Question about Motorola Mobility Elite Sliver HZ750 Bluetooth Headset - Black Original OEM 895
My Elite Sliver is fully charged but won't turn on
I just bought it last week and it worked and paired with my iPhone fine. Two days ago, when I went to put in on my ear, there was no signal when I turned the headset. I put it back in the charger, it lights up, is now fully charged and when I take it off the charger, NOTHING happens. No light, no action, no nothing.
  • 287 Answers
SOURCE: purple light
The purple (majenta) light usually means it is in pairing mode. Is it possible that the button is stuck pressed in??
PUT HEADSET IN PAIRING MODE
1. Ensure the headset is turned off (indicator light not blinking and headset boom is closed)
2. Press and hold the Call button. After about 4 or 5 seconds, the indicator light becomes steadily lit in magenta
3. Release the Call button and immediately open the headset boom. The indicator light remains lit in magenta.
If the indicator light is flashing in blue or not steadily lit when opening the
headset boom, repeat steps 1 through 3
Posted on Jul 03, 2008
SOURCE: Motorola H700 pairing
It's important to note that the pin has to be entered while the light is still violet. On the phone, begin searching for bluetooth devices. With the boom closed, hold the center button until the light turns violet, then immediately flip the boom open. The phone should immediately find your H700. However, to pair successfully, you must enter the pin (0000) while the light is still violet. If the light goes off, close the boom, enter 0000, and while the phone says processing, hold the center button until the light turns violet and flip the boom open. The light on your H700 will turn blue, then flash rapidly, and your phone should say that it has paired successfully.
Posted on Sep 14, 2008
SOURCE: Motorola Bluetooth HS850 Pairing Mode
This worked great for me... I got the headset in "pairing" mode by following these instructions. Then set my BB Curve 8350i to "discover" bluetooth devices. It discovered the headset and asked for a PIN number... one of the other articles I read said the pin was "0000" so I put that in and - PRESTO - it works
Posted on Jun 04, 2009
  • 5 Answers
SOURCE: Motorola bluetooth H270 solid blue light after pairing
I had the same problem. I plugged a USB charger into the headset and turned the power switch off. It worked as normal after that. I think it does not like to be "on" when the USB is disconnected. Anyway it seems the plugging/unplugging kick-started it.
Posted on Feb 12, 2010
  • 15 Answers
SOURCE: The pairing light on my HS850 soes not come on?
You have to start with the boom closed and press the large button with the phone symbol until the blue light comes on, then open the boom before the light goes out and you should be able to pair it with your phone.
Posted on Feb 28, 2010
My silver elite keeps reconnecting even when I have it in the off position
I was having the same issue. When it switches to off by turning the earpiece it will flash a blue light 3 times. carefully place it in the case but do not press down. use the lid of the case to close it all the way. Mine at least seems to stay off. before I was pushing it into the case and it would come back on even in the closed position. hope that helps you.
Jul 22, 2016 | Motorola Mobility ELITE SLIVER Bluetooth...
How do you pair elite sliver blue tooth with a i phone
Turn on Blueototh on your iPhone. THen follow instructions here: How do connect my ELITE SLIVER to other devices and then have iPhone search for Elite Sliver
Jul 11, 2014 | Motorola Mobility ELITE SLIVER Bluetooth...
Motorola HX550 headset goes dead after 30 minutes.
maybe a fault. Try charging it a lttle more n leave it on a bit longer? if not you may have a duff one so just take it back!
Feb 16, 2014 | Motorola Radio Communications
Iphone won't take a charge
I've looked for others with the same problem as you, and I haven't found anything.
I have a few things for you to try, they're rather simple so you may have already thought of them.
First thought, try a different iPhone to USB2 cord.
Try a different type of iPhone charging unit, i.e., car charger, wall charger, etc... Best way to gain access to the more options would be at an Apple Retail store, at least you'll know that the cord you're trying definitely does work.
If the iPhone does connect to your computer, but won't sync or charge, see if you can get it to "Restore".
If you can't get it to recognize your iPhone at all, take it to an Apple Retail store and have them play with it at the Genius Bar.
If you're feeling DIY, try cleaning the contacts on both your iPhone and its cord with some denatured alcohol on a Q-Tip.
If you would like to phone or email me, please feel free. Dan Crowley, 919.280.3101 iKnowApple.com
Aug 10, 2008 | Apple iPhone Smartphone
Will not turn on or charge
get warranty on that one.
Jun 23, 2008 | Jabra BT125 Headset
Help!!!
The battery not charging /
Dec 27, 2007 | Durabrand PDV-705 Portable DVD Player
Motorola Mobility Elite Sliver HZ750 Bluetooth Headset - Black Original OEM 895 Logo
381 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
