Question about Optorite (dd0405) DVD±RW Burner
Writer will read but not burn
Hey everyone i have an issue, my writer will read discs without a problem but when i try to burn a cd/dvd it: 1. reads about every 3rd disc. other than that it says the cds are corrupted. 2. when i get a cd that it takes and press burn, it acts as if it is burning the cd but no progress is made, the red burning light doesn't come on, and after about 5 minutes it stops burning. the burning software that i have been using is nero 6.0 on windows XP and i've had this drive for about 2 years and no problems, this just started happening a couple of weeks ago.
  • 39 Answers
Can you remove the burning software and try to burn by dragging files using the built in windows xp imapi? Check the event viewer for any system events around the time when you are having problems. Also try following these instructions:;en-us;314060 If you have another pc you can try the burner with, you would be able to rule out software issues.
Posted on Aug 26, 2007
I have a dvd writer .it was not reading discs like cd .dvds are reading. i can't burn datas to any discs.from where i get its spares to repair.
hey, if its reading dvd then it can read cds, possible reason is if the cd that your trying to read is burn in a format such as udf or etc. you have to install udf reader first, try to install software udf reader. try this link hope it work.
Oct 22, 2009 | LG GSA-H42N 18x DVD RW DL IDE Drive...
HELP!!!!! : "Not found CD/DVD Writer driver"
This could be due to a common issue. I would suggest you try this method first.
The following is a link to the Microsoft documented solution for issues with DVD/CD drives, explaining a step-by-step procedure. In the event that the first process, which is automated labeled "Fix It" does not solve your problem, please continue to the end of the document.
After completing this procedure, please let us know if you are still experiencing any issues by posting a comment. If this information was helpful, please take a moment to rate the solution. Thank you
May 17, 2009 | LG Super-Multi GSA-4163B 16x8x16x DVD+R/RW...
My lite-on DVD writer is not reading any dvd's as well not writing any DVD's while it is good for CD's..... What is the problem?? How can i correct my DVD writer
Hi Please try and use a different brand of DVD discs. DVD disc quality is sometimes an issue with lite-on drives Also check that you have updated drivers and your media burning software is installed correctly. Again if your using NERO this can be a problem. Try using any other burning software One other thing to try when recording DVDs set the recording speed to lowest Many Thanks Andy
Apr 27, 2009 | Computers & Internet
DVD writer not working
Let's make sure that Nero is not causing the problem. Try this:
-Insert a blank CD or DVD
-Find a file that you want to burn to disc
-Right-Click on said file and select Send To --> DVD-RW Drive (D:) (or whatever your recordable drive is labeled)
-Open My Computer, double click on your recordable drive
- You should see your file ready to be burned to disc
- In the left-hand panel, you should see a link that says "Burn these files to disc" or something similar - click this link and see what happens
If this process works and properly burns a disc, your issue is not with your drive but with Nero. If this process does NOT work, then you may need to reinstall drivers for your DVD writer or replace the drive if it is faulty.
Hope this helps. Please take a moment to rate this solution. Thanks.
Mar 11, 2009 | Compaq 6710b Notebook
Cannot backup files to a cd/dvd
we may need more details but you can try this for now
1. are you sure you have a cd writer or a dvd writer (writer = burner)--- check the front edge of your cd/dvd unit and look for words like "writer" "burner" or writeable next to the word dvd or compact disc... keep in mind not all cd/dvd writer can write (burn) cd or dvds, some may burn cd but not dvds.
2. is your cd/dvd unit compatible with the media (cd or dvd blank disk) you are trying to use.. depending your cd/dvd especifications your dvd/cd drive is compatible with certain types of cd or dvds that are writeable.
3. is the cd/dvd a writeable cd/dvd and is compatible with your cd/dvd drive? for instance.. if you are using a blank dvd and your cd/dvd drive only burn cd/s and read dvd and cd you won't be able to write to the blank dvd.
4. are you trying to burn a dvd in a corporate computer.?? as a user (not an administrator) of your corporate computer you may not have priviledges that will allow them to burn dvd/cd's even you your drive and your media are compatible.
please post
the error that you get
the brand and model of the computer you're using
the type of media you're using
Oct 02, 2008 | Computers & Internet
Registry problems with my dvd rewriter
please check have you install any burning application?
example nero...........
and sometimes it sensitive to some cd/dvd
what disc have you try to put it? cd or dvd?
please make sure your disc writer support dvd burning.........
does it able to read any disc?
Aug 24, 2008 | Computers & Internet
LG DVD writer problem
You should be using the software "NERO" to burn discs.Goto>start>all program>Nero>Data>NeroExpress
Here you clearly see the two types to burn disc "data cd" and "Data dvd".
Need More help?.if yu are using another software whats that?
Mar 07, 2008 | Computers & Internet
Dvd writer for toshiba satellite pro
HP dvd1040i 20x Super Multiformat DVD Writer
Price: $69.99
  Internal drive (double layer)
 Write speed: 8x double layer, 20x DVD±R, 48x CD-R
Rewrite speed: 8x DVD+RW, 6x DVD+RW, 32x CD-RW
Read speed: 16x DVD-ROM; 48x CD-ROM
Lightscribe disc-labeling technology
one-year limited warranty....
HP dvd1040e 20x Super Multi DVD Writer
External drive (double layer)
  • •   Write speed: 8x double layer, 20x DVD±R, 48x CD-R
  • •   Rewrite speed: 8x DVD+RW, 6x DVD+RW, 32x CD-RW
  • •   Read speed: 16x DVD-ROM; 48x CD-ROM
  • Lightscribe disc-labeling technology
    Price: 109.99
    These are the best DVD writers....
    Lightscribe technology is where you can burn your pictures on the disc as a label..... This is Hp's latest technology
    Oct 22, 2007 | Computers & Internet
    DVD burning problem
    if you have tried different dvd-r and dvd-rw discs, unfortunately it's a sign that your writer is failing to read the discs correctly, this normally happens when the writer is about to give up, although it may still write and read cd's but not dvd's
    Sep 01, 2007 | Computers & Internet
    Dvd player has trouble reading the discs this dvd writer burns
    Go to yahoo and do a search for a firmware update putting in the model number of your recorder or visit manufacturer's website see if they have any firmware update available.
    Aug 01, 2006 | Sony DW-G120A DVD RW Dual Layer Burner
    Open Questions:
    See all Optorite (dd0405) DVD±RW Burner Questions
    Optorite (dd0405) DVD±RW Burner Logo
    117 people viewed this question
    Top Optorite Computers & Internet Experts
    David Payne
    David Payne
    Are you an Optorite Computer and Internet Expert? Answer questions, earn points and help others
