I have a lcd 40 inch tv. Model no. M40/57G-GB-FTCU-UK. How do I get all the text meant to be visible on the screen and not have part of it cut off?
  • 579 Answers
SOURCE: 40 inch lcd blue line vertical
The display screen is made of a matrix of elements connected to cables along the side and top. On your unit, some of these many, tiny connections are making contact intermittantly thus losing the elements in that area. These contacts are held in place with just pressure and if that is disturbed, you lose that line of elements. Try squeezing the cabinet of the TV on the outside at the top in the area of the loss and see if that makes a difference. May have to go inside and see if the contact assembly is disturbed or warped or something.
Hope ya fix it!
Posted on Jan 06, 2008
  • 84 Answers
SOURCE: hdtv lcd 40 in. broken screen face
You can have them repaired using a TV Repair guy but often it costs as much as a brand new tv. My daughter broke my $1,600 LCD. It would have cost $1,200 to fix.. so I just bought a new one.After that I picked up a TV screen protector called TV Armor http://www.tv-armor.com Its designed to protect the TV from damage. Now I dont have to worry anymore when she is playing near it. It works really well.
Eric
Posted on May 04, 2008
xCAUSALITYx
  • 210 Answers
SOURCE: My SOny Bravia 40 inch LCD TV has a vertical line
It could be 1 of 4 things:
1. One of the ribbon cables has worked itself loose (Simple Fix)
2. One of the assembly boards maybe faulty
3. The driver board which feeds the panel maybe faulty
4. The panel is faulty
The driver board in the UK costs approx £70 and approx £35-70 to fit it if this is the fault.
All other parts are between £80-160 and approx £35-70 to fit it if this is the fault.
The panel will cost approx 50-75% of what the TV was worth when you bought it - "Repair versus Replacement"
Thanks
Posted on Oct 01, 2009
dave1645
  • 834 Answers
SOURCE: my 32 inch westinghouse lcd tv's screen turned pink when on
your T-con board is failing you need a tech to replace it about a 150 dollar job
Posted on Nov 18, 2009
SOURCE: 3 year old Samsung 40 inch LCD TV will not turn on
The problem is 4 capacitors on the power supply board. Just had mine done under warranty. They (Sears) replaced the whole power board but you can get larger capacitors and just replace those for alot cheaper if not under warranty.
Posted on Jan 30, 2010
How do I fix my e- motion 39 l.c.d. tv
press "AV" & find out the current input/source is set.
Oct 09, 2015 | Televison & Video
CAN I GET NETFLIX ON MY FREEVIEW TV.
If the has an spare HDMI port, you could purchase a Google Chrome Cast. Use it with your WIFI and a Android device to access Netflix.
May 22, 2014 | Televison & Video
TV UMC SCAN
Please provide more details. What do you want to know? Gopakumar Gopalan Google
May 12, 2014 | LG 42LC2D 42 in. LCD HDTV
46/188g-gb-5b-ftcu-uk umc tv just keeps saying scanning it goes from 0% to 100% then starts all over again ???? also it is upside down ????? any help would be great
It sounds that the main system memory IC to this set is faulty. Check and replace it. It is a very small IC, having 8 solder terminals, can be located very near to main system control IC. Contact any service technician. If you wish to get some details, check the site linked here.Pull up older posts.
Dec 09, 2013 | LG 42LC2D 42 in. LCD HDTV
39" LED TV MODEL NO: 39/210G-GB-58-FTCU- UK SERIAL NO: UW39D210BFTCUG528-108239 01835
What is the problem you faces with this TV? Provide more details please. If you wish to get some details, check this link. http://electronicshelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Oct 03, 2013 | Televison & Video
Stuck on scan
It may be that the power cut was the result of a power surge. It may be that the outage has caused damage to the components of
your tv.If it does not return to normal you will need to get a very GOOD technician to diagnose the fault. It may be that the tv can be repaired, it may not ...but eirher way I would think about seeing whether the power company is liable for the damage.
The fault is almost certainly something that needs to be checked out by a pro
Aug 20, 2013 | Televison & Video
My line down the middle is not visible however the two sides are different
U should send the TV back to the store of purchase if you still have warranty.
Usually after 5 years this problem sometime occurs on plasma TV's. I'm not sure about the LCD screens.
Jul 21, 2013 | Sansui HDLCD4050 40-Inch 1080p LCD TV
New samsung 40 inch LCD. When in the wide mode
if you are watching cable or satelite, you need to change the screen format output from the source to make sure it matches with the TV
Jun 14, 2009 | Samsung LN40A550 LCD TV
Televison & Video Logo
61 people viewed this question
Top Televison & Video Experts
