Connection Wi-fi won't work, How do i fix it?
    New Friend:
  • 6 Answers
  • Step 1 check all connections, and make sure they are in right position and well connected
  • Step 2 turn off the power of both router and modem. (unplug the power supply). Sometime the modem has battery in them as the back up power, then you need to find the reset button (use a pen) and push that button.
  • Step 3 wait 3 minutes.
  • Step 4 turn on the modem(if it does not have battery in it)
  • Step 5 wait 3 minutes.
  • Step 6 Turn on the router.
Hope this will hlep!
Posted on Jul 09, 2013
Dynex blu-ray wi-fi disconnects after 1 hour
The issue is with the chip that works with the wi fi. It is erratic in operation. Too expensive to fix. Can you just hook it up via ethernet cable for internet connection?
Sep 07, 2017 | Dynex™ Televison & Video
Kindle accuweather won't connect to wi-fi, all else will
You may need to do a hard reset, I am seeing in other forums the same issue with individual apps not connecting when others do and in all cases a hard reset seems to be the fix.
Jan 27, 2013 | Belkin Computers & Internet
Wi-fi won't connect, how do I fix it
have you had a fire or burglar alarm fitted recently? the signal emitted (even when off) can scramble the wi-fi.
Aug 06, 2012 | Apple iPhone 4S
I can't get it on internet, When I click on the web it says no connection
To get on the internet, you'll need Wi-Fi. Presuming you do have Wi-Fi, go into the 'Settings' application on your iPhone, at the very top you'll see 'Wi-Fi', in that section you'll see a list of networks that can be found, pick your connection and then enter any information that it asks such as security password for your network.
Sep 14, 2011 | Apple iPhone 4 Black Smartphone
How to activate wifi of myphone tw8?
In order to work (both when registering and dialing), your iPhone will need to make a data connection to the RingFree servers. Wi-Fi, though not always available, of course, is your best choice.
To enable Wi-Fi on your iPhone:
  1. Go to the Home screen by pressing the Home button or by unlocking your phone.
  2. Touch the settings incon
  3. Look to the right of the Wi-Fi icon. If a Wi-Fi network is listed, you're all set. Otherwise, select the Wi-Fi icon.
  4. If Wi-Fi is "OFF", touch the Wi-Fi toggle to turn on Wi-Fi.
  5. Then select a network (if one is available) from the list that appears on the iPhone.
  6. When connected via Wi-Fi, you'll see a striped upside-down triangle to the right of your service provider's name on the upper-left corner of the iPhone. If there is no network available, you'll have to use the EDGE network.
i hope it will help you for further query feel free to contact.....waiting forward for your reply.....
Aug 09, 2011 | Cell Phones
How do i connect to the wifi
If you need to connect your HTC Wildfire to a Wi-Fi network then check out this simple, step-by-step user guide to getting connected wirelessly
If you're using your HTC Wildfire for the first time, you can easily select the Wi-Fi network you'd like to join using the setup manager.
When you opt in for either Mobile Network or Wi-Fi, or just Wi-Fi, the Wildfire will by default try to connect to a Wi-Fi network near you.
Select the network you wish to connect to, enter the password if required and you're set up.
If you want to change the settings, or set it up for the first time, you can do this through the Settings menu.
Note: If you're attempting to access a network-based page or app, you may be required to set up a new Wi-Fi connection. When prompted, select the option to set up a new connection.
  1. Access the Wi-Fi settings menu by navigating to the Wireless & networksmenu
  2. Select Wi-Fi settings
  3. Choose a listed network, or add a hidden network by selecting Add Wi-Fi network
  4. If you choose one of the listed networks and it's secured, enter the password, press Connect and you'll be connected to that network
  5. If you wish to access a hidden network, select Add Wi-Fi network and enter the SSID
  6. If a password is required, you'll be prompted to enter this before connecting
If Wi-Fi is turned off, you can now turn this on by ticking the box in the Wireless & networks menu.
links that may helphttp://www.htc.com/uk/howto.aspx?id=3381&type=1&p_id=316 http://www.knowyourcell.com/htc/htc-wildfire/wildfire-guides/487458/how_to_set_up_a_wifi_connection_on_the_htc_wildfire.html
Jul 28, 2011 | HTC Wildfire Cell Phone
I have the GT 15510M samsung phone, howdo i connect to the internet from my wireless at home?
Your mobile has a built it Wireless Fidelity or WI-FI module enabling to catch ata over wireless networks.
By turning ON your wi-fi, it will search wireless network along the nearest location of yours. Once you found a network(s), just open it and wait until established and connected,but some authenticating connection never allows you to connect because it needs a password encryption.so you won't able to patch the network if you do not know the code.
If you have a broadband installed at home, you need a wireless router that can supply internet connection using your mobile phone via wi-fi,just easily series the broadband connection thru a wireless router and also add encryption like WEP key to ensure you are the only one catching the connection.
please state your broadband if any so that i can guide you the procedure in installing your wireless router connection.
If you have some questions, don't hesitate to reply cause i will glad accomodate any comments.
Thank you for visiting FixYa..
Jul 03, 2011 | Samsung Star GT-S5233 Cell Phone
How do i upgrade my htcp3300 so i can use the internet
Your phone is a Windows Mobile 5 device with wi-fi and 3G WAP capability, so does not need upgrading to use the internet.
You can browse the internet a free public wi-fi hotspots. If you want wider web availability, then you need to arrange a data connection with a service provider which you'll need to pay for. If you stay with your current service provider then they will either send you a new SIm or will send the necessary updates directly to your current SIM.
However, from direct experience of my old HTC P3600 which used the same O.S. and had similar specifications, you will find that using the internet is painfully slow and that many pages simply will not work at all. You also won't be able to use any useful modern apps and social networking sites will be totally unsuited or unacceptably awkward to use on your phone.
I'd therefore strongly suggest that you try the wi-fi option first to see how you get on, and if you like it and consider paying for a data connection to bear in mind that in a hotspot you'll be enjoying a far faster experience than you will when using a good 3G connection on your current handset.
Jun 30, 2011 | HTC Cell Phones
Internet connection does not work on my phone LG cookie. teach me how to open it.
jus b clear whether ur cells internet connection is not workin( gprs ) or wi-fi.... if its wi-fi, then u have to save ur wi-fi settins b4 usin it... not lyk laptops cells dnt get settins automatically... u cant use unknown wi-fi without knowin its settins........
Apr 08, 2010 | LG KP500 Cookie black on T-Mobile U-Fix...
Computers & Internet Logo
288 people viewed this question
David Payne
David Payne
