Question about Liebherr KIU 1640 Premium Compact Refrigerator
Fridge temperature too high
Miele KFN8993SDN Freezer temperature to high
Temperature displays
During normal operation, the temperature display shows the temperature in the middle of the refrigerator section and the temperature in the warmest part of the freezer section.
Aug 20, 2015 | Miele KFN12923 SD-2 Stainless Steel 369 l...
Fridge dosen't seem to click off as much when it gets to temperature like it used to do, what can I do?
Try verifying the temperature range with a thermometer. For most fridge's you should see something like a low of 32 and a high of 40. Those would represent the turn off/turn on points for the compressor - that part that actually makes the fridge cold.
If it's swinging much outside those rages, the thermostat in your fridge is suspect. For most fridge's the thermostat is the know you turn to adjust the temperature. It usually has an attached wire/temperature probe that runs down behind a panel in the fridge and senses the temperature so the thermostat can command the compressor to turn on or off.
If it seems like the compressor might be at fault check with the manufacturer's website and you might find a parts diagram and identify the part. Then you can either call a repair technician or try replacing it yourself. You can purchase replacement appliance parts at many places on the Internet such as this site: Search Over 2 1 Million Appliance Parts
Good lcuk.
Mar 10, 2015 | Refrigerators
Fridge temperature too hot won't go down with temperature controls
This looks like there is a problem with thermstat in the fridge. We had a fridge that would not cool and we found it to be the thermastat problem. You have to replace the thermstat on the fridge. Not 100% sure but a high possibility.
Mar 23, 2014 | Frigidaire Refrigerators
When setting fridge temperatures is low cool best?
high and low relate to the speed at which the unit will reach operating temp..low saves energy.high is for newly stored food.
Mar 10, 2010 | Refrigerators
My RM2852 Is Freezing the food in frige section, what might the problem, be? Does this unit have a defrost switch??
Located in the inside in the rear top of the fridge are aluminum fins. on one of the fins near side of fridge there is a folded aluminum sleve that skides up and down on the fin.
this actualy adjusts the temperature of your fridge. slide up or down to adjust fridge cabnit temperature.
Aug 28, 2009 | Dometic RM2852 Refrigerator
Bottom freezer temperature rises as high as 35 degrees and drops only to a low of 15 degrees continually. ongoing for a month now. french doors fridge now has temp. fluxes within this past week. temp. goes...
check the defrost thermostat , and any temp sensor that can determine the freezer temperature.
If this fridge temperature is electronically controlled, the freezer control board must also be tested.
Click here to get all parts and diagrams for this fridge.
Regards.
Jul 09, 2009 | GE Profile PFS22MBW French Door...
How To Set The Temperature
5 is the coldest.
1 is the warmer setting.
Normal setting would be halfway.
Apr 23, 2009 | Refrigerators
FRIDGE/FREEZER MODEL: SR42NMB Multi Frost
You have a clogged defrost drain tube. best way is to thaw unit out. Your vents are being blocked so no air flow is pushed down.
Jan 05, 2008 | Refrigerators
Bosch Fridge Freezer Classixx
This button is the winter/summer setting.
If you switch it on so as the red mark shows this is set for the summer setting.
What it does is allows the interior light to come on very dimly when you shut the door.
The fridge then thinks it is too warm and starts to cool down more, designed for when the ambient temperature is high.
Hope this helps
Deep diver
Dec 22, 2007 | Refrigerators
Liebherr KIU 1640 Premium Compact Refrigerator Logo
18 people viewed this question
Top Liebherr Refrigerators Experts
Dan Webster
Dan Webster
Shehu Pro
Shehu Pro
Are you a Liebherr Refrigerator Expert? Answer questions, earn points and help others
