240v power supply aw4416 - Computers & Internet
No 12volt supply unless connected to 240v mains
the power invertor could be the peoblem, or the fuse to the `12 volt supply sockets
Nov 09, 2014 | RVs
Replace power supply
Are you sure the power pack has failed? That should be straightforward and fairly cheap. Note carefully the model and type on the present one, then shop around.
  • Power Supply
    Internal 220W (100V-240V)
    Form factor: Internal for slim form factor
  • Total wattage: 220W
  • Nominal input voltage range:
    • 100-127V/6A (50-60Hz)
    • 200-240V/3A (50-60Hz)
  • Dimensions: 200mm x 85mm x 53mm (7.9 x 3.3 x 2.1 inches)
  • This power supply has an LED to indicate a possible failure condition when the LED is off and power is connected.
Feb 20, 2014 | HP Pavilion Slimline s5710f Desktop PC
Connected alesis sr16 with alesis 110v power supply.to 240v mains...........briefly powered up and then nothing. Have I "fried" the adapter or the sr16?
Look carefully at the adaptor and see if it takes any voltage besides 110 (it will say in very tiny print, you will need a magnifying glass). if it does NOT say 220V or 240V then you friend the adaptor. Get another adaptor - most are "dual" voltage meaning they run in the U.S. or overseas.
Also check for "polarity" (which part of your plug is + or - ).
Jan 24, 2013 | Alesis Sr 16 Stereo Drum Machine
Factory reset for the yamaha aw4416 workstation
The original factory settings of the AW4416 can be restored by recalling Scene Memory '00'.
1) Press the [SCENE] button in the 'AUTOMATION' section.
2) Press the [F1] button to display the 'Scene Mem' page.
3) Turn the (DATA/JOG) dial to select '00.Initial Data' on the screen.
4) Press the yellow [ENTER] button.
Reference: Operation Guide, p. 203
Sep 09, 2012 | Yamaha Aw4416 Aw 4416 Workstation
How do i reset the yamaha aw4416
Sep 09, 2012 | Audio Players & Recorders
My EH40 is not supplying power to the water heater. I hooked the power line in to posts 1 and 2 and I hooked the load out to posts 4 and 6. When I use my power checker it reads no power to posts 3,4,5,...
I have an EH 40 sitting in front of me right now.
http://waterheatertimer.org/How-to-wire-EH40-hot-water-heater-timer.html
The link above shows correct 240V water heater timer wiring for EH40
Link below shows an overview picture of EH 40 connected to 240V water heater
http://waterheatertimer.org/images/EH40-water-heater-circuit-5.jpg
http://waterheatertimer.org/240-v-water-heater-circuit.html
EH40 has a 240V clock.
Terminals 1 and 2 send power to the 240V clock
Power to the clock terminals do not pass through timer to any other terminal
How to wire EH40 for 240V
240V line has 2 hot wires from breaker box.
Lets call these wires Hot1 and Hot2
These wire are interchangeable on 240V circuit
Hot1 connects to terminal 1 with a jumper to terminal 3 (or connect to 3 and jumper to 1)
Hot2 connects to terminal 2 with a jumper to terminal 5 (or connect to 5 and jumper to 2)
240V circuit has 2 wires going to the Load
Let's call these Load1 and Load2
These wires are interchangeable on 240V circuit
Load1 connects to terminal 4
Load2 connects to terminal 6
If the timer is still not working, go back to the breaker and test if it is delivering 240V to the circuit.
If breaker is bad on one leg, then the circuit can test with live power, but the 240V appliance will not work.
240V circuit requires both legs of 240V before circuit is complete.
Oct 24, 2010 | Intermatic EH40 - Electronic Water Heater...
240V supplied when 115 selected
these laptops come with international adapters you need not change anything ,just plug it.
Jul 07, 2010 | Dell - PS-5141-2D (PS51412D) Power Supply
Replacing power supply main
your best bet is to check owneres manual and keep with what they suggest however when ordering you may want to ask for tech support to see what they say but i would stick with what you had especially if it worked great that way you dont want to overpower your tv if that is what it was used to ..if it ain't broke don't fix it i hope that helps
May 14, 2009 | Philips 42FD9932 42 in. Plasma Television
No power
make sure the power cord is plugged into a working outlet, and make sure the other end of the power cord is firmly seated in the power supply. also look at the side of the plug, there should be a slide switch label (112V, 240V), make sure the slide switch display 112V. (if you are in USA). otherwise 240V.
if this help you solved the problem. please rate the answer.
thank you
Oct 15, 2008 | E-Machines Computers & Internet
110v - 240v
Well it may be compatible but it should hav a switch on the rear side to choose either 110 or 240V.Check for this but you probably burned primary side of main transformator and you'll have to replace it or to find somebody who is able to fix it
Feb 19, 2008 | Nakamichi SoundSpace 5 Shelf System
Computers & Internet Logo
David Payne
David Payne
