Question about Sony Ericsson Xperia Arc S LT18i
Not turning on
My sony ericission xperia lt 18i is not getting turn on ,it is only showing a warning symbol.what should i do..please send me the answer quickly please please...
My phone isn't turning on. When I press the power button it shows the 'Sony' and then shows an error symbol in that typical triangle box with a phone beside it. Help!
Leave it charging for an hour without trying to turn it on. After an hour with its proper charger, turn it on.
Also, try holding volume up and power at the same time for 3 seconds.
Another way to perform the above is to look in the side SIM card slot for a red button. Push it gently for a second.
Jun 26, 2016 | Sony Ericsson Xperia Arc
When I try to turn on my phone , it only shows the startup screen, 'SONY-XPERIA' ,and does not turn on. It just keeps showing that and does not start. Please Help..
Needs to be recovered probably. Don't know if it will help but you could try holding power and down volume. May get into recovery mode and let it recovery itself, otherwise it's reflash time.
Aug 28, 2015 | Sony Ericsson Xperia Arc
Sony xperia mint restrictions code to use other sim
Hello. You can get the unique unlock code for your Sony Xperia Mint from WickedUnlock.com at an affordable cost. Good luck.
.................UNLOCKING INSTRUCTIONS.................
1. Switch ON your Sony Xperia Mint with a Not Allowed SIM Card.
2. Your Sony Xperia Mint will request to enter an unlock code.
3. Tap the box where you have to input the code and a number pad will appear.
4. Type in the unlock code we send to you.
5. Press the 'Unlock' button on the phone.
6. Your Sony Xperia Mint phone should now be unlocked.
Nov 20, 2014 | Cell Phones
Key code needed for Sony xperia L
Hi. What kind of code are you asking for your Sony Xperia L? If it is a network unlock code, You can get it from ClassicUnlocking.com at affordable cost.
UNLOCKING - INSTRUCTIONS
1. Switch ON your Sony Xperia L with a Not Allowed SIM Card.
2. Your Sony Xperia L will request to enter an unlock code.
6. Your Sony Xperia L phone should now be unlocked.
Jul 01, 2014 | Sony Ericsson XPERIA X1 Smartphone
My sony ericsson xperia mini pro wont turn on
First, check if the charging port is properly and snugly connected. Then, check your batteries. Maybe your batteries aren't charging properly. If the battery is self-replacable, try cleaning the golden battery connectors inside first. Or, your battery may need to be replaced
Feb 02, 2014 | Sony Ericsson Xperia mini pro (SK17/SK17i)...
Hi! I need to unlock my sony ericsson xperia x8 phone from telering network in austria. my IMEI is 012560003752507. Can you please help me? I went to all mobile stores and nobody can't do it. Thank...
It's Telstra Network lock in Australia!! You need to Unlock it using the Unlock code,You can get the code from superunlockcodes and get the Free Unlocking Instructions from here Mobileunlockguide and Unlock it step by step...
Sony Ericsson Xperia X8 Unlocking Instructions Warning: Do not enter any wrong unlock unlock codes on your Sony Ericsson Xperia X8 mobile phones. If you enter over a certain amount of wrong unlock codes on your mobile phone, your phone may get hard locked and sometimes become unusable.
1. Switch ON your Sony Ericsson Xperia X8 with a Not Allowed SIM Card.
2. Your Sony Ericsson Xperia X8 will request to enter an unlock code.
6. Your Sony Ericsson Xperia X8 phone should now be unlocked.
*NOT ACCEPTED : We mean, to use a sim card from a network other than the network your Sony Ericsson Xperia X8 is locked to.
Jun 23, 2011 | Cell Phones
My xperia x8 phone is not working properly its hanging a lot and my music and video files are not being played properly
hi my name is neil and i just got a sony ericson phone(xperia x8) but i can't figure out how to send music,videos and pictures through bluetooth..can somebody help me please...?
Feb 20, 2011 | Sony Lands Phones
Sony ericsson xperia x8 won't send or receive picture messages
to send a picture by message?
Go to your album pick a picture touch the message symbol and send it as message hope this helps
Feb 07, 2011 | Sony Ericsson XPERIA X8 Cell Phone
Xperia x1 won't charge. The charging symbol will appear on the screen for a short period of time (perhaps 2 or 3 minutes) before disappearing a showing the full battery symbol. This shouldn't appear...
First try to replace the battery, a drained or low voltage battery won't charge up.
For infos on how to fix the Sony Ericsson Xperia X1 Not charging:
http://mobilephonerepairguides.blogspot.com/2011/01/sony-ericsson-xperia-x1-not-charging.html
Aug 31, 2010 | Sony Ericsson XPERIA X1 Smartphone
Sony Ericsson Xperia Arc S LT18i Logo
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
