Question about Sony Bravia XBR KDL-40XBR6 40-Inch 1080p 120Hz LCD HDTV
Fan noise in back of sony bravia xbr 40 in flat screen tv
Continous noise similar to a cooling fan running inside the tv
  • 15 Answers
SOURCE: crackling noise from tv
That crackling noise has nothing to do with the television and everything to do with your antenna. It is merely signal breakdown, when you get signal interference with analogue tv you get snow, with digital you get little squares on the screen and/or sound breaking and cutting in and out, get a licensed antenna repairer to come out check your signal strength as you may need a booster or your antenna could just be a few degrees off....
Posted on Dec 30, 2007
SOURCE: audio issue with Sony Bravia tv
Each time our TV starts the snapping sound we reboot the cable box. Problem solved.
Posted on Jan 15, 2008
PaulTulsa
  • 14 Answers
SOURCE: Sony Bravia XBR 40" LCD
First, HORIZONTAL CENTER.
1) Press MENU.
2) Scroll to SETTINGS.
3) Scroll to SCREEN.
4) Go to HORIZONTAL CENTER. Move the picture to the right. Hopefully, the line will go away. Otherwise, there is a problem with the pixels or the signal processor. Call 1-800-222-SONY. Or, http://eservice.sony.com. Have a high-limit credit card handy for out of warranty repairs. Sorry about that.
Posted on Feb 17, 2008
rustym62
  • 201 Answers
SOURCE: standby light blinks 13 times
13 blinks is backlight error.. can be 1 of 2 things, 1st bad inverter board (on left side panel looking from back) it has several plug ins to the panel as it supplies voltage to the backlights.2nd could be panel itself as backlights are built into it they can't be replaced. Inverter is probably around $200 +labor, panel= buy new tv... they are outrageously expensive. Good luck!
Posted on Apr 29, 2009
welcomejee
  • 10594 Answers
SOURCE: buzzing/fizzing noise from back of sony flat screen tv
Below is an image of rear side of your TV, Sony KDL-40W5500
Top right corner is marked there and possible cause of noise seems back light inverter board, there are high voltage going to CCFL inside LCD panel and seems high voltage leakage causing that buzzing/ fuzzing noise.
Replace back light inverter board upon voltage leakage confirmation.
Thanks.
Posted on Oct 23, 2009
Testimonial: "Thank you very much for the very prompt reply. This seems a very likely cause. My TV is only a week old so I will contact the supplier. Thanks again."
40 inch sony bravia making buzzing noises....any suggestions
There are 2 small 1.5" fans that are located on the top right and left sides of the screen. These fans are of the non ball bearing type, so the bearings may be wearing out. You can either replace the fan or add a couple drops of oil to it. Remove the label on the back of the fan and put the oil there, it should quiet down. This will work for a while but eventually the fan will need to be replaced.
Good Luck!
Rich Lilja
Feb 28, 2015 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
SONY BRAVIA - 40 XBR .TV will not tune into digital channels. We get a blue screen with No picture and states No Event Information and also states MPEG U1
Hi Douglas,
First of all, thank you for purchasing the service/repair manual of KDL-40XBR2.
Please email me at mjsvillanueva23@yahoo.com, I will send to you the copy.
Again, thank you so much!
Have a great day!
Mjsazon
Jan 15, 2012 | Sony BRAVIA KDL-40XBR2 40 in. LCD HDTV
Sony XBR 40" tube tv.
Failure of the vertical deflection module/circuit. The tv will have to be opened, the vertical deflection circuit found and replaced.
Definitely a job for a pro - the circuit is going to be extremely difficult to extract. The repair will cost you about $200: $20 for a new circuit and $90 per hour for the 2 hour job.
Sep 03, 2011 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
TV cooling fan repairs
If the cooling fan vent has a removable panel then you should be able to access the fan through it. A silicone based type grease should be used directly on the fan shaft after cleaning...do not use a liquid or spray lubricant. The fan could easily displace the oil inside the TV chassis onto parts of the optics engine and do some damage or otherwise affect the picture quality.
May 07, 2010 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Buzzing/fizzing noise from back of sony flat screen tv
Thanks.
Oct 23, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Sony Bravia KDL-52WL140. We went to bed with working TV and woke up to vertical lines on entire screen with every input. My husband has disconnected all inputs and cables to check for any noise or...
it is fixable, but it depands on the cost, compared to buying a new 1..the problem is with the vertical deflection board....if can get it hope it will work..other options are, reservice the whole unit ..
Oct 20, 2009 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
Vertical line on teh left side of the screen
It definately looks like a mechanical defect with the screen. If you see the line when the set is shut off this means that the screen may have a crack in it, or there is a defect in the substrate.
This type of fault is fixed by replacing the screen assembly. The cost of this would not be worth it.
Jerry G.
Dec 08, 2008 | Sony BRAVIA KDL-40S2010 40 in. LCD...
1) Press MENU.
Aug 27, 2007 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
SONY BRAVIA 32" XBR LCD TV KDL-V32XBR1
What about the Led, it shows blinkig light or just dead . if no blinkig at all could'be power supply fuse and or the powers upply board
Jun 22, 2007 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony Bravia XBR KDL-40XBR6 40-Inch 1080p 120Hz LCD HDTV Logo
46 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
