Question about Fisher Washing Machines
I need a manual for a Fisher Scientific Thermix 210T stirring hot plate
2 Suggested Answers
SOURCE: popping plate not heating up
Remember the strirring rod connects to the motor, but the heating element connects via the two prongs in the rear, so the motor can run without the heating element turned on (turn on the base without the plate on...the motor runs fine). Try reattaching the plate...it needs a good connection to the connectors in the back. It should heat up pretty quickly. Also, if you put the heating pad in the dishwasher, make sure it is dry and that the contacts aren't tarnished.
I'm certain over time the contacts will get loose and the popper will stop working, but our is going fine after a year.
Also, be careful not to drop the base...lots of cheap, hard plastic that will break and rattle around.
Posted on Nov 21, 2008
Can a replacement stir rheostat be purchased for a fisher scientific hot/ stir plate model 11-500-4sh.
The value of the rheostat will part of the numbers on the metal case. You should be able to get ons from Radio shack or online.
Aug 11, 2016 | Kitchen Appliances - Others
Corning Pc-320 hotplate/stirrer. Where can I get a manual?
Why do you need a manual there is nothing to do. To make the stirring function work, you need a magnetic stir bar (just a Teflon coated magnet. There is a motor-powered spinning magnet under the ceramic plate.
The heater is not thermostatically controlled. It just heats more as you turn the dial more.
May 17, 2015 | Corning Pc-320 Laboratory Stirring Hot...
MWG9115SB suffix A - cooks very hot. Don't have a manual
I always recommend that folks put food off-center on the turntable to assure more even heating.
It's a stirring action, so imagine how inefficient it would be to stir just by twirling a spoon in the center of your coffee!
If the turntable or stirrer (if equipped) fails, that will cause hot spots and overheating.
Otherwise, you may have a failing magnetron.
In case it helps, the owner's manual is here: http://www.emersonradio.com/resources/owner_manuals/manual_1363011382.pdf
If you need more help, contact Emerson here: http://www.emersonradio.com/contactus.php
Oct 15, 2013 | Emerson Microwave Ovens
What is a hot plate stirrer?
From Wikipedia: A magnetic stirrer or magnetic mixer is a laboratory device that employs a rotating magnetic field to cause a stir bar (also called "flea") immersed in a liquid to spin very quickly, thus stirring it. The rotating field may be created either by a rotating magnet or a set of stationary electromagnets, placed beneath the vessel with the liquid. Since glass does not affect a magnetic field appreciably (it is transparent to magnetism), and most chemical reactions take place in glass vessels (i.e. see beaker (glassware) or laboratory flasks), magnetic stir bars work well in glass vessels. On the other hand, the limited size of the bar means that magnetic stirrers can only be used for relatively small (under 4 liters) experiments. They also have difficulty dealing with viscous liquids or thick suspensions. For larger volumes or more viscous liquids, some sort of mechanical stirring is typically needed.
May 01, 2013 | Science & Laboratory
Laundry detergent not dissolving
If you can let hot water to mix more with the cold when the washer fills, that will help the detergent to dissolve. If that's not an option, you can heat up about two quarts of water on the stove and when very hot, turn down the heat and add your detergent, then stir it till dissolved, and then add it to the washwater and clothes.
Sep 19, 2012 | Fisher and Paykel Washing Machines
Washer does not fill with water but motor continues to turns drum
Yes the drum will always spin when filling it is called stirring, however, you will find you need to replace the (I assume) cold inlet valve, or you could put the cold hose on the hot valve and do a hot wash, this means it would fill with cold water, however some machines do have a sensor for sensing water temp, if this is so the machine will beep, and it may take some time to fill. :)
Dec 04, 2010 | Fisher and Paykel GWL11 Top Load Washer
Hi my Fisher & Paykel Paprika stove (Model FPRA6102AW) Needs a New Oven element, and 3 of the plates stay on Hot. Are these parts available and how much would they cost please: x1 Oven Element x3 Switch...
Yes the regulators/simmerstats are stuffed but are not hard to replace...but please turn off the power 1st when removeing the backing plate as you will kill yourself....yes you will.
Use a multimeter set on volts ac or a volt detector stick, test tester on a known live sourse 1st like a power point....switched on
Mar 05, 2009 | Fisher Ovens
Popping plate not heating up
Mar 01, 2008 | Cuisinart CPM-800 Popcorn Maker
Heat's water great , won't pop corn
It may be a food placement issue or possibly a bad humidity sensor.
I always recommend that folks put food off-center on the turntable (not in the center) to assure more even heating.
Also, when you put your food off-center, you're not putting it in the same spot every time. That will help prevent repeated heating of the the same spot on the glass, which can lead to weakness and cracking. Microwave popcorn gets hot enough to do that.
We have the entire service manual at our site if your or a friend want to look that over: http://www.microwavedisplay.com/r820bc_bk_bw_sm.pdf
If you need a new sensor, you can order Sharp parts from Tritronics at http://www.wehaveparts.com
Please write back with more details if you need further help.
We're happy to help and we appreciate your thoughtful rating of our answer.
Dec 02, 2007 | Sharp R-820B Convection/Microwave Oven
Washing Machines Logo
77 people viewed this question
Top Fisher Washing Machines Experts
Dan Webster
Dan Webster
dweatherby
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
