Question about Guillemot Hercules eCafe EC-1000W 10.1-Inch Netbook - Up to 6 Hours of Battery Life (663296415172)
Wireless card install - Guillemot Hercules eCafe EC-1000W 10.1-Inch Netbook - Up to 6 Hours of Battery Life (663296415172)
    Top Expert:
  • 12,223 Answers
You must sure if you have the driver wireless update, otherwise download from your manufacturer supplier and download and install. Of course you must uninstall the old one.the problem is driver is corrupted.
You can run the utility for diagnostic and repair in network coming with your computer and proceed the steps.
God bless you
Posted on Jul 09, 2013
Can get wireless on my dell gx270
Most desktop computers do not have a wireless card installed.
You need to install a wireless card in the expansion slot and install the wireless driver, then configure this wireless card with your router's wireless settings so it can connect to the wireless router.
Aug 11, 2011 | Dell OptiPlex GX270 PC Desktop
I have a new notepad bought in UK. I cant connect to wireless only local connections
The problem could be -
You do not have a wireless card installed.
or
The wireless card drive was not installed.
Check Control Panel - Syatem - Hardware - Device Manager - Network Adapters. If you do not see a wireless card then your laptop does not have a wireless card installed. If you see a yellow ? against the wireless card then the wireless card driver was not installed.
Sep 14, 2010 | D-Link Computers & Internet
Can't install netgear router WGR614 IN AN DELL INSPIRON1594 LAPTOP
The laptop/computer's wireless card may not have the latest wireless card driver installed or it is not enabled and working. Check Device Manager to see if is is working and enabled. I suggest you install the latest wireless card driver.
Next check the wireless card configuration, it needs to have the wireless router's settings, ie SSID and encryption etc.
For instructions on securing and configuring the wireless router and wireless card please click in this link :-
http://www.fixya.com/support/r3559128-wireless_router_security
Dec 23, 2009 | NetGear WGR614 Wireless Router
Wireless card wn5301a not working. installed in an xp machine 1.7GHz P4, 1G ram can see wireless networks & allows me to enter network key, but fails to connect
Is this a new card you've installed or have you reinstalled the OS?
First verify that the card is enabled. Go to control panel, network connections and select wireless. If the button says Enable, click it and your card should communicate.
If there's no wireless setup to enable check the driver:
Go to control panel, select system, hardware, device manager, network adapters and select your wireless card. Then run the troubleshooter to get the card to work.
If the hardware isn't there to be selected, you don't have a driver installed for that card. Go out to the manufacturer's website and install it.
Oct 31, 2009 | Computers & Internet
Laptop states wireless adapter not installed and configured? worked before.
To check if the wireless card is bad or OK.
Go to Control Panel - Network Connections - Is the wireless network connection listed and if so is there a red X on this connection?
If so, right click on the wireless and click Repair - this may fix your problem, it forces the wireless router to issue the wireless card with a new IP address.
If it doesn't fix the problem then go to Control Panel - System - Hardware tab - Device Manager - scroll down to Network Adapters and expand and check your wireless card, is it Working and Enabled?
If has a yellow ? against it or not working then reinstall the wireless card driver.
If the wireless card is built-in check the BIOS to see if the wireless card is enabled, if not enable the wireless card and repeat the above steps.
If this doesn't fix your problem then the wireless card is faulty and you need a new wireless card. You can get a PCMCIA wireless card to replace the faulty wireless card. If the wireless card is built-in then disable the faulty wireless card in the BIOS before you install the new wireless card.
Oct 11, 2009 | Gateway (802.11usb) Wireless Adapter
Can't get wireless to connect
Depending on your OS, you could check the device mang. and if your 802.b wireless is not found, look for other flags or problems.
Turn off your wireless switch and remove and re-install your network system.
If after completed, you do not see the wireless install when loading, remove the wireless card and try again, removing from device mamg., re-booting and re-installing wireless card.
Sometimes the wireless card looses connection and needs to be physically removed, system re-booted and re-installed to work.
If that does not work, try exchanging the wireless card for another.
Removing the entire network from the system and re-booting is the best way. Shoot down after re-booting and re-install wireless card.
Restart unit, if it see's the wireless card, it will show loading network device. If it does not see the card, it will not load it.
Hope this helps
Jul 27, 2009 | ASUS Eee 4G Notebook
Wireless button
The T30 laptops do not have a on/off button that turns the wireless card on.
Once the wireless card driver is installed the wireless card will detect any wireless router and access point within its range. You need to configure the wireless card to connect into the wireless router or access point eg. the encryption, SSID etc.
The Thinkpad laptops have different wireless LAN cards installed, when you install a wireless card driver and it doesn't work, then install a different model wireless card driver. Also make sure the XP or Vista version of the wireless driver matches the Windows version that is installed on the laptop.
Jul 12, 2009 | IBM ThinkPad T30 2366 Notebook
WIRELESS CARD FOR LAPTOP
Hi
Your did not provide any info on which card you have or wish to install; USB, PC Card, or internal mini PCI card.
For mini PCI cards, first you have to open up the D600 laptop and install the Hardware (ensure to connect the antenna cables) then power-up and install the software (drivers and utility).
For USB and PC Cards, follow the device manufacture's recommended steps. Generally, for USB devices, the software (drivers and utility) needs to installed first before the hardware is connected.
If you have successfully installed the hardware and software (driver/utility) you can scan, choose and connect to an available wireless access point or wireless ad-hoc setup. This can be done through the wireless manufacture's utility or from Windows Wireless Zero Configuration utility. If you use the manafucature's utility, Windows Wireless Zero Configuration utility will not work; will not scan or list available wireless network.
Check "Dell Connect To A Wireless Network" article
http://support.dell.com/support/topics/global.aspx/support/dsn/document?c=us&docid=338826
Mike
May 07, 2008 | Dell Latitude D600 Notebook
Installing pc card: 32 bit cardbus WG511
If your laptop is running on XP, sometimes WINDOWS installs the drivers for the wireless card automatically. If WINDOWS do not install the drivers, you need to load or install the drivers of your wireless adapter. You can use the disc that came with the wireless adapter or downloiad the drivers from the website of your wireless adapter
Mar 13, 2008 | NetGear WG511 802.11g/b Wireless Adapter
Guillemot Hercules eCafe EC-1000W 10.1-Inch Netbook - Up to 6 Hours of Battery Life (663296415172) Logo
Top Guillemot Computers & Internet Experts
micky dee
Raghavendra Nagaraj
Raghavendra Nagaraj
ray gallant
Are you a Guillemot Computer and Internet Expert? Answer questions, earn points and help others
