Question about Samsung SyncMaster 753S 17" CRT Monitor
120hz I only get 84hz out of my 120hz help? i want to know how to change it
Hitachi led 65" TV have maximum 120hz.but I can get only 60 hz.how to setup to 120hz..plx help me
The television panel itself is a 120hz panel, and it should be understood that regardless of the picture being fed into the television, it will always display at 120Hz. There will also be some signals being sent at different resolutions, such as 480, 720p and 1080i/p. Since the panel is a 1080p panel, the picture will also be upgraded to a 1080p picture, regardless of the source.
What you're seeing in the INFO bar are the Hz-ratings that are being sent to the television. Most sources will generally send a 60Hz signal, some will send a 24Hz signal, but all of them will be upconverted inside of the television to 120Hz. This is done by internal processing inside of the television.
Jun 13, 2016 | Hitachi Televison & Video
Rca led tv shows military time is there a way to change it to regular time?
Having the same damn problem it's not in the settings menu or I would have changed it would need to know how to change this to regular time it's very annoying
Feb 20, 2014 | RCA LED55C55R120Q 55" 1080p 120Hz LED HDTV...
I've recently ordered a Proscan PLED5529A 55" 1080p 120Hz LED HDTV, However, a Proscan PLED5529A-B 55" 1080p 120Hz LED HDTV was sent. What is the difference? One difference i've noticed in the...
Same issue here. I'm debating to send it back as most specs are pointing to the A-B model as being 60Hz. I can't really tell of it's pushing 120 or 60 (ignoring the fact that the screen says 60Hz.) It almost "feels" like it's 120 but can't say for sure. Can anyone please confirm that the "A-B" version is indeed 120 or not? Thanks!
Mar 02, 2013 | Proscan Televison & Video
HANNspree 42" 1080p 120Hz LCD
If its still under guaranty take it back.
Sorry couldnt be of more help.
Apr 07, 2011 | Hannspree ST42DMSB 42 in. LCD TV
I'm wondering how to make it run 120Hz. i rented the tv on the promise that it is 120Hz
Many LCDs you find today have 120hz panels, with a 60hz link to your media (eg, a PS3, Bluray player, or Computer). The panel will always run at 120hz, giving you less ghosting and blur in high-action films and games; however very few TVs can support a 120hz link to a PC (which will additionally require a Dual DVI-D cable in order to support the kind of bandwidth necessary to drive an LCD at 1920x1080@120hz). There is usually no noticeable benefit of having a 120hz source unless you're using stereoscopic equipment.
Mar 14, 2011 | Televison & Video
Avol ALT42FD120 - frame rate change 60-120hz?
Hi. It is entirely possible that the set is already running at 120Hz after all. The display 1080p 60Hz is merely the signal it is receiving and the earlier TV's that used to claim 100Hz/120Hz merely did so using line doubling only to give a clearer picture by filling in the blanks between scanlines. If your picture is already very clear, then I wouldn't worry about it
Mar 21, 2010 | Samsung 52 in. Flat-Panel LCD HDTV
LCD outputs 120Hz, but only 60Hz when PS3 is connected via HDMI
CODTerroist,
How did you fix this issue??... I need help please
thanks
Jun 22, 2009 | Sony PlayStation® 3 (60 GB) Console
DOES PLASMA TV HAS 120HZ AUTO MOTION PLUS
This particular model has a 60Hz refresh rate. At this point there are no broadcasts or video sources outside of special labs that can generate enough data to produce a refresh rate of 120Hz. Expect this to become available in a year or so. Please realize that the human eye can not see changes faster than about 30 frames per second. The current standard refresh rate of 60Hz is twice that. The only change you could see (unlikely) would be a slightly smoother flow for fast moving scenes. Typical movement on the screen will not likely see a difference.
Dan
Mar 16, 2009 | Samsung PN50A650 49.96 in. Plasma HDTV
Analog out of range 77khz / 120hz
Make sure you have the latest version of DirectX and 3D glide installed on your computer. You can also try adjusting the monitor frequency from control panel to something a bit higher. That should help.
Let me know how it goes. If the solution worked, please rate a fixya, if not, please post back before you rate , so we can troubleshoot further..
Also you can try lowering the ressolution in the game..
May 27, 2008 | Computers & Internet
Samsung SyncMaster 753S 17" CRT Monitor Logo
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
