Question about Hitachi 42PD380TA 42 in. EDTV-Ready Plasma Television
MY TV HAS ONLY AUDIO BUT NO VISUAL SIGNAL - Hitachi 42PD380TA 42 in. EDTV-Ready Plasma Television
    Top Expert:
  • Hitachi Master
  • 75,311 Answers
There are so many reasons for this fault, and it is not predictable, which part is fault, with this condition. Products powered by electricity should be serviced or repaired only by experienced professional technicians. Any attempt to service or repair the product by anyone else could result in serious injury or death. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock. Instead, contact the nearest service centre.
Posted on Jul 09, 2013
Cant get signal or sound on wireless speakers. Which Audio Socket on TV do I use Audio/visual input or RGB DVI or Audio outlets on AV TV recorder Humax 9300T TV is LG model26LB75
you should be looking for the audio out socket from the tv as the signal is going out from the set to your speakers the other sockets are for input when connecting dvd or video into the tv. hope this helps ..A
Jul 21, 2010 | Anchor Audio/PA Systems: Liberty Sound...
Will a vcd work on this player?
This unit, doesn't care what signal it is fed from at a;;. as long as it is in a format that it can process it will work. If you cab connect up, via the AV, Audio Visual Sockets. Yellow, Video, and Red & White, Stereo, Audio. Or Component, Blue, Red, Green, (All Video) or HDMI, then it will work fine.
Apr 08, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Have no visual display from hdmi - only sound
The settings on the PS3 are sending the video signal throught the hdmi port. Either go through the XMB via sys settings, display settings, ... Or if you only have a low def tv then hold the power for 5 seconds (when you turn it on i belive) and it resets it. You may have to adjust the audio settings at the same time, because if you pressed yes when the HDMI was first connected, you agreed to send the audio signal via hdmi as well.
Apr 07, 2010 | Sony Playstation 3 (PS3) Console
I want to hook up a Toshiba laptop to a Panosonic rear projection
VGA, and supervideo only carry the visual signal, so if you use one of this cables, (both the computer and the tv have to have the same output/input) then you have to have a cable attached to the computers audio output to carry audio to the TV. If your computer has HDMI output and the tv has an HDMI input, then that carries both visual and audio. When you attach the video cable to the tv, put the tv on that input source and the computer will sense the device and if the drivers are updated will fire the signal up automatically and give you the choice of using only the tv, or using both the tv and laptop monitor.
Sep 27, 2009 | Computers & Internet
Audio Problems 42" LCD Toshiba
reprogram the tv- auto scan will synch video and audio
Aug 22, 2009 | Televison & Video
How do I hook up my new coby DVD recorder/player?
What you will have to do is just two of the inputs coming from dvd to the tv.
You should have red, white and yellow coming from your dvd. The Yellow is usually used and is marked on your dvd as the video and goes to the video on your tv. You can use either the red or white for the audio input into your tv. You have an older type tv but that is all that is necessary. Video to video and one audio only to the other audio input on the tv. good luck.
Jan 14, 2009 | Coby Televison & Video
TV doesn't recognize PS3
put cables ps3 came with in with ps3 on standby hold power button on ps3 down 10sec and it will reset audio and visual setings
Jan 06, 2009 | Sony Playstation 3 (PS3) Console
Need instruction to hook up dvd player
You will need a TV or monitor with audio/visual inputs. The better ones have what is known as an S/VHS input, which separates the TV picture signal for better color reproduction. You will need to be able to switch your TV, usually by the channel selector, to the proper input for audio visual signals. Sometimes this is known as Video 1, Video 2, A/V etc. These are usually below Channel 2. Maybe your remote has that option. You will need an a/v cable. This is a three-connector cable with RCA plugs on each end. Connect the DVD player to the TV as follows: 1. Yellow cable, from video OUT on the DVD player, to video IN on the TV. Video is ALWAYS yellow. 2. Red and white cables from audio OUT on the DVD player to audio IN on the TV. 3. If you have S/VHS capability, buy an S/VHS patch cable which will have the three plugs mentioned, plus a round 4-pin plug. Select S/VHS OUT on the DVD player, and S/VHS IN on the TV. When using S/VHS, ignore the yellow connector. It is for composite video and not needed. Here's a hint: Your YV audio/visual inputs will usually be on the back of the set. Some better units have a/v inputs in front. What if my TV doesn't have a/v inputs? If your DVD player as an RF output, connect an RF "f" cable from that output to the antenna in cable on your TV. Otherwise buy an RF converter (about $20 or so at Radio Shack). Connect your a/v cable (yellow, red and white) from the DVD player to toe converter, then connect an RF cable (like the kind your cable box is connected with) to the antenna input on your TV. This signal usually comes in on Channel 3. Let me know if your problem is more complicated, It seems like a lot of wires and connections, but it is really straightforward, Remember, yellow is ALWAYS video. The two audio cables can be connected without worrying about color.
Dec 13, 2008 | Televison & Video
NO signal to tv
There could be two problem ,
1. the cable you are using to connect the station to the box is faulty.
2. the video card signal may be bad, try connecting a computer flat panel
Thanks
Mandeep
Apr 17, 2008 | Sony PlayStation 2 (PS2) Console
Hitachi 42PD380TA 42 in. EDTV-Ready Plasma Television Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
