Question about Magic Chef CTB1722 Top Freezer Refrigerator
Water Found At The Bottom Of The Refrigerator
Magic Chef CTB1722 (ABA or ARA, can't tell from the label) - no ice maker - no water dispenser - freezer is on top - freezer is frost free - freezer and refrigerator working fine - the back of the unit is a solid panel - small removable panel at the bottom of the back of the unit I keep finding puddles of water at the bottom of the refrigerator, under the (empty) produce drawers. What is causing this? What can I do about it? ( please provide instructions and pictures if possible ) Thanks much in advance for any help Steve
Krazytech
  • 725 Answers
SOURCE: water squirting from ice maker
Does it do it all the time or only when the ice maker call for water... you may have a bad water valve 67006531 VALVE, DUAL WATER or a ice dam in you icemaker let me know
Posted on Aug 25, 2007
  • 2920 Answers
SOURCE: Magic Chef refrigerator stop cooling
check the fan relay and the compressor to make sure it is still working...if not there is a capasiter you can replace to get it to work again
Posted on Aug 27, 2008
  • 531 Answers
SOURCE: Water leaking from bottom of unit
check to see if if drip pan leaking may be water line
Posted on Apr 07, 2009
woodchuck789
  • 4066 Answers
SOURCE: Side by side Magic Chef refrigerator. Freezer
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Could also be begining of a defrost problem.
Posted on Jul 09, 2009
  • 16 Answers
SOURCE: bottom of refrigerator not getting cold enough
have you cleaned out the coils underneath the fridge? it's very simple. pull the fridge out, look underneath(try pulling off the bottom grill from the front for more access), and start cleaning. to much dust and lint will hinder the coils from cooling. A vacuum with the brush attachment or little broom works good.
Posted on Jul 27, 2009
IC MAKER WORKS BUT NO WATER OUT OF WATER DISPENSER?
There are two sides to the Dual Water Control Valve. The ice maker side is still working but the water dispenser side is possibly defective. Sea Breeze Model Number?
Magic Chef Refrigerator Parts
Dec 15, 2013 | Magic Chef Refrigerators
Dripping water bottom front of refrigerator
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Jun 07, 2010 | Magic Chef CTB1722 Top Freezer...
Ice maker odor along with ice cubes smell
Try replaceing the water filter first thing you can get at most appliance parts store or sears or any appliance store. Thish should fix your problem.
Feb 05, 2010 | Magic Chef CTB1722 Top Freezer...
We have a Magic Chef CTB177GR refrigerator (no ice maker hooked up) that leaks...from where I don't know. I took off the lower back cover, it is dusty but no water present there. I pulled out the crispers...
Good day.
Water can only come from one place, where the frost is melted off the coil in the freezer during it's normal defrost cycles that occur daily.
Two styles. One style allows this condensed water to run down the back wall of the inside of the refrigerator, under the crispers and thru a hole in the bottom of the cabinet into a drain pan positioned
under the hole.
Possible missing pan, not positioned properly, or crack in the drain pan itself.
The other style drains the water to a hose mounted on the back of the machine, down and then into the pan.
Possible hose blocked, not connected properly, or the other items as described in first style.
It's a look-see type of repair.
Nov 17, 2009 | Magic Chef CTB1722 Top Freezer...
Apr 07, 2009 | Magic Chef CTF1826AR Top Freezer...
Refridgerator leaking water
You will have to check the defrost drain in the freezer by removing either the back or bottom of the freezer . Thaw ice if found in freezer and check to see if the drain hole is clear. Do not use anything to chip at the ice. Clear ice by warming it with warm water or possibly a hair dryer.
Jun 26, 2008 | Magic Chef CTF2125 Top Freezer...
Water squirting from ice maker
Aug 25, 2007 | Magic Chef (CSD2610KRW) Top Freezer...
Magic Chef CTB1722 Top Freezer Refrigerator Logo
Top Magic Chef Refrigerators Experts
evans_lloyd
Level 1 Expert
John Tripp
John Tripp
Lawrence Oravetz
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
