Question about Samsung DV220AEW Dryer
I'm getting a TE code
    Top Expert:
  • Samsung Master
  • 12,223 Answers
Is possible eeprom failure, you must to replace or call to the service.
God bless you
Posted on Jul 10, 2013
I'm getting error code tE on samsung silvercare WF316LAS/XAA
tE is mostly related to
temperature sensor wire and connection problem. Look for a broken or loose wire.
Dec 07, 2012 | Washing Machines
J'ai un code bios k j'ai oubler
Fixya refuse les reponses en langues etrangeres. C'est pourquoi j'ai supprime les accents. Peut-etre que la reponse passera.
Dommage, parce qu'il te faudra envoyer l'ordinateur ou le porter a un centre de service de Toshiba pour effacer le mot de passe. Tu devras peut-etre prouver que l'ordinateur t'appartient. Et il est certain que tu devras debourser de l'argent pour le service, si ton ordinateur n'est plus sous garantie.
Essaie plutot de te souvenir de ton mot de passe.
Jun 26, 2012 | Toshiba Computers & Internet
Error code te
"te" error code is caused by a faulty thermistor; likey cause is:
a. Loose wiring at the control panel (directly behind the cycle selector knob)
b. Broken wire at the thermistor (located at the bottom/front of the tub)
To access the wire plug connectors at the control pannel, remove the top cover of the washer. Stand in front of the washer and look for the plug connectors behind the control panel. Pull apart the plugs and re-install.
Test the washer. If the "te" error still occurs it will be neccesary to remove the front panel as well (two sets of special plier-type tools are needed).
Inspect the thermistor closely, with good lighting. If there's a break in the wire it will be at or near the black sheathing / heat shrink material.
Hope this helps and just keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa.
Nov 01, 2011 | Samsung WF337AA Front Load Washer
I get a tE error code and the machine shuts down. What is it telling me? How do I troubleshoot and fix it?
LG's 'te' stands for 'thermostat (heating) error'.
One way of hopefully getting around the problem is first to ensure the washer is empty then pour the contents of a boiling kettle into it. That can sometimes kick the device into correct action. It's worth a try anyway before having to call in the repair man ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Aug 30, 2011 | LG WM-2277HW Front Load Washer
I have an washe - LG Tromm model # WM2277HB - and I am getting the error code te. What part do i need to repair this problem?
'te' on LG's normally means Temperature Error- a heating element problem. Sorry but I suggest you need to call out a service engineer to attend to it ;-0(
Good luck,
John C
Mar 05, 2011 | Washing Machines
Malfunction code tE
TE error code stands for thermistor error. You have to remove the front panel and ohm out the heating element. If you have continuity most likely it will be fine. There is a thermistor located next to the heating element that will probably need to be replaced. LG's are the only machine besides GE ref's that I have ever seen thermistors go bad on. There is probably an ohm reading you should get through the thermistor but unless you have an analog meter or a fluke most standard digitals wont read into mega-ohms. Removing the front panel is model specific. But i can tell you the spring around the front boot (drum gasket) needs to be removed and there will be some hidden screws at the bottom by the pump where the access panel is located.
Hope this helps _MJ_
Jan 31, 2010 | LG WM-2277HW Front Load Washer
MC909X Barcode types
found someone in the whs that knew what to do
Nov 19, 2008 | Zebra Symbol Technologies MC909X-G Series...
Samsung DV220AEW Dryer Logo
126 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
