Question about Dryers
Aritech alarm sensors
My Aritech house alarm wire system is working with the exception of the connection on my front door which fails to operate. Is it possible to obtain new connection/sensor so that the door alarm will work.
    Top Expert:
  • 12,223 Answers
Go to www. repairclinic.com and get it.
God bless you
Posted on Jul 10, 2013
3 Suggested Answers
  • 1122 Answers
SOURCE: Dryer won't start - Whirlpool LER7646EQo
IF THE DRYER DOES NOTHING AT ALL I WOULD SAY YOUR MAIN FUSE HAS BLOWN,IT IS ON THE BLOWER BOX AND IS WHITE,YOU CAN REMOVE THE BACK PANEL AND CHECK IT WITH AN OHMS METER,IF YOU GET NO READING IT IS BAD,LET ME KNOW-MIKE
Posted on Feb 23, 2009
  • 351 Answers
SOURCE: Need replacement part for front dryer door sensor - broken
i sell parts online you can visit whirlpoolpartssurplus.com and get the phone number off there and i can order it for you
Posted on Jun 26, 2009
Home wired system with 8 units goes off in cold weather without any alarming conditions. Does cold weather effect their operation?
Check each of the sensors one has failed or it also alarms on low temperature and you are cold enough to trip it.
Jan 11, 2015 | Heating & Cooling
Wired in home system. window sensor is not operating.
Alarm door/window sensors of one of two types - magnetic and microswitch, both are available at retail stores (hardware and electronics stores sell them) - verify type of switch: magnetic has two parts one attached to door/window while the other is attached to the frame (and in turn this part is hardwired to your alarm system control unit); the micro switch type is one part on frame *usually under window, or on hinge side of door* - harder to replace due to how they are mounted - but can be replaced.
Either type use two wire connection - basically a positive and negative wire loop via the sensor.
Purchase new sensor of same type - and replace faulty sensor.
Sep 22, 2014 | Computers & Internet
Aritech dr569 owner manuel
rikain.com/Manuals/Intruder_alarms/Aritech/TD8803_programming.pdf
Jul 14, 2014 | Sewing Machines
Removed alarm system; now phone won't work
In the alarm system there was a jack called an RJ31X. This jack is suposed to have the line run from the teleco interface to it and then back out to the rest of the house(except for DSL, it stays ir front of the alarm jack). When the alarm jack was cut out the line bridge was eliminated. To make the line active find the wire that went to the alarm jack and and connect the red wire to the yellow wire and the green wire to the black wire. that should pass the line through to the remainder of the jacks in the house.
Oct 13, 2009 | Lands Phones
Starter button quit
hello. if this an electric dryer, here are the possibilities, if it is a gas dryer get back to me.
If your dryer doesn't work at all, it could be because of problems with:
Power from the house
Door switch
Thermal fuse
Wiring
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
Door switch If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.
Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Wiring Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Aug 13, 2009 | Dryers
Dryer will not start
Door switch
Thermal fuse
Wiring
Apr 01, 2009 | Kenmore Dryers
Will not turn on
check out the following cause =
Door switch
Thermal fuse
Wiring
good luck..........
Mar 28, 2009 | Whirlpool Dryers
Dryers Logo
51 people viewed this question
Top Dryers Experts
