Question about GE Advantium SCA2001BSS Microwave Oven
Repair microwave coming on, but not heating produck
    Top Expert:
  • GE Master
  • 12,223 Answers
Please see this details and fix it. God bless you
1. No power to outlet (overload or fault in microwave or other appliance).
2. Blown main fuse - likely due to other problems.
3. Open thermal protector or thermal fuse.
4. Defective controller or its power supply.
5. Clock needs to be set before other functions will operate (some models)
Posted on Jul 09, 2013
Runs but does not heat the food.
Microwave Not Heating Troubleshooting Guide - YouTube
? 2:45
https://www.youtube.com/watch?v=_3SbJueEn1w
Aug 31, 2012 - Uploaded by Repair.com
Allow the circuitry to dry out by avoiding stovetop cooking for a few days. .... it to microwave, but its just not warming up myfood at all, any idea on how i can .... Everything works except themicrowave- it wont heat anything up.
Microwave Diagnostic - Has Power Not Heating - GE ...
? 2:34
https://www.youtube.com/watch?v=E_iUYIV8wD0
Aug 9, 2013 - Uploaded by ApplianceVideo.com
Microwave Diagnostic - Has Power Not Heating - GE, General ....internals of a similar GE Microwave unit that would not heat food.... Sometimes it turns on, sometimes it doesn't. .... My GE microwave space saver does not heat but it comes on. ... What's Inside A Microwave Oven (Teardown / Taken Apart) ...
Nov 18, 2015 | Microwave Ovens
Microwave fully operational but does not heat
Most probably the Magnetron has failed. Microwave ovens are relatively cheap these days, so usually not economical to repair.
Mar 02, 2014 | Microwave Ovens
Microwave will not heat
If the microwave is 7 years old or less, there are too things that come to mind, defective magnetron, or the inverter board, cost should be considered when going ahead with repairs.
Jun 27, 2012 | Goldstar MV-1526 Microwave Oven
My microwave comes on lights work but doesn't heat food
The most likely cause is a defective magnetron, "heats food" cost to repair will be close to a new microwave oven.
Jun 02, 2011 | GE JE1540 Microwave Oven
My microwave is no longer putting out any heat
The problem could be caused:
top door micro-switch
or
Answer: First, make sure your microwave is plugged in and getting an ample supply of power. If the power is on, but it does not work check to make sure the door closes and aligns properly. Microwave door switches have metal terminals on the end that make contact with the door hook or latch. This completes the circuit which allows the microwave oven to run and without this contact the microwave will not operate. A simple misalignment might be breaking the circuit causing the microwave not to operate.
If you suspect that the thermal fuse has blown, call a professional appliance repair person. Even an unplugged microwave oven can kill or seriously injure someone. This is because there is a high energy capacitor inside the microwave oven case. If it is not discharged properly, you could be electrocuted.
If your microwave buzzes or hums but does not produce any heat, it could be a faulty defective diode, triode, high-voltage capacitor, or even a faulty magnetron. However, this problem usually means a bad means a bad magnetron, followed by a bad diode. Call a professional appliance repair person for assistance.
Warning: Microwave ovens are probably the most dangerous of consumer appliances to service due to the very high voltages (up to 5000 V) at potentially very high currents. If you have any doubts about your knowledge and abilities, replace the oven or have it professionally repaired.
Oct 06, 2009 | KitchenAid KCMS185J Microwave Oven
My microwave oven is not heating the food
HI, you will need to replace the heating device. This device is called the Magnetron and, it will cost you about $133.00. This is a repairable issue but, you will need to call for service. I do not recommend installing this device if you are not familiar with handling this type of tech.
May 30, 2009 | Frigidaire FMV157GM Microwave Oven
Microwave not heating food
It's most likely the Magnetron. The are not very easy to install and quite expensive. Older models magnetrons cost about 80 bucks from GE. It's probably not something you would want to try and repair yourself. Call a GE service person.
Feb 03, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Whirlpool Microwave no longer heating
Sounds like the magnetron has failed. It is the magnetron that generates the microwaves that heat the food. If it or the circuit that powers it fails then it stops heating. There are some high voltage circuits that feed the magnetron and you can potentially get hurt if you don't know what you are doing. Would recommend you have it serviced by a professional if you want it fixed, otherwise look for a new one since the cost of repair can come close to the price of a new microwave oven.
Jan 10, 2009 | Whirlpool MH1170XS Microwave Oven
Not working
When the microwave sounds okay, but there's no heat, one of the internal door switches, the high voltage circuitry, or the circuit board may have a problem. To resolve this problem, you need the assistance of a qualified appliance repair technician, as repairing microwaves is a pretty risky job.
Oct 05, 2008 | Microwave Ovens
GE Advantium SCA2001BSS Microwave Oven Logo
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
