How do I remove the timer knob for this machine zanussi w1242w
    Top Expert:
  • Washing Mach... Master
  • 12,223 Answers
You must use small scredriver, and see if there are small screw and proceed according. God bless you
Posted on Jul 10, 2013
mikedurland
  • 481 Answers
SOURCE: replacing timer
  • push the timer in and turn it counter clockwise. this should unscrew it.
  • if that does not work, check the back of the timer for a black plastic tab. pull it out to unlock the timer knob from the timer.
  • there are many different styles of timer knobs.
Posted on Jun 29, 2008
battlesmith
  • 382 Answers
SOURCE: Zanussi washing machine Jetsystem 1000 model FJ1093 - stuck timer?
The Timer needs to be Replaced,Which can quite easily done..If you plan to do it by calling Service person he might get you the Timer KNOB or else if you plan to do it by yourself Then you can order the Part from this link CLICK HERE
Thank you!!!...Regards...!!..
Posted on Jul 30, 2008
gary1121
  • 332 Answers
SOURCE: Removing the Push-to-turn-on knob
if you pull on the knob it will come off it has a metal clip that is pretty snug on the stem but it will come off, you still have to take the cack cover plate off to get to the switch and do the actual replacement
Posted on May 29, 2009
beltronic205
  • 1466 Answers
SOURCE: changing drain hosezanussi w1242w
It clips onto the pump , you undo the clip remove hose refit and reclip same checking for any leaks before running machine, its very simple to do .....
Posted on Apr 13, 2010
  • 1937 Answers
SOURCE: removeing timer switch knob
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.########) and you'll see a list of major sub-components with diagrams and parts.
See the following for how to release the console:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=d09053515715195798276a5664b79cf0
Also see the Whirlpool / Kenmore Service Manual for top load, direct drive washers:
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
If this is a basic top load, direct drive washer, these units may have one of two different timers. (See the Whirlpool PDF).
On models with a metal timer, you have to release the console, pull it forward and tilt it back in order to get to the back of the timer.
The knob screws onto a medal shaft that goes through the timer.
Usually, trying to un-screw the knob won't work by itself since the shaft will also turn.
I found that if you hold the back of the shaft with a thin needle-nosed pliers, you can unscrew the knob.
Then you simply have to disconnect the timer.
The Whirlpool PDF also has troubleshooting and testing procedures for the timer.
Posted on Jun 08, 2010
Remove knobs zanussi zwf 1621 w
some timer knobs had pop on front cover on knob the 2ba nut on inside of same.
Apr 09, 2015 | Zanussi Washing Machines
Zanussi zwf1421
Thermostat or heater most likely causes. Does timer button move round without doing anything? Timer knobs on Zanussi notorious for breaking off inside.
Apr 28, 2012 | Zanussi F1245W Front Load Washer
What is required to replace rear drum bearing
You need to replace both the drum bearings and the water seal as well, and it may be neccessery to replace the drum and shaft if is worn, but you will not know until the m/c is stripped down.
It is not a repair to be undertaken lightly, if it is more than 5 years old, best option is to replace the washer.
Nov 03, 2010 | Zanussi W1242W Front Load Washer
My zanussi TC7103 s dryer , timer dial is very stiff, and now sometimes sticks when on so that the dryer just keeps going and does not automatically switch off.
i think the timer knob will be binding in the facia panel. you could try working some washing up liquid round the knob to free it up (not oil) the timer may still be damaged but freeing the knob is worth a try a new timer varies from around £37
Jul 25, 2010 | Zanussi TC7114W Electric Dryer
Changing drain hosezanussi w1242w
Apr 13, 2010 | Zanussi W1242W Front Load Washer
Zanussi w1242w takes circuit breaker out when it goes into tumble dry
Here is a tip that I wrote that will help you ti find out why the circuitbreaker is tripping.
Circuit Breaker Keeps Tripping
heatman101
Nov 22, 2009 | Zanussi W1242W Front Load Washer
Washer dryer sticks on j cycle does not spin or drain
check no foreign object stuck in pump impellor and that it turns freely. if that is ok then check continuity thro drain pump. if no muiltimeter, try connecting drain pump to mains direct to see it works
Aug 21, 2008 | Zanussi W1242W Front Load Washer
DETATCHED DRIVE BELT
this is a split cabinet and you have to remove the rear section of the cabinet. take top of undo all bolts holding rear cabinet plus one bolt each side at bottom underneath a blank and two bolts at rear bottom of machine. sounds difficult but in fact is easy
Feb 26, 2007 | Zanussi W1242W Front Load Washer
The fabric softener doesn't go in...
The detergent dispenser is located above the detergent drawer. A water pipe is connected to it and water entrance and distribution to drawer's cells (following the programmed cycle)are done by a lever's movement (part of the dispenser). The lever movement is controlled by two solenoids that received their power from the timer. By opening upper machine's cover you will have an access to the dispenser. Disconnect the power cable from the machine before moving to next test !!!! Look first that they are not any disconnected wires. Move manually dispenser's lever and see if water running to all cells (depend on your movement). In case it doesn't work properly remove the unit from the machine and try to clean it (I hope it will help, otherwise you should replace the unit). In case it works properly (manually) - you should test by a multi-tester solenoid's resistance. the one that doesn't have a resistance measurement should be replaced. Good luck !!
Nov 12, 2006 | Zanussi W1242W Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
