Nixon The Block SS Watch Logo
Anonymous Posted on Jul 09, 2013
I need the handbook - Nixon The Block SS Watch
Level 3:
  • Nixon Master 18,429 Answers
  • Posted on Jul 09, 2013
Nixon Master
Level 3:
Answers
18429
Questions
Helped
1404207
Points
62248
Where can i order "BANDING TOGETHER FOR A CURE" rubber bracelets?
Does Google not produce any hits?
Try altering search terms....
banding together for a cure
rubber bracelets
also, if you know who distributes or makes these, try searching them as well.
You may get lots of unrelated hits for all above words, so scrolling will be required.
There is a way to specify ALL words only, but I'll have to check my Google handbook.
Nov 20, 2017 • Watches
tip
REGULATION TIPS FOR THE 400-day and 1000-day clocks
CLOCK REGULATION TIPS FOR THE ROTATING REGULATOR
These Regulations tips are useful for regulating the rotating regulator. This is to include most 400-day and 1000-day clocks.
The following information is copied from SCHATZ (tm) OWNER'S HANDBOOK.
Time Regulation Tip:
On the top of the pendulum is a disk on which numbers are engraved 1 - 16 and two arrows marked F - S. The small indicator hand will be pointing to a number on the disk at which the clock was regulated before leaving the factory. Should you find it necessary to regulate the clock, observe the number to which the indicator hand points. The distance between each number is equivalent to 1/2 minute in 24 hours + or -.
FRROM MY PERSONAL SHOP NOTES:
If your clock loses two minutes per day [24 hours] and the indicator hand points to number 8 on the disk - move the disk in the direction of the arrow marked F until the indicator hand will point to number 1.
NOTE:
Before attempting adjustments to the regulator disk, first lock the pendulums by using the lever located on the front of the base. By so doing, you will avoid damage to the delicate suspension wire while turning the regulating disk.
Keep A Regulation Record:
Keeping a short Record of regulation and maintenance on your clock will make it much easier for you to keep it well with in its optimum time-keeping ability. We have found that using the guideline below helps.
Date: +/- in min: How much adjust in Degrees +/-: Personal Notes:
We recommend logging only the times the clock was wound, and any time the clock is regulated or reset.
Times of regulation will include any time the clock has exceeded a 3 to 5 minute error.
Use only ONE form of time references for this, a QUARTZ clock that is known for keeping good time is recommended.
Over time you may find the clock needs only slight regulation; for example, if it has run for approximately 3 weeks and the error rate is under 3 minutes adjust regulator only slightly or simply RE-set.
TEMPERATURE and SEASONAL CHANGES
Temperature fluctuation can affect the time-keeping abilities of your clock.
Never allow direct sun light to come in contact with your clock. This will over heat the clock and it will not only affect the time-keeping qualities, but also dry out the oil and cause premature servicing requirements.
SPECIAL NOTES: REGULATION TENDENCIES
It is very difficult to look at the hands of an analog clock and still determine if the clock is running correctly, therefore I recommend allowing the time error rate on the clock to remain UN-touched until the error rate has exceeded + or - 3 to 5 minutes. This is because 1 minute is very difficult to observe and calculate effectively.
One little known fact about the Rotating Regulator: After the clock is restarted it can take up to 3 or 4 hours for the pendulum to settle down into regular beat rate. Example: If the pendulum is under rotated the clock will run fast and will take some time to bring it up to speed. If over rotated it will run slow. RECOMMENDATIONS ARE: Look at the actual clock time and reset it as closely as possible to real time after the clock has run for about 3 to 4 hours but don't disturb the pendulum. ONLY RESET THE CLOCK IF the actual clock time is off by 1 or 3 minutes.
If you must reset the clock every 3 to 4 weeks, and it is FOR EXAMPLE always slow, Slightly RE-Regulate the clock to compensate for this rate of error. Simply reset the clock several times just to make sure that no mistakes are made.
How to Calculate the Adjustment:
Calculating how much to turn the regulating nut on the rotating pendulum by using the following calculations.
Link to data base located at http://antiqueclock.clockstop.com/Regulate.html
Hope this tip helps.
r/David
on Feb 17, 2010 • Watches
8helpful
2answers
Need battery # Seiko 7N43 9070
You can purchase your battery from amazon, take a look here: Amazon com SR920SW battery (SR920SW battery is what you need). I hope this was helpful. Cheers
2answers
Blank screen with a line. Why?
I have the same, assume the watch battery is gone. Handbook says the whole timer has to go to a dealer to replace the battery.. the printer batteries are easily replacable, I wonder why they made the watch battery such a costly deal?
Dear Sirs: I bought my Vizio Computer at in Carson City, Nevada. However when installing it. I found that the Catalog for operations id missing. Would you be so0 kind as to mail me a copy of the Handbook :...
The support page for Vizio offers a link to manuals. I am unsure if the company continued to supply physical manuals, a matter you could query about to the customer service. If possible, have your receipt for the computer handy. If you were supposed to get a manual, chances are you will need to show when and where you bought it.
https://support.vizio.com/s/?language=en_US
Jun 13, 2017 • Watches
Require owners handbook for rolex daytona watch
Go to http://www.rolex.com/en#/Download/ and you will see your watch on screen.
Click on this and follow the instructions to download your watch instructions.
Apr 23, 2010 • Watches
5helpful
2answers
HANDBOOK FOR CASIO WAVECEPTOR TOUGH SOLAR 4719 WV0-620
Go to the Casio web site "casio.com", select "support" and the "manuals", then "watches", accept their terms and conditions,
Insert the module number and download instructions.
Jan 18, 2010 • Watches
9helpful
Cartier Roadster strap change
Scanned from the handbook. Hopefully this helps.
2helpful
Fossil watch service centers in India
Need to change leather strap
Dec 12, 2007 • Watches
1helpful
3answers
Peugeot406hdi
It sounds like the pump may be faulty. These are not cheap ! Could be a faulty pressure sensor, loose pipe connection or blocked fuel filter. Check the fuel filter is clear of water and dirt. Check there are no visible leaks between the pump and the injectors.
Have you run it low on fuel ? It is possible to get air in the system, and as air is more compressible than diesel, the pump pressure sensor may be showing a low pressure.
Oct 28, 2007 • Watches
Top Nixon Watches Experts
ZJ Limited
ZJ Limited
john h
Are you a Nixon Watch Expert? Answer questions, earn points and help others
