Question about Saws
Bosch pts 10 table saw
2 seconds of grinding noise on starting up, normal or is something wrong that I need to address?
  • 80 Answers
SOURCE: How to change blade on 10" Craftsman table saw?
you need to grab the blade with something.maybe some pliers(if you are not going to refurbish blade) and loosen the nut in the center of the blade. i think it is a left hand thread(cw to loosen) because of the rotation of the blade. if the nut is on the left when looking from the front it is probably left handed. make sure it's unplugged and wear leather gloves so you don't get cut. install in reverse...
Posted on Jan 20, 2009
  • 205 Answers
SOURCE: I have a Skil 10'' table saw that will not power on.
If your switch is in the base of the machine, like some portable table saws. The switch may be full of saw dust. I hade one that the reset switch couldn't be pushed to reset because the housing was packet with saw dust. I simply opened the cover and vacuumed it out. If you open your switch box up and it is clean inside, your switch is probably bad. You can check it by taking the two wires off your switch (with the saw unplugged of course) and taping them together, if the saw works when you plug it back in, get a new switch.DON'T use your saw wired this way.
Posted on Mar 28, 2009
  • 59 Answers
SOURCE: My Skil Saw 10 will not start now.
depends wether the saw is belt driven or gear. just because you cant hear the motor doesnt mean its not running.
Posted on Apr 25, 2009
rowdy45176
  • 2176 Answers
SOURCE: Bosch 4000 table saw. The saw stopped while
If you are mechanically inclined and it sounds that way do you have a volt ohms meter?? If so start at the cord and check the continuity to the brush holders. Why did you replace the field? You might have had a stuck brush or some other problem. Make sure the brushes move freely in the tubes and also look for discoloration on the commutator of the armature. Let me know what you find and I will try and help you thru the rest of it.
Posted on Aug 25, 2009
  • 384 Answers
SOURCE: key switch on Craftsman table saw
Switch is filled with sawdust. Disassemble and clean out.
Posted on Sep 14, 2009
Installing the rear outfeed support tubes
About 11,900 results (0.88 seconds) Search Results
    Bosch TS1002 Table Saw Rear Outfeed Support ... - YouTube
    ? 3:59
    https://www.youtube.com/watch?v=d5B4227hBUk
    Jun 18, 2012 - Uploaded by Isabel De Los Rios
    Bosch TS1002 extends 18-inches and stores flush to table. It extends the working depth of Bosch 4000 10 ...
    Tool Free Way of Attaching the Out-Feed Table. - Angelfire
    www.angelfire.com/.../funwithtubes/.../ss_outfeed_table_mounting.html
    The outfeed table which is available from Shop Smith works very well once ... The bottom part supports the far end of the table while the near end attaches to the ... the screws can be installed through the brackets on the outfeed table to hold it in ....Insert one of the extension tubes in the rear rip fence rail, adjust it so it sticks ...
    Craftsman 137.415030 Operator's Manual - ManualsLib
    www.manualslib.com > ... > Saw > 137.415030 > Operator's manual
    be installed underneath the rear. outfeed support tubes (2). Fig. L. 3. Insert the rear outfeed support. tubes (2) into the two holes in the. rear of the saw table, and ...
Feb 08, 2016 | Saws
Bosch table saw GTS1031 won't start.
In case of this kind of questions you can only advise someone to go back immediately where they have bought the tool for warranty or exchange or money back.
No other suggestions but few years to late to give the only right answer in this cause of question.
Aug 29, 2014 | Bosch GTS1031 10-in Portable Jobsite Table...
Bosch 4000 table saw motor does not turn, very stiff
Possibly something has jammed inside the motor housing although unlikely.
Electric brake seized perhaps?
Carbon brushes need replaced?
These saws (and the newer 4100) have a history of motor problems, with the field winding and electronic motor speed control being the most common points of failure. If you go to an online tool parts supplier like toolpartsdirect- Bosch 4000 saw you will see a list of the parts available, as well as the most commonly ordered parts.
Thanks go to Jason for his blog post at:
http://mypeculiarnature.blogspot.co.uk/2013/07/bosch-4000-table-saw-fix-momentum-lost.html
May 23, 2014 | Bosch 4000 - 07 Electric Table Saws
My 10" Bosch miter saw
I would remove the blade and try the saw again, there is a possibility that you might have gotten a flange on incorrectly or left the spacer out.
Sep 10, 2011 | Bosch 10" Slide Miter Saw
The belt on my 10"
you need to check your brushes again. something is making contact or shorting out. look at everything carefully
Dec 25, 2010 | Delta 36 979 10 Inch Left Tilt 1 1/2...
Bad vibration and noise from saw
Are you sure blade is straight, and mounted on arbor correctly? that's the first thing to check. Or remove blade and 2 arbor plate's and run saw. If you have a vibration after that you have a bearing problem.( rear bearings go bad on these saw's) other they are the best saw for the price. We have about 50 of the 4000 model. hope that help's Never had a vib problem.
Jun 01, 2010 | Bosch 4100 10" Worksite Table Saw
My Bosch 4000 table saw blade spins very slow. What the problem would be?
could be bearings locking up/seizing or do you smell any burning when running indicating the armature/field are burnt from possibly overloading with a dull blade.
Dec 17, 2009 | Bosch Saws
Sounds like I need to lubricate something.
flip over the saw you will see a motor
take it out the bearings need changing.
Aug 06, 2009 | Bosch 4100 10" Worksite Table Saw
Saws Logo
60 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
