Question about Kenmore Elite Oasis 7808 Gas Dryer
Not working when you hit any button it turns on and the next button pushed turns it off
    Top Expert:
  • Kenmore Master
  • 12,223 Answers
Follow this steps and fix it. God bless you
Thermal Fuse
The thermal fuse helps to prevent a dryer fire by shutting off power to the dryer if it overheats. If the dryer won't start check this fuse first. Test the thermal fuse with an ohm meter or continuity checker. This is the most common part to fail when the dryer won't start. Once the thermal fuse has blown, it has to be replaced. It can not be reset.
Enter your model number to see parts for your dryer.
Help me find my model number
Start Switch
The start switch is on the dryer control panel. Depending on the model, either press a button or turn a dial to start the dryer. If the start switch fails the dryer won't start or make any noise. Test the switch with an ohm meter or continuity checker. If the dryer hums when the start switch is activated, or if the motor runs only while activating the start switch, the motor might be defective or something might be binding the drum preventing it from turning freely. If the dryer start switch does not have continuity when it is activated, it will need to be replaced.
Door Switch
The door switch is located near the dryer door and is activated when the door is closed. If the door switch fails, the dryer won't start at all. Most door switches will make an audible click when they are activated. If the door switch makes a clicking sound when activated it is probably not defective. If it doesn't make a click, it can be checked with an ohm meter or continuity checker. The door switch is relatively easy to replace and is usually not very expensive.
Drive Motor
On most dryers the drive motor turns the drum and the blower wheel to exhaust the air. If the dryer won't start the motor might be defective. Before replacing the motor, check the thermal fuse, start switch and door switch because all three are more likely the cause. If the dryer won't start and the dryer motor makes a humming noise there might be something caught in the blower wheel, or the drum might be binding. Try removing the belt from the motor and checking the blower wheel for obstructions. The dryer motor can't be tested easily. If the more common components have been checked and it seems the motor itself is defective, it will need to be replaced. It is not serviceable.
Drive Belt
On most dryers, if the drive belt breaks the motor can still be heard and it will still be blowing air out the exhaust tube, but the drum will not spin. However, in some dryers when the drive belt breaks the tension pulley arm trips a switch which shuts off power to the entire dryer. If the dryer won't start, check to see if the belt is broken. If it is, replace the belt and the dryer should be fine. If the belt is not broken, check the other components that can fail when the dryer won't start.
Thermal Cut Out Fuse Kit
Most dryers have several temperature control devices such as a thermal fuse, thermal cut out, high limit fuse or high limit thermostat. Some manufacturers sell the thermal fuse and thermal cut out in a kit. These kits normally solve no-heat problems rather than when the dryer won't start. However, in some models, this kit will solve both problems. Even though this is not the most common part to fail if the dryer won't start, both can be checked using an ohm meter or continuity checker. If they have continuity they are good. If not, they should be replaced.
Incoming Power Problem
If the dryer won't start, check to make certain there is electricity to the dryer. For a gas dryer, unplug the dryer from the wall and plug something else into the outlet to see if it's working. For an electric dryer, check the home circuit breaker or fuses. If they are working, check the outlet where the dryer plugs in with a volt meter. There should be between 208 and 240 volts. If there is power to the dryer, check the more common items in this troubleshooting guide.
Belt Switch
If the dryer won't start, there might be a belt switch that has failed. This is not a common problem and most dryers do not have this switch. If the dryer has a belt switch, the switch shuts off power to the entire dryer if the belt breaks. It is possible that this switch has failed, even if the belt is not broken. It can be checked with an ohm meter or continuity checker. If the dryer works at all, even if all it does is hum, this is not the problem.
Main Control Board
The main control board is normally not at fault when the dryer won't start. First, check all of the other components in this troubleshooting guide before replacing the main control board. The main control board can not be tested and must be replaced if it is defective. If there are obvious signs of burning or a shorted out component on the board, it should be replaced.
Timer
The timer is normally not at fault when the dryer won't start. In many situations where timers are replaced they end up being returned. First, check all of the more common components in this troubleshooting guide before replacing the timer. If the dryer won't start, the cause is much more likely to be a thermal fuse or switch. The timer can not be tested, it must be replaced if it is defective.
Posted on Jul 10, 2013
CD player won't switch to next cd and keep playing
Look for a button that says repeat ...push if to turn it off..if it has schuffle , try hitting that.
Dec 24, 2012 | Denon AVR-1803 Receiver
2006 mazda 3 windows not working
there should be a button next to window button on drivers door that turns the other windows on and off try pushing it once then see if they work it is a safety feature on most cars my daughter had hit this button by accident and thought the windows broke
Oct 11, 2010 | Mazda MAZDA3 Cars & Trucks
I do not have a manual and need to know how to set it up and the code for a vizio tv.
On your remote you will find a setup botton and what i want you to do is hit set up then hit the tv botton and hit channal up and do that untell it turns off your tv are the channal if that works it tv botton again and your remote will work other wise in the back of your remote it well tell you a code number and go on line to philips and they will give your your codes for you.
Dec 09, 2009 | Philips Magnavox Learning Universal Remote
When I try to print from my brother2070 the red paper light keeps blinking but there is plenty of paper in the printer. What's the problem?
Is the paper pushed in all the way? Make sure the paper is firmly pushed into the paper tray, towards the printer.
Do you have too much paper loaded in the feeder? Reduce the paper to about 30 pages.
Hit the cancel button on your printer, or push the button next to the flashing light. If this does not work, power down your printer for 30 seconds. Now turn it on.
You should now be able to print.
Jun 28, 2009 | Brother HL-2070N Laser Printer
Swissgear spyder mouse will not work
Had the same problem with my wife's...you have to push the connect buttons on both the receiver and the mouse almost simultaneously after turning the mouse off and back on. Keep trying, it took me lots of tries.
Jun 07, 2009 | AVENUES The SPYDER SwissGear Wireless...
Can't turn off PIP on Sony XBR videoscope TV
Hit the set up button on the TV.
You'll see options to change the language. The last option is to put the TV in "Demo Mode."
Put the TV in Demo mode, when the first screen appears, "Welcome to...." the PIP will disappear.
Hit exit before the screen moves to the "Menu." If you miss it, watch the demo once--it will restart--and hit the exit button the next time you see the "Welcome to" message.
I just did this and it worked for me - i hope it works for you.
Apr 14, 2009 | Televison & Video
TV will not turn on
Hey guys this one is a no brainer when you push power button AND STANDBY LIGHT COMES ON NEXT PUSH THE BUTTON ON THE LEFT NEXT TO POWER BUTTON AND WALLA IT TURNS ON
Nov 11, 2008 | Televison & Video
Stuck in demo
I had the same issue and was about to give up.
cleaning, key combos and such didn't work out.
Solved the dirty way, as described some comments above:
"Just took the faceplate from the "push-menu" button and hit it against a hard surface [not too hard but not too soft hits] and thats it, it worked again."
ah, the good manners!
Jun 07, 2008 | Aiwa CDC-X504MP CD Player
Time/date set
turn camera on
hit menu button
right arrow one time
and down 7
hit middle button which reads "func set"
then use the up and down arrows to adjust time and date
use the left and right arrows to move to next set
Dec 26, 2007 | Canon PowerShot SD850 IS Digital Camera
Rca412c
THIS WORK!!!!! to make this simpler
1. Hold on TV and POWER simultaneously (light comes on), let go
2. Press POWER then CH+ back and forth (light comes on), when TV turns off
3. press STOP, code is saved!
Sep 25, 2007 | RCA RCR412C Remote Control
Kenmore Elite Oasis 7808 Gas Dryer Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
