Question about Sony Handycam DCR-SR100 Camcorder
Images on the SOny DCR SR 100 HDD camcorder show as boxes.
I plugged in the USB from the Camcorder to the computer. Selected "open the folder to view the files". Selected all the movie and images folders and copied them on to the computer. My problem: The movies playback on the camcorder but not on the computer. Only few images got copied on to the computer. And when I checked my camcorder, all the images, except the one that got copied, rest of them are grey boxes. I can;t see the bulk of the images. Please help. TGhanks
  • Anshuman Guleria Aug 26, 2007
    the video problem is ok...
    but wat about the images...why are the images not shown on the camcorder and how can i retrieve them.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 153 Answers
Sounds liek you need a codec to view them (a driver for video files) I'd suggest: www.xvid.org or www.divx.com
Posted on Aug 26, 2007
  • SimcoeTek Computer and Technology Solutions
    as a suggestion, try downloading picasa from google.
    it will let you import everything, and will recognize what is valid images and what are not.
    it not a solution, but may help
SOURCE:
The harddrive of my sony dcr-sr68 harddrive cannot seen on the my desktop computer
Please connect the Camcorder to the Computer, turn off and turn ON it again to see the USB SELECT options on the LCD screen of the Camcorder. Once you get the USB SELECT screen, select HDD and give a few seconds to display the HDD of the Camcorder under the My Computer.
Please let me know if you require any additional help
Apr 12, 2012 | Sony Handycam DCR-SR68E Camcorder
How do you get rid of movie disabled on a sony video camera
The movie recording error message indicates that the Camcorder is not in a position to record videos. It may be due to shake, free space, corruption in the folder structure, bad sectors in the HDD.
Please follow the below steps and check the operation. Each step is a possible resolution, so please perform one by one and check the operation.
  • Place the Camcorder in a steady surface and press the record button.
  • Please press the reset button on the Camcorder and check if that helps.
Make sure that you have turned ON the Camcorder while pressing the reset button.. You can locate the reset button from the below figure.
  • If the issue persists again, format the HDD of the Camcorder and check the operation.
To format the HDD of the Camcordeer, you can use the HDD FORMAT option under the HDD set
Note:Formatting the HDD will erase all previously recorded videos and images from the Camcorder.
I hope this will resolve the issue
Jan 27, 2011 | Sony DCR-SR60 30GB PAL Handycam Digital...
Hello - i have Sony sr42 handycan and i need to copy data from it to my laptop. i have usb data cable but unfortunately i have lost my software. when i connect handycam to my laptop through usb, i get the...
There is a tutorial for transferring video from tyhis camera to a computer on the Sony website. Unfortunately, you do not say what kind of computer (PC or Mac) or operating system you have, and you have to specify this on the website to get the right instructions.
The instructions for a Windows computer are as follows:
Movie player applications must support mpeg 2 playback to open these files properly. Refer to the software manufacturer for additional information and available updates.
  1. Turn on the computer.
  2. Make sure the camcorder is turned off.
  3. Connect the camcorder to the computer using the supplied USB cable.
  4. Plug the AC power adapter into an electrical wall outlet and then connect it to the camcorder.
  5. Open the LCD screen on the camcorder.
  6. Turn on the camcorder.
  7. The USB SELECT screen will be displayed on the LCD; touch the HDD icon.
  8. Open the My Computer window on the computer.
  9. In the My Computer window, double-click the icon that represents the camcorder and then navigate through the folder structure to locate the video you want to transfer. Note: The camcorder will be listed in the My Computer window as an additional hard drive.
  10. Click to select the video or image files you want to transfer. Note: If your are using a High Definition Handycam® Camcorder, Sony recommends copying and pasting the AVCHD folder to the hard drive of the computer before accessing its contents.
  11. Type CTRL+C to copy the files.
  12. Click on the computer folder to which you want to copy the video or still image files.
  13. Type CTRL+V to paste the file into the computer folder.
The Sony page for your camera has many links for information and downloads, including software downloads, at THIS PAGE
Dec 31, 2010 | Sony Handycam DCR-SR42 Camcorder
I want to play a mpeg-2 video on my TV through Sony SR 40
You cannot play any content that you transfer from your computer on the camcorder no matter what format you try. The camcorder simply does not support it.
Dec 23, 2009 | Sony Handycam DCR-SR40 Camcorder
Hello, my Sony handycam model no is DCR-SR200 HDD. I can record, replay in handycam. but unable to download/copy the files into my PC. unable to read the memory in the CAM hard disc. please help me. how...
when you connect to PC if you can see the disk/camcorder drive in my computer, copy entire folders to your PC it will work.
possible : Check /replace USB cable
:without using sony software copy files from my computer.
:if lcd not working, use the copy button from the camera docking unit
Nov 29, 2009 | Sony Handycam DCR-SR200 Camcorder
Connecting to computer & importing images from HD of DCR SR 42
Mine does the same thing.After it says "connecting" on the LCD of the camcorder, there is nothing to actually do on the camcorder. With the Sony SR42 software installed (supposed to come with the camcorder on purchase-but maybe you can also find it for free online), the software called Sony Picture Utility (which is part of the big packge of software) opens up automatically and offers to either burn your photos/videos to directly to a compact disc, or to import them onto the computer's harddrive.
That's how it happens for me.I'm not-tech savy or anything. Hope this helps.
Dec 01, 2008 | Sony Handycam DCR-SR42 Camcorder
Sony dcr-pc101e camcorder / vista laptop
Please download Sony USB Driver from Sony Support so your computer will recognize your camera DCR-PC101E.
Oct 05, 2008 | Sony Handycam DCR-PC101E Mini DV Digital...
Sony camcorder - USB mode
the usb mode is usually reserved for removing pictures from memory card through camcorder to computer-using camcorder as web cam-new models can stream lower quality video from camcorder to computer-for a dvd cam use a converter box ie pinnacle movie box to convert analog A/V connections to usb and that will stream the correct way-
May 08, 2008 | Sony Handycam DCR-DVD105 DVD Camcorder
Sony Handycam DCR-SR100 Camcorder Logo
335 people viewed this question
Top Sony Video Cameras Experts
Ekse
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
