Sylvania 7" portable dvd player...Does this piece
Sylvania 7" portable dvd player...Does this piece suppose to be attach to something...
SOURCE: DUR-7 portable dvd player battery life?
Wal-mart does sell replacement batteries. http://www.walmart.com/catalog/product.do?product_id=2350787 For this particular unit. However; in the future I would suggest researching a particular item before buying esp from Wal-mart. As Durabrand doesn't even have a website.
Posted on Dec 04, 2007
Benimur
  • 6966 Answers
SOURCE: Durabrand DUR-7 portable DVD player
Most DVD players that would display such a message even with a known good disc inside signifies that the that the laser eye/lens is not reading the disc. This could probably be attributed to:
1. dirty, damaged, inverted, blank, un-finalized burned CDs or DVDs;
2. defective, weak burned-out laser eye/lens;
3. defective slider shafting (where the laser eye's carriage moves.
A few things you can try:
1. Use a CD cleaner (readily available from most computer shops);
2. use a can of compressed air and blow through the inside of the loaded disc area;
3. gently tap on the top cover where you estimate the reading/laser eye/lens would be;
4. gently press on the tray door once the disc is loaded.
Should this not be corrective, perhaps your best bet would be to seek the services of a qualified professional such as those in a Service Center. Alternately, your friendly neighborhood electronic shop should do just fine.
Hope this be of some help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kindest regards.
Posted on Feb 10, 2008
  • 3 Answers
SOURCE: Polaroid PDX-0073 7 LCD Portable DVD Player
Hello
I had that problem, the problem is that where you put the disc (the black Circle) tends to get a bit loose so it moves downwards.
so the distance between the lens and the under surface of the DVD / CD is reduce, so the beam is NOT return to the lens.
The way I fix it is by pulling the black circle EXTREMELY carefully and SLOWLY while you are turning it.
Once is out, with a toothpick or a needle put a small amount of crazy glue in the inner walls of the hole that is in the center ( where the pole of the rotor goes in) this way the hole is reduce.
Wait till it dries, then gently put it back in, it will be a tight fit, IT MOST NOT GO ALL THE WAY IN!!!
By this i mean that you will see the pole of the rotor go into the hole, but it most not reach all the way, it should be below the surface. The distance between the end of the pole and the surface of the black circle should be THE THICKNESS OF THE BLACK CIRCLE.
The way to know that the distance is right, put in a CD and play some songs, then try it with a DVD.
If it reads no disc it means you inserted the disc to much, pull it out a bit, then try again.
Once it reads both CD and DVD, fill in the hole with a drop of crazy glue, this way the black disc will not move anymore.
One more thing, I do not recommend to use alcohol in the lens, 'cause some lenses are now made of polymers non resistant to abrasive, instead use a cue-tip (cottonete, little pole with cotton to clean your ear) moistened with bottle water or distiled water.
Note MOISTENED not soaked or wet.
Hope it works for you.
Best Regards
Luis.
Posted on Dec 29, 2008
SOURCE: My portable dvd player won't load any dvds anymore
lachallep,
The solution for your problem will be needing a little knowledge with electronic repair and hands on.Most common problem for portable DVD player is their 1) Spindle motor the 2) flex cable ( tin ribbon wire connecting the optic lens and the main board)
note: to check if your spindle motor is working good, you must measure it's resistance and it should be around 200ohms.
For the flexcable all you have to do is check the continuity.
cheers.
mark
Posted on Jan 16, 2009
SOURCE: Curtis portable DVD player parts
You can find ordering information for the adapters (among other parts) from the Curtis International website at:
http://curtisint.com/support/faq.asp
Posted on May 07, 2009
My 9" Coby V.ZON TFDVD9109 Swivel Widescreen Portable DVD Player won't charge but will turn on and stay on as long as I have a charger hooked up what can I do about that
Coby TFDVD9109 9-Inch Widescreen TFT Portable DVD ...
www.amazon.com/Coby-TFDVD9109-9...Widescreen...
Amazon.com, Inc.
Rating: 3.6 - ‎52 reviews
Sylvania 9-Inch Swivel Screen Portable DVD/CD/MP3 Player with 5 Hour ... has never been easier with the Coby TFDVD9109 9" Portable DVD Player. .... The DVD player finally stopped working, won't load discs anymore, gives error message. I had a ... I'm currently doing my research for a new a player but likely will end up ...
Coby TFDVD7009 7-Inch Portable DVD/CD/MP3 Player, Black
www.amazon.com/Coby-TFDVD7009...Portable-Play...
Amazon.com, Inc.
Rating: 3.7 - ‎240 reviews
Ac Power Adapter Cord for Coby Dvd Players Tfdvd1029 Tfdvd7009 .... So in my case 5 zone is needed and it worked well. ... There is inconvenience in charging. ... that once you unplug the battery the connection is so cheap that it won't reconnect. .... Sylvania 9-Inch Swivel Screen Portable DVD/CD/MP3 Player with 5 Hour ...Missing: tfdvd9109
Coby Electronics TF-DVD7006 7-Inch Widescreen TFT ...
www.amazon.com/Coby...DVD7006-Widescreen-Port...
Amazon
Jan 10, 2016 | Coby Televison & Video
Why wrong region code for portable sylvania dvd player
Region code can be changed. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Jul 17, 2014 | Sylvania SDVD7015 7 in Portable DVD Player
My dvd player starts the movie over every time I turn the car on. Previous reviews said it would start back where it stopped. the manuel gives no information on this. Help!
Hi Arlene,
I checked Amazon for this player and looked at the questions and reviews. As luck would have it, I found this:
Q: dvd player: Does the Sylvania SDVD8791 dvd player remember where the movie stopped?
A: No, It's starts the movie over everytime the player is turned off.
So it appears that at least one other person is having the same experience as you are having. At first, I thought if you had it wired wrong it would "forget" but since it is portable and lacks batteries - that wouldn't be the case. For these same reasons, I can't imagine how a player can remember the location on a disk if power is removed from it. In any case, I doubt there is anything wrong with the player, it simply doesn't function as you were erroneously told or as hoped. When in the car, you should probably tell those watching to note the location on the disk before shutting off the car.
The Amazon link I used for my reply can be found here: http://www.amazon.com/Sylvania-SDVD8791-7-Inch-Mobile-Portable/dp/B004QGXWS6
Apr 07, 2014 | Sylvania 7" Dual Screen Portable DVD...
SDVD8732 7-Inch Dual Screen Portable DVD Player not displaying picture on screen
On one or both? Take a flash light and look close at the screen while playing something. If you can see the picture on the screens then it is a back light problem. They are not easy to repair.
Sep 05, 2013 | Sylvania SDVD8732 Player
Sylvania SDVD7027 7-Inch Portable DVD Player won't read DVD
The DVD player maybe faulty and it could be still under warranty.
Take it back to the shop where you bought it to have it repaired ot replaced under warranty.
Oct 22, 2012 | Curtis Sylvania Sdvd7027 7-Inch Portable...
WHY MY PORTABLE DVD WON'T PLAY
It won't play for one of two reasons:
1. There is something inside the DVD player, which keeps it from playing.
2. The DVD player's battery has run out of juice and can no longer play, meaning the player needs to be replaced.
Aug 06, 2012 | Curtis Sylvania SDVD7037 7-Inch Portable...
I have a Sylvania sdvd7015 that had the 120v wall adapter cord crack and short out while a DVD was playing. The screen stopped playing and gradually faded to white and then went black. The car charger...
I have serviced a lot of portable dvd players, when the adaper shorts in the manner you describe it usually takes out the pcb board making it not cost effective to repair, far cheaper to replace the whole unit.
Sep 20, 2011 | Sylvania SDVD7015 7 in Portable DVD Player
I just bought a new SCVC1023 yesterday and have played several dvd's and the images of moving people leave "tracks" behind them on the screen. Even something as simple as someone on the...
Tries every setting on the player auto,see if it help?No,this portable player have foggy laser eye len data reader,require cleaning.But this is a new bought one return it and exchange it for another one.
May 27, 2011 | Sylvania SDVD1023 Player
Televison & Video Logo
Top Televison & Video Experts
