Question about Intex Pool & Spa
Fill valve replacement
I have an intex oval pool. The filter valves I believe were installed incorrectly or something isn't operating the right way. There is a blue large flat valve on the intake, which is leaking a little, and a white small one on the output, and that is leaking a little. But mostly, there is no air pressure. Not pulling in and not pushing out. What could be wrong and do I need to empty the pool?
SOURCE: Hayward sand filter needs primed every time
The problem is a malfunctioning check valve. It'll be somewhere in the line on the pump output side. If it's not a separate fitting it'll be in the line, probably in an elbow.
Need further info, let me know...
Charlie
Posted on May 29, 2009
  • 76 Answers
SOURCE: I have an intex 15 x 48 pool. The old pump wasnt
check the intex site for adapters and other parts you might need.
I don't think you should buy new pool .
Posted on Jul 15, 2009
SOURCE: air in filter on hayward above ground pool.
This is common the first 30-60 seconds after turning the filter on. The filter is purging its self of the air, sometimes algae or small debris will shoot back into the pool as well.
If it is constantly getting air then replace your o-ring on the that clear cover (Strainer Cover) make sure you use a lubricant, and like djtc66 said re-wrap all threaded areas with teflon tape.
Posted on Sep 04, 2009
nlc0
  • 3 Answers
SOURCE: New Intex FP621 4000 Pool Pump Noisy
I have a 16 x 48 intex pool with the 1inch inlet and outlet. I purchased the intex 4000 pump. The attachments are too big for the inlet and outlet so i then purchased the adapters. The plungers are very noisy and allow air to get into the pump. I removed them and hooked the hoses up to the adapters directly. That worked as long as the adapters were new. This year the seal comes loose and allows air to get into the pump. I even tried allowing the top nut to be loose to allow air to escape. This year nothing works. The pump is just too strong for the holes. I was considering cutting the holes bigger and glueing seals on there but i was concerned about creating weak spots in the pool. I am tired of spending money on it so i did the redneck thing. I can say that because well, you might consider me one. I took the inlet hose off the connector and plugged the hole with one of those little black things. I took the hose and run it up through the hole in between the liner and the poles and down into the pool. If you run it over the top it will not work correctly. Take the hose and tie them together between the two sides as best you can to keep the hose in the pool. If you look at the smaller intex pools that dont have holes, that is how they have the pump hooked to the pool. VOILA! You have an airtight inlet to the pump. You do not need to do that to the outlet because its not sucking water its just pushing it. So, just hook the hose up as you wish. When you need to clean the filter, I put wash clothes in the hoses to plug them and voila. No air gets into the filter. Done! It is actually keeping my pool clean this year. Also, i purchased one of those aqua vacuums and it does work great for this pool. Once you get the big stuff, sweep it with a pool broom and the filter will do its job. You can vacuum these pools with the filter type pumps. Next time, i will purchase a sand filter and be done with it. Happy swimming with less work.
Posted on May 22, 2010
SOURCE: Top Inflatable Ring on Intex Pool Leaks
Soapy water never worked for me... Pour kids bubbles into a bowl and use a paint brush to spread the bubbles on the top ring. If there is a hole you'll see it begin to blow a bubble where the hole is.  patch with vinyl repair kit.
Posted on May 31, 2010
Can I fix my input valve, on my sand filter, while water is in the pool?
IF YOUR ASKING IF YOU CAN REPLACE THE MULTIPORT VALVE ON TOP OF SAND FILTER HOUSING WITH WATER STILL IN POOL , SURE ITS POSSIBLE . 1ST UNPLUG PUMP POWER !!!! SECOND USING A COUPLE OF TRASH BAGS ADD ENOUGH AIR INSIDE OF THEM TO FIT JUST TIGHT ENOUGH DOWN INTO SKIMMER ON SIDE (ME I USE A OLD POOL TOY) WEIGHT OF WATER WILL HOLD THEM IN THERE , NOW YOU CAN DISSCONNECT YOUR HOSES , A SLIGHT TRICKLE MAY COME OUT (EASY TO REPLACE LOST WATER VOLUME) REPLACE THE VALVE , WAIT FOR GLUE TO COMPLETLY DRY (IF USED) THEN RECONNECT HOSES , REMOVE TRASH BAGS FROM SKIMMER(LET AIR OUT) , RECONNECT PUMP AND TEST FOR LEAKS
Jun 05, 2015 | INTEX Sand Filter Pump
My intex 637r pump is not pulling the water through to the filter and letting it discharge back into pool could it be that the pump and hoses are sitting to high on the ground and not far enough under the...
Air release valve for air trapped inside filter chamber
Intex 1000 GPH Easy Set Pool Filter Pump Instructional Guide 637R
The link has a set-up video for the 637R pump. Make sure water flows out of the air valve on the top of the filter cover. This will purge air out of the filter and prime the pump. Hope this helps you....
May 13, 2014 | Intex Krystal Clear Model 635 Pool Filter...
Sand and debris isn't being filtered out and comes back into the pool via return water
The lateral assembly in the bottom of the sand bad inside the filter is broken. You may not even see damage on it when replacing it but it is the problem. Replace the sand while you are at it. Be sure to fill the tank half-way with water before adding sand back into the filter. Also be sure to cap the top of the lateral assembly so sand doesn't get into the standpipe that inserts into the bottom of the valve.
John
May 29, 2011 | Hayward SAND FILTER, PRO SERIES
How do i clean or replace the filter on the intex water pump for my above ground pool
Shut off the valves on the hoses coming from the pool. spin the top of the filter counterclockwise to take it off. remove the old filter, replace with new filter then replace the cover and spin it tight. openvalves and purge air from the pump.
heatman101
Aug 19, 2010 | Intex Pool & Spa
Very weak suction on inlet side. Water is green.
unscrew the top valve on the filter carteidge and let the air bleed out
clean filter every day and run it 24/7
Intex pumps can not filter good enough
Jun 09, 2010 | Intex Automatic Salt Water System for ...
I cannot get one of the filter valves closed
Water should not be draining from your pool filter at all. There should be one hose that connects to from the filter to the pool and another hose that returns the filtered water from the filter to the pool. It is a continuous loop. If water is coming out of your pool during this process, either you don't have a hose connected properly or the hose is leaking/cracked.
Jun 16, 2009 | Intex 1500 Gph Swimming Pool Filter Pump...
Is the intex 4000 pump any good.... do you lots filters...
I have the new 4000GPH pump and its awesome! The pump itself needs modifying just a bit. As for your pool, get rid of the plunger valves. They restrict the flow by about 1000GPH or more. There is a plastic grate in the inlet side of the pump. I just took a small file and sharpened the leading and trailing edges to smooth things up. The biggest thing is with the plunger valves. I modified some PVC fittings so I can use 1.5 inch ball valves. When my pump starts up, you see the water moving. I no longer have problems with **** settling to the bottom of my pool. Oh, and it will run an automatic cleaner with ease.
I dont recommend using the 400GPH pump with hoses smaller than 1.5 inches as there will be too much pressure and is likely to cause problems.
Mar 07, 2009 | Intex 4000 GPH Filter Pump
Pool & Spa Logo
12 people viewed this question
Top Intex Pool & Spa Experts
Jay Finke
Jay Finke
Mike
Colin Stickland
Colin Stickland
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
