Fisher and Paykel GW 6`2 - Washing Machines
  • lindacmayer
    lindacmayer Jul 09, 2013
    I have a ~ 4yo Fisher and Paykel GW612 washing machine that stops after ~ 30secs and beeps with flashing lights no. 1 and 7.
fanny
  • 146 Answers
SOURCE: Fisher & Paykel GWL10 US won't spin
If the machine still has water in it, the drain pump is jammed or there may be an obstrution in one of the hoses. It is most likely the drain pump. Switch off the machine at the wall and unplug it. Tilt machine against a wall and look underneath. On the right you will see the drain pump. It looks upside down. Unplug the wiring harness to the pump and remove pump by turning it clockwise while at the same time releasing the little white clip that holds the pump in place. Clean thoroughly and replace pump.
Posted on Nov 03, 2007
  • 12 Answers
SOURCE: Fisher & Paykel GW711 Washer
If you brought this machine new, then you should find a service manual under the display panel
You will need to remove the panel, Next to inlet valves you should find a maual in a plastic cover...
Posted on Jul 18, 2008
  • 4 Answers
SOURCE: Have a fisher & Paykel
Go to similar problem posted by ronnelini on Sept 8 2008, and see my suggested solution.
If you're lucky it could be a quick and cheap fuse replacement.
Good luck.
DIY Eddie.
Posted on Sep 16, 2008
  • 106 Answers
SOURCE: fisher and paykel gw509 not draining, pump is clear
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Posted on Mar 04, 2009
MNfisherman
  • 11896 Answers
SOURCE: fisher paykel GW 11, no power to panel.
You will have to check the power from power supply to relay to control panel. You can check for voltage with multi-tester or voltmeter
Posted on Jul 07, 2009
Model gw 712. Why are lights 3, 5, 7, and 8 flashing?
Hotpoint, GE, RCA Washer Repair - Does not spin or drain ...
? 6:13
https://www.youtube.com/watch?v=69az-ZA3eSQ
Jul 10, 2013 - Uploaded by ApplianceVideo.com
Hotpoint, GE, RCA Washer Repair - Does not spin or drain - VWSR4150DAWW ... Fisher & Paykel ... my washer won't drainnor spin. what is the problem? .... But in the end, this video helped me fix our washing machine.
How to repair a Fisher Paykel Washing Machine
www.instructables.com/.../How-to-repair-a-Fisher-Paykel-W...
InstructablesHow do I remove the lid on a F&P intuitive eco washing machine to get to the motor panel?? IMadeIt ... It runs until the spin cycle and it drains but won't spin.
Dec 18, 2015 | Fisher and Paykel Washing Machines
Just replaced bearings and seal in GW 612 fisher and paykel washing machine and now wont spin and lid doesnt lock
if the bowl is stilf to turn when stator cover is off by hand, remove agitator give the end of the shaft a hit with a hammer and punch and the same thing at the other end of the shaft to free it once stator cover is removed assemble and try again
Jun 03, 2015 | Fisher and Paykel Washing Machines
Fisher and Paykel Washer GW 609 when switched on at wall keeps pumping
The best bet is to have an authorized serviceman test the control board for continuity. It is out of phase and cannot reset to the normal start position.
Feb 27, 2014 | Fisher and Paykel Washing Machines
MY FISHER AND PAYEL GW 712 WASHING MEACHAINE IS NOT SPINNING AT ALL
I have a Fisher & Paykel GW712 and had same problem and fixed it today the drain pump motor had failed although it worked for 1 full cycle. when I tried to wash a second load the water would not completly clear from the machine I finally replaced the pump and now works correctly the pump is easy to install ensure machine is disconnected from power first
Mar 27, 2011 | Fisher and Paykel (IWL12)
Fisher & paykel GW 703-U water flow and the engine sounded choked
sounds like out of balance switch is faulty. does the water start stop start stop then machine beeps. if it does it is most likely out of balance switch.please reply 4 more help
Mar 12, 2010 | Fisher and Paykel GWL11 Top Load Washer
Have a fisher & Paykel GW 501 - u Washing Machine which has gone dead. No power is coming and the diplay p.anel is also dead
Good luck.
DIY Eddie.
Aug 10, 2008 | Fisher and Paykel Washing Machines
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
