SOURCE: I need to replace the Door Springs
if you just need to install springs pull the bottom kickplate can do it there only two screws
SOURCE: Danby counter top dishwasher leaks
This might help with disassembly. Mine was leaking also, but my main problem was no spray. Use my disassembly instructions to remove the pump/motor. If you notice that the leakage is from the pump and not a loose connection, remove the pump cover and apply a thin bead of Blue RTV sealant to the rubber ring. This stopped the leak in my pump.
________________________________
My Danby dishwasher (DW) stopped working. The spray arm
stopped spinning completely and very little water was coming out of the arm.
When I removed the spray arm (CAUTION: reverse threaded, turn CW to loosen and CCW
to tighten) and ran the DW, very little water was spraying out of the pump.
I thought maybe the pump was clogged. So, I followed the
recommendations I had seen online about running a few cycles with Vinegar to
clear the crud from the pump, but this did not help.
It seemed like the motor was operating, and there were no
strange smells to indicate the motor was burned…just no water spraying. So I
thought it must be the pump. Before disassembly, I tried to locate a
replacement pump. I searched far and wide, both locally and online, and could
not locate a replacement pump. So with nothing to lose, I decided to
disassemble the DW, take a look and see what I could find. I am glad that I
did.
The bottom line is that I disassembled the dishwasher and
found that the plastic pump impeller had worked its way off the pump shaft and
was not turning. I forced some Teflon plumbers tape over the shaft and forced
the impeller back onto the shaft. The impeller has a flat spot to line up with
the shaft and I pushed the impeller down on the shaft as far as it would go. I then
used a small socket to fit over the shaft and GENTLY tapped the impeller for a
final seating. I reassembled the dishwasher and it worked like a charm.
Since I could not find any service manual or instructions
online for this DW, I thought I would share my disassembly/reassembly
procedure.
Since my instructions are too long to post here, a complete repair document including a link to pictures can be found at:
http://www.megaupload.com/?d=XBOGBR4I
SOURCE: Viking Dishwasher Leaks Into Base
Since this was posted in May I guess it's been fixed but for those of you seeing this problem for the first time, here's one reply:
This sounds exactly like the problem I just found with my DFUD042. There is a small black hose between the base of the tub and a pump motor - part number on the hose is 8072888. The hose has a small **** or crack in it and water is leaking which is most likely the problem causing the symptoms. I had to throw the circuit breaker to get mine to shut off as well.
When I tried to remove the plate it was stuck under the black sound proofing so I had to work around it a bit until it finally came off. Now I just have to find the hose and some clamps.
SOURCE: mdb7601aws dishwasher door drops down
hi there,
go to www.whirlpoolparts.ca to get the exploded view for your model #. it will be the located under Repair Parts.
SOURCE: dishwasher not washing dishes properly
Thanks akubra_lands, it worked for me too on model DW28W. I thought I should elaborate on your answer for anyone else who comes across this while researching the same problem.
The repair is ridiculously simple (takes about 10min) and the only tools needed are 1 philips/posidrive screwdriver and 1 flat blade screwdriver. Assuming you've unplugged it from mains power:
Now take a moment to admire the handiwork of the engineer who planned the failure of that innocent little plastic flap around 6 months after the expiry of the warranty.
I actually had a repair man come and look at the problem, and yep, right on cue, he told me it needed a new pump motor. $300. When he realised I was on to him he just gave up. So hard for repair people to do an honest day's work these days..
