Question about Dishwashers
Samsung DMT - 400 delicate light blinking
Have a 2 year old Samsung DMT 400 RHS. Friday last week it stopped working.We have checked for clogs in the drain hose, took everything apart clean it, No kinks in the hose and it still does not work. It starts to wash dishes, it pumps water when it is supposed to pump water out. Then when it comes almost to the end it pumps water out again stops, comes back on short time later, tries to pump again, can not pump, stops again comes back on tries to pump water out again and now the delicate light comes on and blinks. From what we can tell the pump is working fine, there are no clogs in the drain hose , nothing stopped up and no kinks. Hose is mounted the right highs and still it will not pump the water out. Can anybody help?
    Prodigy:
    An expert who has answered 500 questions.
  • Dishwashers Expert
  • 646 Answers
The Delicate light flashing on Samsung dishwashers indicates a drain error. You say there are no clogs or kinks in the drain hose, and that the drain pump tries to run (I guess you can hear it running), but it still won't drain. Try this: Disconnect the drain hose where it goes into your garbage disposal, and see if it will drain into a bucket. If it does, then there is probably a clog just inside the garbage disposal, OR if you just got a new garbage disposal, then either you or the installer forgot to knock out the plastic plug at the end of the drain port!
If the dishwasher won't drain into a bucket, then you probably have a bad drain pump, or an obstruction right there (or just inside the drain hose, which is where your check-valve is located - maybe that is where you have a clog or obstruction).
If the dishwasher drains okay, then you have a bad ECS sensor causing the error code.
I hope this helps.
Posted on Mar 22, 2015
    Top Expert:
  • Dishwashers Master
  • 12,223 Answers
Please follow this steps and fix it. God bless you
Heating Element
If lights are flashing on the control panel, the heating element might have burned out. The heating element heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element can be checked for continuity with an Ohm meter.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Heating Element Assembly
If lights are flashing on the control panel, the heating element assembly might have burned out. The heating element assembly heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element assembly can be checked for continuity with an Ohm meter.
Check Fault Codes
If the display lights are flashing and there is an error code in the display window, check the wiring diagram and tech sheet in the dishwasher that will provide information on the fault.
Drain Pump
If lights are flashing on the control panel, the drain pump might not be working properly. For two-wire drain pump motors check them for continuity using an Ohm meter. If it's defective You'll need to replace it. Drain pumps are not repairable.
Touchpad and Control Panel
If the lights are flashing on the display the entire touchpad and control panel assembly might be defective. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Touchpad
If the display lights are flickering for no reason, the touchpad might need to be replaced. Sometimes when the touchpad is defective the display lights are flashing randomly.
Posted on Jul 09, 2013
Samsung dishwasher not pumping water out. "delicate" light blinking and it doesnt appear the pump even tries to come on. the machine just stops after wash cycle then I get the error light.
The Delicate light flashing on Samsung dishwashers indicates a drain error. Possibly a pump/motor assy.
Samsung Dishwasher Not Draining
Doesn't sound like a clogged ECS because it's not draining at all.
Jun 12, 2017 | Samsung Dishwashers
Samsung dishwasher heavy and delicate lights blink and cycle stops
The lights that are blinking are indicating an error code--the particular code you describe is a "heater error". You will have to check the circuit for an open heater element, loose or broken wire, defective main control board. The part number for the main board is DE92-02256C. Hope I helped you!
Aug 07, 2015 | Samsung DMT400RHS Builtin Dishwasher
Heating Element
Check Fault Codes
Drain Pump
Touchpad
Jul 09, 2013 | Dishwashers
Samsung Dishwasher can drain, but gives "drain error"
Sounds like it could be those same water level sensors you worked on before. Only now its telling the thing that there is water still standing in the unit. Try cleaning those sensors again and I know this sounds obvious but check all your conections.
Jan 08, 2013 | Samsung DMT400RHS Builtin Dishwasher
Samsung dishwasher dmt 300rfb wont drain and is humming
Hello Randy Lowe,
There is an EXPECTED INITIAL failure period
on new equipment...!!
Use your warranty...
Brand new = Take it back & get a GOOD ONE.
Carnac the Magnificent
Apr 22, 2017 | Samsung DMT300RFS Builtin Dishwasher
I shut down my laptop and it said shutting down and turned off. Now when I try to turn it on it won't come on .3 little lights blink in front 3 times and does nothing. nothing shows on the screen and it...
try these 3 steps enable for you to resolve your problem:
1. re-install OS
if that would not work try the next step
2. detach the power cable that is connected to the mother and plug it back in if that would not work try the lst step
3. check for the warranty and have the unit replced by the manufacturer
Sep 11, 2010 | Computers & Internet
The screen blinks fast and slow
Tv starting to take longer to power on?Power light indication in the LCD panel screen blinking?Power supply board,starting to have problems.The power supply board,that the board,where the power a/c cord plug into it.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Jul 21, 2010 | Samsung 40 in. Flat-Panel LCD HDTV
TV INOP
Sounds like you need to replacew the lamp.
Jul 08, 2009 | Televison & Video
Dishwashers Logo
2,379 people viewed this question
Top Dishwashers Experts
