Question about Peerless Industries Peerless& Single Handle Tub & Shower Faucet
How do I disconnect the pull down hose?
I need to move the faucet to another sink. I installed it yesterday and the pull down hose just snapped together.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 101 Answers
If you were able to snap the water lines from shutoffs onto the faucet with a click, look for a small wire clip inserted into the lower/outer half of the joint. TURN OFF THE WATER, then remove the wire clip carefully and the water supply lines should come back apart. the little wire clip goes back into the slot for safekeeping till next time .
Posted on Jul 22, 2013
How to disconnect sprayer hose on kitchen faucet?
Turn off the water supply valves beneath the kitchen sink. Turn on the faucet and squeeze the trigger on the sprayer to empty any water left in the supply lines, faucet and sprayer.
Trace the sprayer hose from the end of the sprayer to where it connects to the faucet. Use pliers to loosen the connector holding the sprayer hose to the faucet.
Remove the sprayer hose from the faucet to expose the male threads. Wipe the threads dry with a towel. Wrap the threads with pipe-joint tape. Twist a 3/8-inch threaded brass flair cap onto the male threads. Use the pliers to tighten the cap.
Reach beneath the sink and loosen the mounting nut securing the sprayer support to the sink or countertop. Use a basin wrench if you are unable to reach the mounting nut with your hand.
Slide the mounting nut off the hose attached to the sprayer beneath the sink. Pull the sprayer support and the sprayer from the hole in the sink or countertop.
Insert a sink hole cover into the hole left by the sprayer. Depending on the style of hole cover, it could snap in, or a mounting nut could hold it in place.
Things You Will Need
  • Pliers
  • Towel
  • Pipe-joint tape
  • 3/8-inch threaded brass flair cap
  • Basin wrench
  • Sink hole cover
Dec 01, 2017 | Plumbing
Brand new kohler cruette. attached cold and hot water fine. when snapping in the pull out faucet hose it sprays all over under the sink
Hi rysenga, the problem is an omission of directions. The section 9 directions are the worst offender and left me never again to purchase a Kohler product. First, this connection for the pull out hose to the outlet fitting should have been a screw on connection. Should have been. Ok it was not, I'll get over it. But the directions never mention having to install the white plastic bushing. Not at all. Nor does it mention that the bushing should be put on the outlet first and then push the hose connection in. This omission is a huge one, but should help anyone else reading this complete the install. Find the oval lip white bushing and install this first on the body, and then just push the connector in. Done.
Sep 02, 2012 | Kohler Plumbing
I have an American Standard kitchen faucet aqua source model no. 5913100075. It comes with the sprayer hose inside the faucet. I have a double sink. I would like to know 'do you hold on to the faucet...
pull it out as far as you need. You will not hurt anything just dont try to wash the car its not that long
I have my spout in the middle and I pull out all I need to clean out both sidees it works just fine
Thanks Richard
Sep 07, 2011 | American Standard Plumbing
Have Kohler diverter, GP 75878 but no instructions as to how it should be installed. Is it under sink where sprayer hose is attached?
Shut off water supply Under Sink: · Unscrew brass connector for spayer hose · Disconnect single water line to faucet bysqweezing lever on connector and Gently pulloff. · Loosen two screws on faucet base washers thenunscrew the washers on thebrass faucet shaft ( NOTE: Have someone hold the fauct so it does Not accidentlyfall in sink when the support washers are removed) · Take faucet out of sink · Unscrew brass collar at base and remove · Remove Set Screw on lower body of faucet · Pull out Brass Mechanism from faucet · The Diverter is located in the Brass mechanism · Remove the Washer · Pull off the small top valve in center of theDiverter, if still there · Using a large wood screw that fits/screw intothe exposed hole In the center of The plasticdiverter, screw it in and pull out the remaing part of the old diverter · Flush out Faucet to remove any remaining debrie · Replace with new diverter and replace washer · Grease all areas that where greased when mechanismwas removed Remove & clean the faucet Airrater and replace only afterEVERYTHING has been Completed soyou can flush the faucet out again into the sink, then replace.
Dec 20, 2010 | Kohler Model 10430: Fort® Single-control...
The O rings need to be replace, but you can not get the handle off because if the hose. How do you disconnect the hose so you can remove the handle.
handle should have an allen screw rite under the handle coverd by a little cap mite have red and blue..shouldnt have to take hose off but that just snaps off from under sink.
Nov 21, 2010 | Delta Faucet Delta 470-BL-DST Signature...
How do I remove the spray hose from the brass connector under the sink?
On the side of the brass there should be a clip or a pin that you can pop off... a knife or screw driver will work to snap it out of there... then the hose will just pull down out of the fitting...
heatman101
Sep 03, 2010 | American Standard Kitchen Faucet 6310 020...
I have a Kohler Forte Single handle faucet, and I'm seeing leaking down below the sink in the cabinet. I tried reconnecting the Kohler piece to where the water comes out, but now it's even worse. It looks...
Turn off your water supply to the sink the disconnect the supply lines to the faucet. Reconnect supply lines making sure to use plumbers pipe joint compound of teflon tape. I've found teflon tape to be better. When installing the supply lines make sure that the threads aren't crossed and the retaining nut is snug.
Mar 12, 2010 | Kohler Model 10433: Fort® Single-control...
Grohe ladylux plus kitchen faucet leaks from multiple points along metal pull out hose attached to faucet head. Is this fixed by replacement of same hose? How do I replace the hose?
Yes,it sounds like you have to replace the hose.Follow the braided hose under your sink until you come across a yellow and black fitting . it is comparable to an air hose fitting quick disconnection. once that is pulled from the sink port,unscrew the spray head and pull the ose through the faucet body from above the sink
Feb 23, 2010 | Grohe Plumbing
Grohe faucet handle doesn't retract
Ok well that is probably the install then.  there is a brass ring under the sink that is holding the faucet tight to the sink.  this has 2 water lines that feed the faucet and the line to your spout.  if the copper lines are not pushed apart enough than it will rub one the line with the weight and make it hard to move up and down. you need to get under it with a flash light and move these lines apart.  The worst  would be that when the faucet was installed the hole was not big enough and that is what it is hitting.  So I hope this help you .
Jun 23, 2009 | Grohe 32 999 KD0 Alira Pull-Out Spray...
The pull out faucet is loose, wobbly, won't stay attached.
Make sure that there is a weighted ball connected about halfway down the retracting hose. If not you need to go to a supply house and purchase one and its a simple install.However if there is one attached you can loosen the 2 screws and slide it up closer to faucett but not so far that you can't pull out the sprayer as far as you need. Also make sure nothing is obstructing it under the sink. bottles, cleaners, etc.
Jun 04, 2009 | Grohe 32 999 KD0 Alira Pull-Out Spray...
Peerless Industries Peerless& Single Handle Tub & Shower Faucet  Logo
70 people viewed this question
Top Peerless Industries Home Experts
Joe Lamb
Joe Lamb
john h
Steve Wood Plumbing...
Level 1 Expert
Are you a Peerless Industries Home Expert? Answer questions, earn points and help others
