Question about IBM Computers & Internet
Motherboard speaker pin out - IBM Computers & Internet
  • 3,799 Answers
Look at the manual provided on the motherboard makers website. It is in the support section.
Posted on Jul 10, 2013
I was wondering can the pin code be broken to these speakers?
The pin assignments are in the manual to most motherboards.
The pin will be called Line Out Right for the right speaker, and Line out Left for the left speaker.
Or something similar.
Both returns go to the same ground.
Aug 01, 2015 | Computers & Internet
I cannot understand where to connect the speaker slot in my intel ZX-I945LM4 motherboard please help.....
Good day
you can find the sulotion in your motherboard manual.. what kind of speaker slot?
the speaker for mother board is 2pin
1st find the reset/led/on pin
2nd you can see the speaker slot..
May 24, 2011 | Intel Motherboard
How to connect the front penal with motherboard
Hi.
To connect the front panel of your case with your motherboard, it is quite easy.
If you have the motherboard manual, I will help you on connecting the cables to the motherboard.
In summary, the pins or connectors for the front panel are on the same spot of the motherboard.
If you don't have the manual, check on the motherboard, THere are like 8 or 10 pairs of pins which are labeled.
The speaker cable is a 4 pin conector. See the speaker's pin on the motherboard.
The Power cable will fit into a 2 pin connector.
The HDD Cable as well
The reset. too..
The colored cable is always +, the black cable is always -
The + usually goes on the first pin of the assigned connector.
For example: motherboard connector is:
The cables goes on the Jumpers area.
You will see somthing like this:
Hope that helps
God Bless You!!
Remember to rate this solution!!
Feb 21, 2011 | Intel Motherboard
How to connect small case mounted system warning speaker
Either ground (probably the one next to the "speaker) and the Speaker. ignore the other two. Ground to neg and Speaker to Pos.
Mar 14, 2010 | ASUS M4A785TD-V EVO Motherboard
Connection of inbuolt speakers on motherboard..
Dear User,
Pl Take Your Motherboard Make and model no with its diagram.
(1) Diagram contains inbuilt speaker pin where to connect wire.
(2) Anoter way please see on your motherboard small pin when wire hang. Read Carefully around pin in small latters for speakers pin.
Feb 26, 2010 | MSI K9MM-V Motherboard
Sound cable connection
Look more closely at your motherboard, for a 4-pin "PC Speaker" label.
The "HD Audio" is _OUTPUT_ (left front, sub-woofer, right front, left back, right back) to Surround Sound speakers.
Dec 31, 2009 | Foxconn (945G7MA-8KS2) Motherboard
Pluged in pwr and restart and hdd led but where is speaker plugin?it is 4 pin but only has 2 wires either end
speaker connectors are strange on most boards. They tend to be 4 in line pins but only the two outer ones are used. So you will see
0000 pins shown for the speaker connector but the only ones you use are the x's - X00X or the two end pins.
Jul 30, 2009 | PC Chips M825G Motherboard
How to connect the front panel sould device?
Do you mean speaker or front panel audio? The front panel audio connector is located at the rear of the board, behind the PCI connectors - the speaker connections are in the panel connector block (2x10 pin header) located at the front left of the board.
With the board in it's normal position, the speaker pins are on the right hand side of that block, on the pin nearest the front and the one 3 positions behind that
<back of board>
| HD LED + | | Power LED +
| HD LED - | |
| | | Power LED -
| Power SW | |
| Power SW | | Speaker
| Reset SW | |
| Reset SW | | Speaker
Front of board
Jul 03, 2009 | ASUS K8V-MX Motherboard
Connecting Speaker
Dear Big Timmo,
To connect the Speaker Pins u have to check left or right side of u r mother board where u r power wire, reset wire and Hard disk led wire connected to the mother board. it has 12 or 13 male pins. There u will find in writen speaker in the motherboard. I hope now u can connect u r speaker pins..
Regards,
Bittu_8
Feb 15, 2008 | Intel Desktop Board D845GERG2 Motherboard
Computers & Internet Logo
18 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
