Str f6654 diagram
HIGH VOLTAGE
    Top Expert:
  • Televison & ... Master
  • 75,462 Answers
Check all the solder terminals to this Regulator IC, for any loose soldering. It will be best to resolder all the solder terminals to this IC, by applying a little more solder to each solder terminals, without making any solder bridge short in between adjacent solder terminals. Take extreme care when soldering procedure, as there will be dangerous voltages will be present, even after switch off the set. If you wish to get the schematic diagram for STR F6654, get it from the site linked here. http://electronicshelponline.blogspot.com/ Pull up previous posts there, either by its left side bar, or view it in Timeslide option. Surf the site with patience.
Posted on Jul 09, 2013
2 Suggested Answers
SOURCE: LG TV using STR F6654
main condencer charge no out put suplly
Posted on Apr 09, 2012
I have panasonic nn-gs597m microwave its working normal but not heating, I opened the cover magnetron is hot the fan is working. Any help?
follow the next steps , use the VOM and fix it. God bless you
Diode
The high voltage diode converts the A/C power output of the transformer to D/C, doubling the voltage to nearly 5,000 volts. This high voltage powers the magnetron which emits the energy that cooks the food. If the diode burns out, a lower A/C voltage reaches the magnetron, which is not sufficient to power the magnetron. When the diode fails it is often visibly burned out. If it appears to be good, it can be tested with a volt-Ohm meter capable of testing diodes. High voltage diodes frequently fail and are one of the most common points of failure in a microwave oven. A regular meter with a diode checker will not work to check these diodes. You have to use a meter with a 9 volt battery or put a 9 volt battery in series with the diode to check it.
Door Switch
If the microwave does not heat, one of the door switches might be defective. Microwave ovens normally have three door switches, if any of them fail the microwave does not turn on and does not heat. Check the switches for continuity with an Ohm meter.
Magnetron
If the microwave oven doesn't heat the magnetron tube might have burned out. The magnetron uses high voltage, high current DC power to generate the microwave frequency that cooks the food. If the microwave oven is turned on when it is empty this can cause the magnetron to burn out. Once it is burned out it has to be replaced, it's not repairable.
High Voltage Capacitor
If the microwave doesn't heat the high voltage capacitor might be defective. The high voltage capacitor works with the high voltage diode to convert the output of the transformer to DC voltage and to double the output voltage. If the capacitor is burned out the entire high voltage circuit stops working properly. The high voltage capacitor can be checked with a special VOM meter which has a capacitance testing capability. Be aware that the high voltage capacitor can retain a charge of more than 3,000 volts and can injure or kill a person if not handled properly. Only trained technicians should perform this type of testing.
High Voltage Transformer
If the microwave does not heat, the high voltage transformer might be burned out. Microwave ovens produce a very high voltage in order to power the magnetron antenna, which emits the energy that cooks the food. When a high voltage transformer fails it will usually arch and have a burning smell.
Thermal Fuse
If the microwave doesn't heat the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Thermoprotector
If the microwave doesn't heat the thermoprotector may have tripped. This is a safety device to prevent the microwave from overheating. It can be tested for continuity to see if it's blown.
Main Control Board
If the microwave doesn't heat the main control board may be defective. This is not common. When a microwave doesn't heat the problem is usually a faulty door switch or within the high voltage circuit; either the high voltage capacitor, diode, transformer or magnetron.
Jun 16, 2013 | Microwave Ovens
Hyundai santa fe 2001
Car error codes::
Diagnostic Trouble Code Storage Condition Remedy
P0100 Mass Air Flow Sensor Voltage High C-8
P0100 Mass Air Flow Sensor Voltage Low C-8
P0110 Intake Air Temperature Voltage High C-10
P0110 Intake Air Temperature Voltage Low C-10
P0115 Coolant Temperature Voltage High C-9
P0115 Coolant Temperature Voltage Low C-9
P0120 Throttle Position Sensor (TPS) Voltage High C-7
P0120 Throttle Position Sensor (TPS) Voltage Low C-7
P0130 O2 Sensor 1 Circuit Voltage High C-30
P0130 O2 Sensor 1 Circuit Voltage Low C-30
P0130 O2 Sensor 1 Open Circuit C-30
P0150 O2 Sensor 2 Circuit Voltage High C-31
P0150 O2 Sensor 2 Circuit Voltage Low C-31
P0150 O2 Sensor 2 Open Circuit C-31
P0201 Injector Valve 1 Voltage High C-20
P0201 Injector Valve 1 Voltage Low C-20
P0201 Injector Valve 1 Open Circuit C-20
P0202 Injector Valve 2 Voltage High C-21
P0202 Injector Valve 2 Voltage Low C-21
P0202 Injector Valve 2 Open Circuit C-21
P0203 Injector Valve 3 Voltage High C-22
P0203 Injector Valve 3 Voltage Low C-22
P0203 Injector Valve 3 Open Circuit C-22
P0204 Injector Valve 4 Voltage High C-23
P0204 Injector Valve 4 Voltage Low C-23
P0204 Injector Valve 4 Open Circuit C-23
P0205 Injector Valve 5 Voltage High C-24
P0205 Injector Valve 5 Voltage Low C-24
P0205 Injector Valve 5 Open Circuit C-24
P0206 Injector Valve 6 Voltage High C-25
P0206 Injector Valve 6 Voltage Low C-25
P0206 Injector Valve 6 Open Circuit C-25
P0230 Fuel Pump Relay Voltage High C-6
P0230 Fuel Pump Relay Voltage Low C-6
P0230 Fuel Pump Relay Open Circuit C-6
P0325 Knock Signal Circuit 1 C-26
P0330 Knock Signal Circuit 2 C-26
P0335 No Engine RPM Signal C-32
P0335 Incorrect RPM Signal C-32
P0340 Hall Sensor Voltage High C-15
P0340 Hall Sensor Voltage Low C-15
P0403 EGR Valve Voltage High C-28
P0403 EGR Valve Voltage Low C-28
P0403 EGR Valve Open Circuit C-28
P0410 Secondary Air Pump Voltage High C-27
P0410 Secondary Air Pump Voltage Low C-27
P0443 Fuel Tank Ventilation Valve Voltage High C-29
P0443 Fuel Tank Ventilation Valve Voltage Low C-29
P0443 Fuel Tank Ventilation Open Circuit C-29
P0500 Vehicle Speed Signal C-42
P0505 Idle Air Control Voltage High C-33
P0505 Idle Air Control Voltage Low C-33
P0550 Power Steering Voltage High C-14
P0550 Power Steering Voltage Low C-14
P0560 Battery Voltage High C-4
P0560 Battery Voltage Low C-4
P0602 Control Module Programming Error C-2
P1110 Intake Manifold Valve 1 Voltage High C-34
P1110 Intake Manifold Valve 1 Voltage Low C-34
P1111 Intake Manifold Valve 2 Voltage High C-35
P1111 Intake Manifold Valve 2 Voltage Low C-35
P1230 Power Supply Relay Secondary Circuit C-3
P1405 EGR Valve Feedb. Voltage High C-28
P1405 EGR Valve Feedb. Voltage Low C-28
P1405 EGR Valve Feedb. Incorrect Signal C-28
P1501 Immobiliser No or Wrong Coding C-5
P1502 Immobiliser No Signal C-5
P1503 Immobiliser Wrong Signal C-5
P1530 A/C Relay Voltage High C-41
P1530 A/C Relay Voltage Low C-41
P1600 Reprogram or Replace Electronic Control Unit (ECU) C-2
P1602 Knock Control Module; Replace ECU C-2
P1690 Check Light Voltage High C-43
P1690 Check Light Voltage Low C-43
P1690 Check Light Open Circuit C-43
P1740 Torque Control Voltage Low C-40
P1740 Continuous Torque Control C-40
These are the error codes:
Jul 08, 2008 | 2001 Hyundai Santa Fe
Code f-33
Step 1:
Symptom: Intermittent or continuous error code F33 on the display. Cause: Insufficient (poor) grounding of the controller (DP) board.Remedy: clean the groundHowever if Not Heating proceed with the next steps.
1)Diode
Door Switch
Magnetron
Thermal Fuse
Thermoprotector
Step 2:
Step 3:
Feb 07, 2013 | Microwave Ovens
Neff gmbh microwave on but not heating
Step 1:
follow this steps and test and fix it. God bless you
1)Diode
Door Switch
Magnetron
Thermal Fuse
Thermoprotector
Step 2:
Step 3:
Step 4:
Why is the microwave not heating the food, but the turntable is hot.?
Step 1:
folloq this steps and fix it. God bless you
1)Diode
Door Switch
Magnetron
Thermal Fuse
Thermoprotector
Step 2:
Step 3:
Feb 06, 2013 | Microwave Ovens
DEAD JUST STANBY LIGHT FLASHING AND HIGH VOLTAGE COMING AND COMING OUT A 1 SEC AFTER.
If the high voltage comes up and goes right down something in that area is either shorted , open or bad---only thing in power supply that could cause this is if the main voltage (130 volts plus to the high voltage area is HIGH---the high voltage will go excessive and shut the set down--xray protection.
Oct 25, 2012 | Toshiba 27A60 27" TV
Sharp convection microwave oven model R1875F. It's cooking on the left side faster then the rest of the oven. It seems to burn on the left side and not cook in the middle.
see the next causes. God bless you
Diode The high voltage diode converts the A/C power output of the transformer to D/C, doubling the voltage to nearly 5,000 volts. This high voltage powers the magnetron which emits the energy that cooks the food. If the diode burns out, a lower A/C voltage reaches the magnetron, which is not sufficient to power the magnetron. When the diode fails it is often visibly burned out. If it appears to be good, it can be tested with a volt-Ohm meter capable of testing diodes. High voltage diodes frequently fail and are one of the most common points of failure in a microwave oven.
Door Switch If the microwave does not heat, one of the door switches might be defective. Microwave ovens normally have three door switches, if any of them fail the microwave does not turn on and does not heat. Check the switches for continuity with an Ohm meter.
Magnetron If the microwave oven doesn't heat the magnetron tube might have burned out. The magnetron uses high voltage, high current DC power to generate the microwave frequency that cooks the food. If the microwave oven is turned on when it is empty this can cause the magnetron to burn out. Once it is burned out it has to be replaced, it's not repairable.
High Voltage Capacitor If the microwave doesn't heat the high voltage capacitor might be defective. The high voltage capacitor works with the high voltage diode to convert the output of the transformer to DC voltage and to double the output voltage. If the capacitor is burned out the entire high voltage circuit stops working properly. The high voltage capacitor can be checked with a special VOM meter which has a capacitance testing capability. Be aware that the high voltage capacitor can retain a charge of more than 3,000 volts and can injure or kill a person if not handled properly. Only trained technicians should perform this type of testing.
High Voltage Transformer If the microwave does not heat, the high voltage transformer might be burned out. Microwave ovens produce a very high voltage in order to power the magnetron antenna, which emits the energy that cooks the food.
Thermal Fuse If the microwave doesn't heat the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Thermoprotector If the microwave doesn't heat the thermoprotector may have tripped. This is a safety device to prevent the microwave from overheating. It can be tested for continuity to see if it's blown.
Main Control Board If the microwave doesn't heat the main control board may be defective. This is not common. When a microwave doesn't heat the problem is usually within the high voltage circuit; either the high voltage capacitor, diode, transformer or magnetron.
Oct 03, 2012 | Sharp R-1870 Convection/Microwave Oven
Sharp micro doesn't heat
see this causes and fix it. God bless you
Oct 02, 2012 | Sharp Microwave Ovens
Maytag microwave problem everything seemingly works but does not heat. Help
Oct 01, 2012 | Maytag MMV4205 Microwave Oven
Heating problem
Sep 27, 2012 | Microwave Ovens
Televison & Video Logo
178 people viewed this question
Top Televison & Video Experts
