Question about Konica Minolta bizhub C250 All-In-One Laser Printer
IU The copy machine didnot work and appear this error Replace IU. K what is that mean and what I can do to fix it? Thanks
  • 47 Answers
Replace black Imagin unit drum
Posted on Jul 11, 2013
How can I clear Error code E000000
First clear that error from service mode. Press additional function
press 2 and then press 8
press additional function again
service mode should appear in screen
select "clear"
select "engine"
select "Errlcr"
select ok.
unplug power cord for a few seconds and restart the machine,
try to make some copies if problem persist replace the fixing heater assembly
May 14, 2014 | Canon Imagerunner 2525
How can I solve error code c255A
From another site
Details Subject:
C-255A (C255A), C-255B (C255B), C-2559 (C2559) or C-255C (C255C) at power up.
Description:
C-255x code at power up.
Solution:
CAUSE: The K (black) IU (C-255C) has failed. The M (Magenta) IU (C-255A), Y (Yellow) IU (C-255B) or C (Cyan) IU (C-2559) is not fully seated or has failed.
SOLUTION: Replace the K (black) IU (Item #A0DE02F for the bizhub C203/C253 and Item #A0DE03F for the bizhub C353). Reseat the color IU and if the problem persists, replace it. Item # Color IU Model
A0DE0CF Magenta bizhub C203/C253
A0DE0DF Magenta bizhub C353
A0DE06F Yellow bizhub C203/C253
A0DE07F Yellow bizhub C353
A0DE0HF Cyan bizhub C203/C253
A0DE0JF Cyan bizhub C353
SPECIAL NOTE: Solution contribution by Tom Kelly, Workgroup/SSD
Options:
None Specified Details Subject:
After toner installation, C255x code within a few hundred prints.
Description:
C2551, C2553, C2555 or C2557 codes.
Solution:
CAUSE: Toner is not supplied due to abnormal position of coupling.
Normal condition The coupling is blocked by bracket
May 03, 2014 | Konica Minolta bizhub C250 All-In-One...
Fixing unit error e000 0000
Its been a while since I worked on it but that means fixing unit is bad.
Apr 29, 2014 | Canon imageRUNNER 3300 All-In-One Laser...
C2557
C2557 ATDC Sensor Failure
• The scanning value of the ATDC Sensor is less
than 7 % while the IU Motor is turning.
• The scanning value of the ATDC Sensor is more than 19 % while the IU Motor is turning.
This is form the service manual, The meaning is developer material or the worst case you should change the entire ATDC sensor.
Jan 23, 2014 | Konica Minolta bizhub 350 All-In-One Laser...
How to solve konica minilta c224 machine c2558 error
SHAKE THE BLACK IU VERY WELL Clean Imaging Unit Contacts RUN GRADATION
UPDATE FIRMWARE
REPLACE BLACK IU
Jun 29, 2013 | Konica Minolta Bizhub C224 Color Copier...
Samsung scx6555n showing error #31-007
I have encountered this problem twice on the same machine with different imaging units. I haven't received an answer from Samsung (presumably they will fix with a firmware update, their solution to everything) but the message and the red light can be cleared by powering down, reseating the the IU and powering back up. The good news is the user can still use the machine, even with the code.
Sep 13, 2012 | Samsung SAMSUNG SCX6555N LASER...
Canon MX328 Error code appear "5B00" what does it mean and how can i fix that error? thanks. jodans
not work, in display printer shows error 5b00. I can't go to nv ram setting. Can you help me?
Feb 08, 2011 | Canon Office Equipment & Supplies
While copying, system error E007 appears and machine stops immediately. As machine stops copying paper also get stuck.
E007 Fixing film rotation error
Inspect fixing film for damages
Main Cause/Symptom: Fixing film sensor failure
Countermeasure:
- Check the connector of the fixing film sensor.
- Replace the fixing film sensor.
- Replace the DC controller PCB.
Feb 02, 2011 | Canon iR 2016i Black and White Copier
I get an E140 error message when I turn on the copier
Hello sir; The error code you display it means optics fan not working you have to replace it.
Aug 28, 2009 | Panasonic FP-7735 Black and White Copier
Sharp AL-1631 has 3H error code
3H error means overheating...what you can do is supply new fans or clean the unit for dust and others. check for the exhaust fans if its still working. this will reslove your problem.
hope this helps
Jan 27, 2008 | Sharp AL 1631 Copier
Konica Minolta bizhub C250 All-In-One Laser Printer Logo
42 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
