Question about Microwave Ovens
Bosch Oven Manual for HBC86Q650 - Microwave Ovens
Bosch Oven Manual HBC86Q650I need a manual for the above oven/microwave
go to www. fitness.manualsonline.com or www. retrevo.com and download for free.
God bless you
Jul 09, 2013 | Microwave Ovens
Bosch combination oven/microwave HMG 8220GB start button doesn't work
This is a door switch problem, one of the door switches has malfunctioned preventing the microwave oven from running.
May 14, 2012 | Bosch Microwave Ovens
The problem is most likely a bad magnetron, "heart of the system" or the inverter board has failed, "if less than 7 years old"
Apr 18, 2012 | Bosch HMT8625GB Microwave Oven
I am just a housewife and asking a simple question. - I have bought an bosch eye level double oven HBM13B - I currently only have available a 13 amp plug. retailer is saying i need to upgrade to 20amp from...
For the oven you are describing, you would be wise to upgrade because chances are you have other feeds that draw from the same circuit, that is why the retailer is suggesting running from the junction box with a 20 amp service, this way you will not have to worry blowing the fuse when you are running multiple items.
Apr 05, 2011 | Bosch Microwave Ovens
Hmv9305/01 microwave @ 13months old the magnetron blew, authorized bosch repairman, replaced using bosch magnetron. warranty for 90 days jan of 2011 same problem, why does this happen? should i ditch...
With all due respect, what are you doing to it?
If you use it with nothing in the cavity, that will kill the magnetron otherwise it will last for years and years.
Very unusual and Bosch is a well respected name.
If there is a probem with the oven, Bosch will replace it so take it up with Bosch.
Apr 01, 2011 | Bosch HMV9305 Microwave Oven
Bosch HBC84K520B Combination Microwave Oven
If you google search bosch gourmet the second item down titled "bosch household appliances" you can download a manual from there
Jun 27, 2009 | Bosch HMB402 Microwave Oven
Bosch Microwave HMT9656AU cuts out
Did you contact a Bosch-authorized service center?
If not, please consult your manual for the number or other contact information for Bosch. They can help you find local, knowledgeable servicers.
There may still be some warranty on some parts.
Or they may help you find local Bosch parts distributors in case you or a friend want to replace the part(s) yourself.
If you do not have your manual, I would contact the dealer where you purchased it to see if they have current contact information for Bosch.
An authorized servicer will have the service manual and is a little less likely to actually test and troubleshoot, instead of just throwing in parts until it works.
Dec 15, 2008 | Bosch HMT9656GB Microwave Oven
Bosch HES435U - Stove Keypad is Locked
Locking or Unlocking the oven control panel
1. Access Select Function Menu
2. Turn knob clockwise until Lock Keys is flashing
3.Touch Start. Key Pad locked is displayed.
4. To unlock keypads, touch cooking mode and hold for 5 seconds. Display will read unlocking key pad
5. When unlocked the clock will again appear in the display.
Apr 29, 2008 | Bosch HLK4525GB Convection/Microwave Oven
Microwave Ovens Logo
65 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
