Question about Euro-Pro F1066 Deep Fryer
Deep fryer cuts off several times a day pressed reset switch cuts on but will contiues to cut off
    New Friend:
  • 3 Answers
No I need a replacement cord P/N 21515
Posted on Jul 11, 2013
When thermostat cuts on there is a pop when the
Hi there.
Check the gas pressure, it must be standard as required on unit,s nameplate, low gas pressure can cause this problem.
Check and clean also the burners as needed.
Regards.
Oct 27, 2013 | Frymaster Dean SR42G Deep Fryer
WHEN FRYER HEATS UP THEN IS LOADED TEMP SEEMS TO FALL AND HAS TO BE RESET
If you manually reset by pressing overtemp thermostat, then check your operating thermostat.. maybe over heating.. if so replace thermostat.. if pilot cuts out completely prematurely without reaching set temp then replace overtemp cut out thermostat as it is faulty.
Cheers
Mar 22, 2012 | Pitco Frialator SG14 Deep Fryer
Commercial deep fryer keeps getting to hot, having to reset, is it possible to replace thermostat ??
Hi there.
Your fryer may have problem in cutting off the heating element power (electric fryer) or burner flame (gas fryer) for temperature regulation which is thermostat's main function.Thermostat is replaceable, you have to identify the manufacturer of your fryer to get the exact component.
Regards.
Aug 24, 2011 | Kitchen Appliances - Others
Fryer heats up but does not maintain proper temp. last year replaced hi limit reset & today replaced thermostat
Hi there.
You may need to calibrate the new thermostat and in doing so, you will need a calibrated thermometer with sensor dipped in oil at about one (1) inch above the fryer thermostat sensing bulb.
Record the cut-off temp (when indicator light goes off) and compare it with the thermostat setting.
The thermostat has a calibration screw ( - ) recessed in the middle of the shaft, you will see the when you pull off the thermostat knob. this calibration screw can be turned by a precision screw driver, turn clockwise to decrease the cut-off temperature ; turn counterclockwise to increase the cut-off temperature.
Just make sure that the unit is preheated or have cycled at least 5 to 8 times and the oil is new before performing the calibration.
Regards.
Jul 14, 2011 | Wells F-101(21186) Deep Fryer
Unit ( model SR142gp serial 0608MA0448 - propane fuel ) operates as designed, but can not cut flame to pilot with the thermostat. must cut the gas control to pilot to the get pilot flame & pilot...
The pilot light should remain "ON" all the time. It is not intended to ever go off, unless you are not going to use the fryer for several months at a time. Then you can just shut off the propane which will shut off the pilot light flame. It does not cost that much to run the pilot light all the time. About one to two dollars a week.
Sep 11, 2010 | Frymaster Dean SR142GP001 Deep Fryer
My signature classics deep fryer will not power on. I pressed the red button and nothing happened. Please assist.
first check fuse in the plug,,,if good, check that the plug is working and has power to it,,if all ok so far then you need to check the power on switch in the cooker and the thermal cut outs,, if the fryer has over heated the thermal cut out would have blowen or the heater has blowen
Aug 08, 2010 | Kitchen Appliances - Others
Piot light will go out
its likley to be the thermal cut out playing up its not holding the gas on as its getting week a new one will sort this problem out first time
Nov 12, 2009 | Frymaster Dean GF14 Deep Fryer
Fryer promblems
This is caused by a failing coil on the gas valve. You should replace the gas valve.
May 08, 2008 | DCS FSF-40 Deep Fryer
Euro-Pro F1066 Deep Fryer Logo
101 people viewed this question
Top Euro-Pro Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Gerry Harvey
Gerry Harvey
Clarice Bornschein
Level 1 Expert
Are you an Euro-Pro Kitchen Appliances - Other Expert? Answer questions, earn points and help others
