Question about Fisher and Paykel Fisher Paykel Intuitive Eco Washer IWL15
Fisher Paykel Washer Model SWL26CW1 Fault Code 130
Fault code 130 comes up on screen.
  • 34 Answers
SOURCE: service fault 130
rotary position sensor fault. underneath the machine. Unbolt plastic cover with 16mm socket all of the plastic will come off. Undo four 10mm bolts around shaft. Pull off the big round thingy with cooper wire on it carefully. The purple wire is connected to the sensor which looks like a computer card and fits between the copper things ,pull up the sensor carefully and unpug the connection clean off the blue stuff on contacts,use electrical spray cleaner. Put back together in reverse.
Posted on Aug 03, 2009
  • 34 Answers
SOURCE: fisher@paykel Intuitive eco comes up with code 130
Comments: Aug 03, 2009 - if it still doesnt work reset the machine by turning it off at the wall and waiting 2mins and start again. If that doesnt work the sensor may need replacing.
  • 41 Answers
SOURCE: My fisher and paykel washing machine keeps flashing a fault code
needs a new Rps sensor , 130 is a fualty Rotor postion Sensor
Posted on Jan 31, 2010
SOURCE: new fisher and paykel washer WL26CW fault code 245
the drain pump impeller is seized; you just need to turn it a bit and will work just fine afterwards.
Posted on Mar 26, 2010
  • 713 Answers
SOURCE: fault code 130 - fisher and paykel intuitive iw812
Hi just read your posting.Now Error Code 130 means the fault on your machine is called Single Rotor Position Sensor Error.This means the Rotor Sensor which is located on your motor is faulty or the wiring to the rotor sensor is faulty or the Control Module that reads the information from the rotor sensor is faulty.Now to test the wiring you need an electrical tester to check if the wires going to the rotor sensor are broken but unfortunately to test the Rotor Sensor you need a device called RPS tester.If you eliminate the wires as the fault, which is not too difficult, and change the rotor sensor without testing it the fault could be the Control Module.I am sorry I cant help you test the rotor sensor without an you having an RPS tester.Please reply and let me know how you would like to proceed and I can help you as much as I can .Looking forward to your reply.
Posted on Aug 04, 2010
What is fault code 130 and how do I fixit?
130 indicates a faulty Rotor Position Sensor (RPS) or a bad connection to the RPS. This can be a common fault on all Smart Drives. Rather than explain the the procedure you can watch this video which a kiwi guy has done on how to fix it if you are good with that sort of thing. IF you live in NZ the best deal to get a new RPS is Rotorua Appliances or search TradeMe for RPS. To watch the video click the link. Good luck https://www.youtube.com/watch?v=6FQc64aBzc0 Fisher and Paykel 130 10000010 Error Code Fix
Jun 22, 2015 | Fisher and Paykel GWL11 Top Load Washer
Washer will not spin there is water on the floor and has a fault code of 130 it is fisher+paykel brand model numberWL26CW1
Hi just read your posting.Error Code 130 means your fault is called Single Rotor Position Sensor Error.This component is attached to your motor which is underneath your machine.What concerns me is your machine is leaking.Did the Error Code appear the same time your machine started leaking?The reason I am asking this is because the water could have damaged the rotor sensor.Is the water leaking underneath the machine?Please reply with additional information and I can help you rectify this fault.
Jul 20, 2010 | Fisher and Paykel WL26CW1 Top Load Washer
Hi my fisher and paykel model MW15 wont agitate or do anything really, and the starting from the left hand side, the cycle lights 1st and 7th come on. what does this mean?
This is fault code (130).the lights that are on are added together,il explain how below
0 0 0 0 0 0 0 0
128 64 32 16 8 4 2 1 This is The Rotor Position Sensor located in the motor underneath the machine.from underneath undo the pig plastic nut & take off the big round cover with the magnets in it.undo 4 bolts in centre of motor.The rotor Position Sensor has the plug with about 5 wires on it.
May 31, 2010 | Fisher and Paykel Fisher & Paykel Washer
Jan 24, 2010 | Fisher and Paykel IWL12 Top Load Washer
Service/error code 130 on Fisher & Paykel intuitive eco washer
Jan 24, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Fault code 130
Nov 09, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Intuitive eco Fisher & Paykel
try google search for the actual model and fault code
Jun 04, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher & Paykel Washing Machine IWL12
130 rotary position switch fault 136 motor fault
Apr 29, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
19 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
