Question about Dishwashers
Samsung DMT - 400 delicate light blinking
Have a 2 year old Samsung DMT 400 RHS. Friday last week it stopped working.We have checked for clogs in the drain hose, took everything apart clean it, No kinks in the hose and it still does not work. It starts to wash dishes, it pumps water when it is supposed to pump water out. Then when it comes almost to the end it pumps water out again stops, comes back on short time later, tries to pump again, can not pump, stops again comes back on tries to pump water out again and now the delicate light comes on and blinks. From what we can tell the pump is working fine, there are no clogs in the drain hose , nothing stopped up and no kinks. Hose is mounted the right highs and still it will not pump the water out. Can anybody help?
    Top Expert:
  • Dishwashers Master
  • 12,223 Answers
Follow this steps and fix it. God bless you
Heating Element
If lights are flashing on the control panel, the heating element might have burned out. The heating element heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element can be checked for continuity with an Ohm meter.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Heating Element Assembly
If lights are flashing on the control panel, the heating element assembly might have burned out. The heating element assembly heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element assembly can be checked for continuity with an Ohm meter.
Check Fault Codes
If the display lights are flashing and there is an error code in the display window, check the wiring diagram and tech sheet in the dishwasher that will provide information on the fault.
Drain Pump
If lights are flashing on the control panel, the drain pump might not be working properly. For two-wire drain pump motors check them for continuity using an Ohm meter. If it's defective You'll need to replace it. Drain pumps are not repairable.
Touchpad and Control Panel
If the lights are flashing on the display the entire touchpad and control panel assembly might be defective. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Touchpad
If the display lights are flickering for no reason, the touchpad might need to be replaced. Sometimes when the touchpad is defective the display lights are flashing randomly.
Posted on Jul 09, 2013
Testimonial: "Thanks, but this those not help. Sorry. But I appreciate your help!"
SOURCE: G892-SC Miele water intake/drain light blinks
The intake/drain light blinks. How do I fix this problem?
Posted on Sep 18, 2008
SOURCE: GE Nautilus won't drain after Rinse Cycle
Check disposer plug. If a garbage disposer has been recently installed, it is possible the disposer drain plug was not removed. The drain plug is a plastic piece in the disposer that blocks the hole where the dishwasher hose connects. Also check the hose connected to the disposal. Mine apparently had a kink in it. When I straightened the hose the dishwasher drained at full speed (I recently had a plumber re-route a hot waterline. He must has bent the hose). Hope this helps. If not go to the GE website. That's where I found my answer.
Posted on Sep 29, 2008
skrbin
  • 121 Answers
SOURCE: Bosch S9GT1B not taking water
check electro valve,water-level switch.
Posted on Feb 15, 2009
  • 111 Answers
SOURCE: Blinking Clean light in Whirpool dishwasher
Control is programmed to stop running and not allow any further cycles if it detects a water heating problem (no temperature increase detected in heated Main Wash on 3 consecutive cycles). Control blinks the Clean LED 7 times repeatedly and disables the Start/Resume key until cleared. Running Diagnostics clears the control and allows it to operate again. The water heating problem must be fixed or the control will stop running again. See potential causes below. Heater circuit problem: ■ Open in heater. ■ Open connection or component in heater circuit. ■ Faulty heater drive circuit on control. 1. Check operation of heater in Diagnostics cycle. 2. Unplug dishwasher or disconnect power. 3. Check resistance of heater and all components and connections in the water heating circuit or heat dry circuit.
dont forget to vote hope this helps thank you
Posted on Jun 20, 2009
SOURCE: Bosch Dishwasher wont drain
Crazy! I have the EXACT same problem....sounds like it wants to drain...but won't ...Water has been stuck in the bottom for days now
Posted on Jul 18, 2009
Samsung dishwasher not pumping water out. "delicate" light blinking and it doesnt appear the pump even tries to come on. the machine just stops after wash cycle then I get the error light.
The Delicate light flashing on Samsung dishwashers indicates a drain error. Possibly a pump/motor assy.
Samsung Dishwasher Not Draining
Doesn't sound like a clogged ECS because it's not draining at all.
Jun 12, 2017 | Samsung Dishwashers
Samsung dishwasher heavy and delicate lights blink and cycle stops
The lights that are blinking are indicating an error code--the particular code you describe is a "heater error". You will have to check the circuit for an open heater element, loose or broken wire, defective main control board. The part number for the main board is DE92-02256C. Hope I helped you!
Aug 07, 2015 | Samsung DMT400RHS Builtin Dishwasher
My Samsung GTE 2370 will not open when I powered it, it only blinks not booting.
Sounds like either the battery is bad or the phone might have water damage.
If you're comfortable opening the phone, I would recommend checking for water damage. You can also try a different battery if you have one around.
If it's under a year old, send it for warranty (average free, 2 weeks) or bring it to a repair shop (average $40-60, 1 week, depending on the store).
Oct 21, 2013 | Samsung GT E2370 - black SAMSUNG
please follow this steps and fix it. God bless you
Heating Element
Check Fault Codes
Drain Pump
Touchpad
Jul 09, 2013 | Dishwashers
Samsung Dishwasher can drain, but gives "drain error"
Sounds like it could be those same water level sensors you worked on before. Only now its telling the thing that there is water still standing in the unit. Try cleaning those sensors again and I know this sounds obvious but check all your conections.
Jan 08, 2013 | Samsung DMT400RHS Builtin Dishwasher
Samsung dishwasher dmt 300rfb wont drain and is humming
Hello Randy Lowe,
There is an EXPECTED INITIAL failure period
on new equipment...!!
Use your warranty...
Brand new = Take it back & get a GOOD ONE.
Carnac the Magnificent
Apr 22, 2017 | Samsung DMT300RFS Builtin Dishwasher
The screen blinks fast and slow
Tv starting to take longer to power on?Power light indication in the LCD panel screen blinking?Power supply board,starting to have problems.The power supply board,that the board,where the power a/c cord plug into it.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Jul 21, 2010 | Samsung 40 in. Flat-Panel LCD HDTV
TV INOP
Sounds like you need to replacew the lamp.
Jul 08, 2009 | Televison & Video
Samsung hl-r5067w 50" DLP no picture
I have a solution for The United States of America! "If We Don't Make It, We Don't Need It".
Personally, I believe if we went back to actually manufacturing things in this country and stopped importing everything, a lot of these problems would STOP!
Think about it America!
Oct 19, 2008 | Samsung DLP HL-P5663W 56" TV
Dishwashers Logo
204 people viewed this question
Top Dishwashers Experts
