Question about Kenmore Elite Oasis 7808 Gas Dryer
When you hit any button it turns on and the next button shuts it off
    Top Expert:
  • Kenmore Master
  • 12,223 Answers
Follow this steps and fix it. God bless you
Thermal Fuse
The thermal fuse helps to prevent a dryer fire by shutting off power to the dryer if it overheats. If the dryer won't start check this fuse first. Test the thermal fuse with an ohm meter or continuity checker. This is the most common part to fail when the dryer won't start. Once the thermal fuse has blown, it has to be replaced. It can not be reset.
Enter your model number to see parts for your dryer.
Help me find my model number
Start Switch
The start switch is on the dryer control panel. Depending on the model, either press a button or turn a dial to start the dryer. If the start switch fails the dryer won't start or make any noise. Test the switch with an ohm meter or continuity checker. If the dryer hums when the start switch is activated, or if the motor runs only while activating the start switch, the motor might be defective or something might be binding the drum preventing it from turning freely. If the dryer start switch does not have continuity when it is activated, it will need to be replaced.
Door Switch
The door switch is located near the dryer door and is activated when the door is closed. If the door switch fails, the dryer won't start at all. Most door switches will make an audible click when they are activated. If the door switch makes a clicking sound when activated it is probably not defective. If it doesn't make a click, it can be checked with an ohm meter or continuity checker. The door switch is relatively easy to replace and is usually not very expensive.
Drive Motor
On most dryers the drive motor turns the drum and the blower wheel to exhaust the air. If the dryer won't start the motor might be defective. Before replacing the motor, check the thermal fuse, start switch and door switch because all three are more likely the cause. If the dryer won't start and the dryer motor makes a humming noise there might be something caught in the blower wheel, or the drum might be binding. Try removing the belt from the motor and checking the blower wheel for obstructions. The dryer motor can't be tested easily. If the more common components have been checked and it seems the motor itself is defective, it will need to be replaced. It is not serviceable.
Drive Belt
On most dryers, if the drive belt breaks the motor can still be heard and it will still be blowing air out the exhaust tube, but the drum will not spin. However, in some dryers when the drive belt breaks the tension pulley arm trips a switch which shuts off power to the entire dryer. If the dryer won't start, check to see if the belt is broken. If it is, replace the belt and the dryer should be fine. If the belt is not broken, check the other components that can fail when the dryer won't start.
Thermal Cut Out Fuse Kit
Most dryers have several temperature control devices such as a thermal fuse, thermal cut out, high limit fuse or high limit thermostat. Some manufacturers sell the thermal fuse and thermal cut out in a kit. These kits normally solve no-heat problems rather than when the dryer won't start. However, in some models, this kit will solve both problems. Even though this is not the most common part to fail if the dryer won't start, both can be checked using an ohm meter or continuity checker. If they have continuity they are good. If not, they should be replaced.
Incoming Power Problem
If the dryer won't start, check to make certain there is electricity to the dryer. For a gas dryer, unplug the dryer from the wall and plug something else into the outlet to see if it's working. For an electric dryer, check the home circuit breaker or fuses. If they are working, check the outlet where the dryer plugs in with a volt meter. There should be between 208 and 240 volts. If there is power to the dryer, check the more common items in this troubleshooting guide.
Belt Switch
If the dryer won't start, there might be a belt switch that has failed. This is not a common problem and most dryers do not have this switch. If the dryer has a belt switch, the switch shuts off power to the entire dryer if the belt breaks. It is possible that this switch has failed, even if the belt is not broken. It can be checked with an ohm meter or continuity checker. If the dryer works at all, even if all it does is hum, this is not the problem.
Main Control Board
The main control board is normally not at fault when the dryer won't start. First, check all of the other components in this troubleshooting guide before replacing the main control board. The main control board can not be tested and must be replaced if it is defective. If there are obvious signs of burning or a shorted out component on the board, it should be replaced.
Timer
The timer is normally not at fault when the dryer won't start. In many situations where timers are replaced they end up being returned. First, check all of the more common components in this troubleshooting guide before replacing the timer. If the dryer won't start, the cause is much more likely to be a thermal fuse or switch. The timer can not be tested, it must be replaced if it is defective.
Posted on Jul 10, 2013
How to fix Error F3-f200-0002 on toshiba windows 7 laptop with recovery media on flash drive
If you still have your recovery partition that the computer came with you can do this:
1. Initially you keep hold the power button for around 5 to 10 seconds to turn off your system. Keep in mind that keep holding the power button force the system to turn off. But any of the unsaved data will be lost.
2. At the similar time press and keep hold the zero key simultaneously, now push the power button one time to switch on your system.
3. While the screen is get appeared then free the 0 key.
4. If it any message to select the 32bit or 64bit operating system then you click Next button.
5. When provoked by the warning screen; click on to the Yes button to keep continue with the system recovery.
6. In that choose Recovery of Factory Default Software from the menu and then hit it off on the Next.
7. Choose Recover to out-of-box state option from certain options and then click Next button once again.
8. Understand and recognize this final warning screen.
9. Now finally click Next to start recovery
Aug 31, 2015 | Toshiba Computers & Internet
My dell laptop says while on hybernating
I don't understand your question. Please re-word in English so it is understandable!
If you mean "My Dell laptop stays on while hibernating" then I would make sure that you are actually hibernating and NOT hitting the "sleep" button.
If you hit sleep or close your laptop then any small movements could possibly wake it up (though you would need to hit the start button to turn it on from sleeping usually)
If you hibernate then your computer saves its current state and shuts off so that way it can resume its current state next time your start up.
Are you positive you are putting it into hibernate and giving it time to shut-down without moving it? (Closing it before it is ready will tamper with the process at times)
Nov 20, 2014 | Computers & Internet
Why did this turn off by itself?
You may have a problem in the audio output chips in the unit, first check the speaker wires on the back for shorts, a common problem, if okay you will need a technician to take it to the next step.
Sep 05, 2012 | Audio Players & Recorders
Ati2dvag.dll blue screen error and dont shut down the PC
It's a problem with the video driver, device driver. ATI
Here's the fix for the infinite loop problem caused by ati2dvag.dll that has worked for some others.
Right click on My Computer
Choose Properties
Choose the Hardware(Tab)
Choose Device Manager(button)
Click the [+] next to System devices
Right click on CPU to AGP Controller
Choose the Update Driver(button)
Select Install from a list or specific location (Advanced)
Choose Next(button)
Select "Don't search. I will choose the driver to install."
Choose Next(button)
Select PCI standard PCI-to-PCI bridge
Hit Next(button)
Hit Finish(button)
Reboot.
This should resolve your issue.
Jul 02, 2010 | Computers & Internet
Sylvania LD320SSX turns off by itself.
your powersupply is dying in the set.. have it checked..
Apr 10, 2010 | Sylvania LD320SSX LCD TV
Can't get the Hourly chime to shut off - tried going to alarm, then hitting adjust Button - alarm shuts on or off , but not Chime
using the mode button (lower left, go to the alarm. once at this screen, hit the "12/24H" button (lower right). now hit the "adjust" button (upper left), that should toggle the hourly chime on and off. you'll see the bar next to 'SIG'. when it's lit, it's on, when it's blank, it's off.
Oct 27, 2009 | Casio Illuminator AQ150W1EV Wrist Watch
My rca lyra keeps turning on and off and when i hit the play button it shuts off and turns it self back on It turns on and starts to play but will shut off or if you try to go to the next song it shuts...
How old is the Lyra, sounds like the battery isn't charging or is in need of replacement...
You could have a look here > http://www.rcaaudiovideo.com/product.aspx?product=410
May 28, 2009 | RCA Pearl TH1102 MP3 Player
My desk top hp pavillion will not turn on
Hold the power button in on the computer for 5 seconds. Wait another 5 seconds. Now hit the power button as you normally would to turn the PC on. It should boot normally.
Dec 30, 2008 | HP Pavilion a1410n (ER890AA) PC Desktop
Toshiba 62hx94 cant shut off closed caption have comcast cable How do I turn off closed caption on my TV. It suddenly turned on.
if the tv is not hd then the control is on your tv.
However if the comcast box is an hd box do the following;
Press cable, then power and then with 2 seconds press the red menu button to get the hidden hd user setup menu. You may have to hit the menu button multiple times to get the menu to stay up on the tv.
Next go down to closed captions which is probably enabled, and hit the left or right arrow key to change it to disabled.
Then press the power button twice to turn the box off and back on.
Dale
Dec 26, 2008 | Toshiba 62HMX84 62" Rear Projection HDTV
Kenmore Elite Oasis 7808 Gas Dryer Logo
53 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
