Oki mc362- accounting log buffer is near full
Hi, I have problem with my oki MC362, device is showing accounting log buffer is near full. Please help me clear accounting logs. Thank you
SOURCE: Clearing buffer
Press the SEL or ONLINE key, then turn the printer off. Clear the print queue in the PC and then turn the printer on again.
Posted on May 05, 2008
  • 97 Answers
SOURCE: OKI C7300 Printer
moz-screenshot-1.jpg Unfortunately it's a Hardware problem.
If you bought it from a dealer, contact them.
Error 020
When an error has occurred in the controller board (CU) or the program Rom.
Resolution:
Replace the Rom Dimm, see chart below for the correct part number. If the Rom Dimm does not correct the issue, then replace the (CU) controller board. Please refer to the service manual for (CU) part number depending on the printer revision
Posted on Dec 07, 2008
  • 97 Answers
SOURCE: toner sensor error on an Oki C3520 Laser
Check the little switch/door on the right hand side of the drums.
This has worked successfully for me.
Symptom:
After replacement of a C3530 Image Drum, the message, "Toner Sensor Error" is displayed.
0.10a?openelement&fieldelemformat=gif
Cause:
The plastic shutter in the ID is fully or partially covering the toner sensor window.
Resolution:
Move the cover upward to allow for the sensor to become fully exposed prior to reinstalling the drum.
0.106?openelement&fieldelemformat=gif
SOURCE: fatal error 980 OKI C5500 printer
I had a paper jam and removed the jammed papers. The paper jam cleared and then the Fatal Error 980 appeared. OKI C5500 printer
Posted on Feb 25, 2010
SOURCE: OKI C8600 Printer Toner Sensor Reset
I've had two toners that have done this, they register as used as soon as you turn the dial to open the toner compartment. So if they don't work properly, as soon as you remove them.. you can no longer use them. (they empty contents into the drum).
I got in contact with my supplier and sent them back as faulty cartridges.
Posted on Jul 06, 2010
5650c not scanned. making paper jam. rollers replaced. making big noise.document page stop halfway through
PDF]fi-5650C Image Scanner Operator's Guide P3PC ... - Fujitsu
www.fujitsu.com/downloads/.../scanners/.../fi-5650c_ops-guide.pd...
FujitsuThank you for purchasing the fi-5650C fi-5650C duplex color scanner product. ... 6.1 Removing jammed documents ..... store where you purchased the scanner or an authorized FUJITSU Image Scanner service provider to make repairs to this .... It is adjusted to the width of the paper in order not to scanned skewed pages. 5.
Okidata User's Guide OKIFAX 5650 Error Messagesmy.okidata.com/man-OF5650.../006B738F6240C3BF8525678500678C...Make sure a new drum is available, and replace the drum ... to be faxed or scanned hasjammed in the scanner. Refer to the "Problem Solving, Clearing aTroubleshooting - Oki Printing Solutions in New Zealandwww.oki.co.nz/support/printer/.../index.aspxOki Electric Industry... MB491 ES4191. FAQ: Paper Jam Clearing MB451 MB471 MB491 ES4191 ...MC361 MC362 MC561 MC562 How to setup scan to email. Open the attached ..... Can I disable Colour Copying and make only B+W Copying available? No, it not possible to disable Color Mode when copying via the Scanner Operator Panel.
Jan 29, 2016 | Office Equipment & Supplies
Oki c5150 log buffer full job rejected
This problem exist because of Job Accounting has been initiated on the printer. Just had this problem myself. Okidata was unable to help me solve, but through numerous online searches I was able to work it out. First you have to download Storage Device Manager from Oki. It is under the Utilities heading on the left of the drivers download screen. At first I couldn't find it under my printer C5200n, so I continued to the next model just after mine and found it there under C5300 and fortunately it worked. What this will do is it will clear the flash memory in the printer. Only use this if the log data is of no use, which in my situation was the case. It is easy and only takes a few seconds and now everything is back up and printing. READ the instructions first before installing.
Apr 19, 2012 | Office Equipment & Supplies
CANT STOP OKI 591 PRINTER TO STOP PRINTING REPORT
Check that the LINE FEED button is not jamming or on.
The LINE FEED + POWER ON will print the "Printer Character Report" or "Test Page".
May 24, 2010 | Okidata 591 Printer
I NEED TO INSTAL OKI B2540 MFP PRINTER ON MY
You can go here
http://www.oki.co.uk/support/printer-drivers/index.aspx
May 18, 2010 | OKI B2540 MFP Printer
I have a Oki C9500 laser, the magenta print is streaky
I have the same problem with my OKI c3100, please help
Jan 13, 2010 | OKI C9500dxn Led Printer
Unable to work on oki c5500n on dell x64
If you are using this printer w/ two different versions on it or if it is on a network you must install both drivers. Your printer has its own web id if it is hooked up to a network. You can go into devices on network, right click on the printer and go to device web page. The problem is you had it working w/ a more advance version and now you are reverting operating systems.
Feb 06, 2009 | OKI C5500n Printer
OKI DATA MICROLINE 320 TURBO PRINTER PROBLEM
Hi Charles,
Use the IBM proprinter driver for this printer and select IBM in the menu of the printer.
Hope this helps.
Dezzi
Sep 10, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Clearing buffer
May 05, 2008 | OKI MICROLINE 321 Elite Matrix Printer
508 people viewed this question
jasbo
jasbo
