SONY VGN-T240P TURNS ON GOES BACK OFF
    Sergeant:
  • 429 Answers
Sounds like a bad battery.get it checked or replace it if necessary.
Posted on Aug 14, 2013
Sony VGN-FW41E not starting...
Power supply in the laptop may have went bad
Aug 27, 2012 | Computers & Internet
Sony Vaio Model VGN-FS640/W does not show having a battery.
The main battery needs to be replaced, or the charging ciruit on the motherboard is not working, remove main battery get a stiff toothbrush and clean terminals in the laptop incuding the battery, if no change! check the device manager to see if battery is present, if no! reset bios to factory default.
Mar 26, 2012 | Sony VAIO VGN-FS640W Notebook
Sony VAIO VGN-CS110E won't boot
yes it is the problem you need remplace the mothersboard because lucks like your motherboard is damage
Nov 25, 2011 | Sony VAIO VGN-CS110E/Q PC Notebook
Describe your VGN-CS110E MODEL IS SHUTTING DOWN Problemi HAVE VGN-CS110E MODEL od sony now from today morning iam encounting thet when oi turn on my computers it turns on and in 5 min its shut it down...
You should send it to them, it absolutely sounds like the computer is overheating which would be the cause of a faulty fan. Make sure you back up all of your information prior to sending the computer out, as they won't hesitate to reset the computer back to its factory settings. Continuing to use the computer in its current state could cause more permanent damage to the computer, so back it up and send it out as soon as possible.
Mar 21, 2011 | Sony VAIO VGN-CS110E/W NoteBook
Vaio VGN-CR35 laptop not booting at all. When started, screen is blank and power led turns on, num/scroll/caps keys flashes once, battery and hard disk led turns on once and immediately goes to off....
This could be a sign that your laptop is overheating. If you touch the laptop while it is running & you find it too hot, make sure that the fan is running properly & that the air ways are not blocked.
You can blow compressed air into the cooling vents of the fan. If you notice clouds of dust coming out, then it might be a good idea to disassemble the laptop, clean the fan & air ways, & reassemble it back. If the fan has failed & is no longer running, it might need to be replaced.
If none of this solves the problem, or is not the case, then you might have a bad motherboard.
Sep 13, 2010 | Sony VAIO VGN-CR220E/P Notebook
Trying to replace the dvd drive in sony vgn-t240p notebook
You can refer the Service Manual for the VGNT series Models as all the Models have same Service Manual.
http://www.notebook-manuals.com/laptop-manuals/service_manual_for_SONY_VaioVGN_T350P_9e406957d4_VGN-T350P-manual-repair.pdf
Jun 06, 2010 | Sony VGN-T240P/L: VGN-T240P Intel Pentium...
Sony vaio VGN-SZ430N/B
I'd suggest ring back Sony support and tell them that your OS is Windows 7 - not Vista. Therefore, you need the upgraded VGA driver because the Vista driver is incompatible with Windows 7. Hope it all goes well. If my suggestion works for you, please do rate me. Thanks
Feb 04, 2010 | Sony VAIO Notebook
Power button pressed, doesn't boot
Try taking memory module out and then put it back in, or try using another memory module.
Nov 11, 2009 | Sony VAIO SR Series Notebook PC...
I have Sony Vaio Laptop. My computer turns on, i log in and it goes to a blank screen what do I do
Mine did this for awhile, i took it to geek squad and they said to do a system restore and that fixed the problem.
Dec 25, 2008 | Sony VAIO VGN-FE550G Notebook
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
