, start or run - YouTube
? 2:00
https://www.youtube.com/watch?v=Atd5YHbRh7M
Jun 20, 2012 - Uploaded by searspartsdirect
So if my washer wont start just call Sears. .... Bad sears mykenmore is only 2 years old, fill take 30 mins,,,wash 50 mins rinse never spin never,, ...
Nov 28, 2015 | Kenmore Washing Machines
I have a kenmore front loader recently it has decided to stop spinning and retain water. Help?
Regardless of model, this is probably a drain pump problem. With many Kenmore washers, there is a pump trap that can become plugged. Remove the washer's bottom front panel, if there is a white drain pump casing, turn out the pump trap counter-clockwise, making sure to have a bucket to catch the water. Check and clean the trap, and try to spin the pump impeller, if the pump impeller is stuck, something may actually be stuck in the impeller. If the impeller feels wobbly, you will want to just replace the drain pump entirely. Depending on the model, there may just be a hose connecting directly to the pump, with no trap available, just pull the hose off and check for an item plugging the pump. With any model, there will be WATER that will POUR out. Be prepared.
Mar 17, 2011 | Kenmore Washing Machines
Washing machine is not completing spin cycle at high speeds. Only goes slow speed tumble for a few times and then stops.
Below is for Whirlpool/Kenmore, u might find it helpful. Some machines have a small trap door on left front bottom, coin trap.
The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the drain pipe you see. The white filter cover is right in front. Get yourself a good plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully. Check your pump too, comes after the filter.
On some models the filter is located ‘inside’ the big hose from the bottom of the tub. This takes more time to clean.
Jun 04, 2010 | Frigidaire ATF6000ES Front Load Washer
Cylce stops after 1st drain before spin out
I have kenmore washer front load H2 after 1st circle of wash it stop and start beeping with code F11. My email address is anarfi1212@ live.com
Jan 21, 2010 | Kenmore HE2 Plus Front Load Washer
I have a he2 kenmore front end loader washing machine...it stops mid load and flashes F20
Something is in your pump trap, easy fix. pop open the bottom panel by removing the three screws under it. requires a torx bit or a nut driver. if you can tilt the washer back so the front legs are a foot or 2 off the ground, it will make this a lot easier. once open you will see a twist off cap. before you remove this be prepared for the residual water to eject out when you open it. these can not get all the water out so there is always some, tilting it back will minimise this or putting hose clamps on the pump to tub hose can help but not nesesarry. twist it out and clean it out, also stick your fing into the two holes where the trap is located to see if any coins have gotten stuck. once clean, make sure you line up the trap arrow with the base. then button it back up, good luck
Dec 04, 2009 | Kenmore HE2 Plus Front Load Washer
My Kenmore HE 2 Plus front end loader washing machine has a load and when I open the door water pours out. It will NOT spin
since front loader wont spin till its empty
id be willing to b et you have a clog in the pump
get a few towels
and spread em out in front of the machine
take off the fron toe kick 3 T-20 screws on front lip bottom
you should see the trap cleanout dead center
turn the handle 1/2 tun and pull straigt out...
be advised the washer will dump
you now have the sump in your hand ensure it and the pump inside are clean
reassemble and test
use 1 tablespoon of soap no more
suds will mess this machine up
Oct 06, 2009 | Kenmore HE2 Plus Front Load Washer
Stopped working mid cycle. The timer still counts down but does not fill, agitate, spin, drain. And before it stopped, the water that was draining out smelled really bad.
The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the hose you see. The white filter cover is right in front. Get yourself a bunch of towels or a good big plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully.
Next: You can use Affresh to clean your front loader. Deposits of soap and other such things can be stuck around the inside tub of your washer. Try this product, it works great on all front loaders. Use quite hot water with the Affresh pellet with no clothes and run the machine through a cycle. Also helps with any stagnant water smells. Have you cleaned out your pump lately. Put the pellet inside the machine, not in the soap dispenser.
Pl give me a good rating for the free help, thanks.
May 30, 2009 | Kenmore 3.5 cu. ft. Front Load Electric...
KENMORE ELITE SMART WASH QUIET PAK 4 FRONT LOADER,
Now this is a drain issue from the pump, clean out or check drain hose position to make sure hose isnt in water. Front loader right? kick panel under door has two screws, 1/4 or Torx T20 will remove them. You will see a clean out screw handle that holds junk. Use a trash bag wrapped around the clean out to catch water and debris..
Oct 21, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore 417.29042992 front loader washer
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Jan 23, 2008 | Kenmore 44102 Front Load Washer
Pump won't stop
ur controler most probabley gone
Oct 02, 2007 | Kenmore 43142 Front Load Washer
Washing Machines Logo
20 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
