Hotpoint wt741 Washing machine over fills then leaks out. Coming up 1420 on code
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 48 Answers
Not sure about the code but there are 2 reasons for a unit to overfill. 1 if the inlet water solenoid doesn't shut properly and leaks. You would probably know this as the unit would fill overnight. Also check that water doesn't come in with power on but cycle not running ie. shorted solenoid. 2 the pressure switch, either a problem with the tube being loose or split etc or the switch itself being faulty Of course these problems can always be the main pc board but these are the more common causes.
Posted on Jul 09, 2013
SOURCE: error message f-01 on hotpoint ultima wt741 washing machine
F01 is a motor faulty normally caused by the module,but sometimes thewiring to the motor plug that works loose as its to tight,give them alla good wiggle make sure there all in!
check this link for other error codes of hotpoint machines
http://www.hotpointservice.co.uk/hs/pages/content.do?keys=FAQ:ERROR_CODES
Posted on Dec 15, 2008
barkencoa
  • 3463 Answers
SOURCE: f03
Good morning.
Error code F03 means that the wash thermistor is open circuit, this means that the water is not getting hot.
You need to fit a new thermistor first of all, if that does not solve the prob, then you will have to fit a new heater element as well.
You will normally find the element and thermistor located at the rear of the m/c.
Access it by removing lower rear panel
To get the parts, go to-----www.hotpoint.co.uk
Plz rate my solution.
Thanks.
Posted on Jan 19, 2009
barkencoa
  • 3463 Answers
SOURCE: Hotpoint Washing Machine WT741
Error code F12 is indicating a communications error between cards, this can be caused by one of several things..
A problem with bad connections, if you can remove and then replace the plug on connectors, check for loose or chafed wires to motor, they can chafe due to tightness of wires, particularly down to the motor.
It is a electrical problem as opposed to a mechanical one.
If you cannot eliminate the problem your self, then i'm afraid your only other option would be to call an engineer out, it can be a difficult problem to pinpoint correctly.
Please leave a rating for my suggested solution.
Thankyou.
Posted on Jan 30, 2009
  • 9 Answers
SOURCE: Leak from under the washer
tub seal has gone bad, will only get worse. Expensive fix,
Posted on Jul 02, 2009
barkencoa
  • 3463 Answers
SOURCE: hotpoint ultima F-05 errorr appears on machine
Error F05 indicates pressure switch jammed on full.
Remove lower rear cover of washer.
Locate and remove large black hose fastened to drum.
Remove and clean filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well.
This should solve the problem.
Posted on Jan 10, 2010
Wt741 machines drum
It is possible the motor start capacitor has failed. Unless you know how to test it, call a service person.
Oct 19, 2013 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima wt741 f10 fault code
  • F10 - No cold fill. Check that the taps are on or if the drain hoses are kinked / blocked.
Apr 10, 2012 | Hotpoint Washing Machines
Hotpopint Washing Machine WT741 flashing F-12
Resolved the problem.
Switched off the power to the machine. hit the on /off button and the f-12 error code disappeared .
On reappling the power to the machine the orignial programme continued to completionj
Jan 29, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint wt741 f11 what does this mean
Hotpoint Error Codes.
Hotpoint washing machines are among the most common found in the Uk and like any mechanical device they will occasionally breakdown or develop a fault and need repairs.
Being a very popular make means that most parts supplier will keep there parts in stock and because so many suppliers keep Hotpoint parts stock this also drives competition hence driving down the price of parts if you should ever need them
One problem many people including some engineers face when faced with a faulty Hotpoint washer is knowing what the error code mean, so here are a list of error codes and there meanings for Hotpoint washing machines
These error codes can some times have a E in front of the number and not a F as shown here, but the meaning of the code is still the same
# F11 - This means there is No hot fill.The ambient temperature is probably below freezing perhaps due to the plumbing becoming frozen. Also verify that the taps are on or if the drain hoses are kinked.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Dec 26, 2008 | Washing Machines
Error message f-01 on hotpoint ultima wt741 washing machine
Dec 15, 2008 | Hotpoint Ultima WD72 Front Load...
f11 keeps flashing door won't open
Sep 01, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint WT741
turn the machine on while pressing the on annd stat buttons at the same time until dOFF appears.
Apr 20, 2008 | Hotpoint Aquarius WD640 Front Load...
Leaking wt741
This is a European Model mostly sold in the UK for about $250 pound I cant find any books or manuals on this model you might want to check some UK websites
Jan 24, 2008 | Washing Machines
washing machine WT741 ultima all light are flashing and it won't do anything else
Nov 12, 2007 | Washing Machines
Washing Machines Logo
44 people viewed this question
Top Washing Machines Experts
