Canon ir 3300 e 0064 error in double sided copies
SOURCE: canon ir 400 photocopier
Apr 19, 2009- Press additional functions
press #
press + key until display reads #7 printer
press set
press + key until display reads #4 printer reset
press set
press - key for yes
unplug copier wait a minute and plug it back in
This resets E-000 codes maybe that will help
Good luck
I found this on someones elses solution maybe it will help you...
Posted on Aug 24, 2009
goodgold
  • 389 Answers
SOURCE: Canon Ir 550 E020 error
When the scanner motor is started up, the BD input signal does not arrive within a specific period of time.
When the scanner motor is started up, the motor rotation is too fast, and fails to reach a specific revolution within 20 sec at time of deceleration.
While the scanner motor is rotating at a specific speed, the BD input signal cycle is not within a specific range (±2%) for an equivalent of 10 mm (print distance).
While the scanner motor is rotating at a specific speed, the BD input signal cycle is not as indicated (±2%).
During the WMUPR period after the power switch has been turned on or the front cover/left cover has been opened/closed, the drum unit is absent.
Possible cause: The wiring is faulty (short circuit, open circuit). The laser scanner unit is faulty. The DC controller PCB is faulty. The drum unit is not installed.
Posted on Sep 20, 2009
PATHAMPAD
  • 25 Answers
SOURCE: Printing double sided color copies.
CHANGE YOUR DUPLEX PAPER SELECTION MOTOR
Posted on Oct 31, 2009
SOURCE: Describe your canon ir 400 xerox machine error
i have duplexing problem
Posted on Jan 11, 2010
SOURCE: canon IR 2020 showing system Error E007 printer
my canon ir2020 is displaying system error E007
Posted on Jul 20, 2010
IR 2270/2870g photo copy machine ,paper jam at the time of double side copy
Clean the vertical path rollers .they are located in the right door. check for obstructions. inspect your right door for broken parts and missing pressure springs that keep pressure on those vertical rollers. Make sure the right door is shut firmly.
Apr 11, 2014 | Canon Ink Cartridge GPR15 for iR 2270, iR...
Hello , i have cannon IR 2270/2870g photo copy machine ,paper jam at the time of double side copy
There might be an issue with the feed clutch or fuser. It depends on where it jams in the machine.
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_7148ad2a373711a3
Sep 27, 2013 | Canon Ink Cartridge GPR15 for iR 2270, iR...
Open your developer unit and check sensor , refix it an close unit see........your problm solved
Apr 22, 2013 | Canon Ink Cartridge GPR15 for iR 2270, iR...
DOUBLE SIDED COPYING
First normaly copy first side, then take copied paper and set it in bypass tray, when you do thath, the copier ask you for paper size and type, choose correct sett. and confirm with OK.The side on wich you want to print must be face down in bypass tray.
May 11, 2010 | Canon iR 1600 Laser Photo Printer
Sep 17, 2009 | Canon imageRUNNER C3200 Copier
Canon IR 2020 showing system Error E007 printer
Jun 16, 2009 | Canon iR 2022 Printer
How to make automatic duble sided copy on IR-2000
these machines have a duplex unit all machines this size does, now a duplex unit is where the paper double sides in the machine, like doing a double sided copy.
i know off some people think that a duplex unit is the DADF (document feeder).
May 31, 2009 | Canon imageRUNNER 5570 Copier
Steps to make an automatic double sided copy
Hello sir; That is depend on your machine have duplex unit or not if doesn't come with duplex unit you can not do it.
May 30, 2009 | Canon imageRUNNER 5570 Copier
How to photocopy double sided A4 sheets?
you copy first side normaly. then on left side open bypass deck.Put the paper, so that the side on wich you want to print is down. Automatically when you put paper in bypass, the machine ask you wich format is it ( eg. A4 ), confirm with OK, then you need to tell machine wich type of paper ( eg. plain paper ) and OK. then green copy key.
May 02, 2009 | Canon iR 1600 Laser Photo Printer
CANON IR 2000
Canon iR1600/2000 not a double-sided copying machine. Can print one side then reverse copies in paper cassette and copy side 2 onto it.
Jan 31, 2007 | Canon imageRUNNER 2000 Copier
74 people viewed this question
k24674
jasbo
jasbo
