I am replaced a dual core motherboard, when i booting key board not woriking. how i solve it?
    New Friend:
Motherboard Intel d865gkt of biosupdate
Posted on Jul 09, 2013
ctf1800
  • 4402 Answers
SOURCE: MoBo Replacement
did you go into the new bios and check to make sure you have the hard drive setting on auto, then check your boot order that the drive is first to boot., if that doesnt work create a floppy boot disk (google it) and see if you see the hard drive when you do that.
Posted on Feb 15, 2008
worldvet
  • 859 Answers
SOURCE: Asus p5w DH Deluxe: updated to new bios 2704 now only black screen on boot up
brophylad,You sound like you know your way around a PC so please do not be offended by the suggestions below that you may already be aware of to begin with.
Use the PC your are using to communicate with us and download the older bios and create a bootable floppy or CD, Nero's bootable image is best as it recognizes NT partitions, and try flashing with the old bios. Otherwise, when I've had a board on the bench with this issue I've had to get a replacement bios chip which is rather easy to replace or Asus has replaced the board for me under warranty or for a rather fair price to replace with a refurbished board.
Anyway, try this again: remove the button battery and turn off the rocker switch on your Power Supply and remove the power cable. Leave all this disconnected for several minutes. Re-insert the battery, reattach the power cable and turn the rocker switch back on and attempt a bootup. If this fails to get you to a bios setup screen the CMOS chip has failed, permanently or is glitched, with the later being my guess.
Phone Asus at 502-995-9883 and have the serial number for your board, located on the inside of the case on top of the parallel port socket. I've phoned them many times over the years and they are quick. They'll most likely will give you a post bypass keyboard sequence if there is one for your model or give you a RMA immediately. I've never found Asus slow to replace a board from the RMA department.
The above phone number is for tower boards, for notebooks (they make great notebooks and sell white boxes as notebooks) call 510-739-3777 x5110.
Best Regards and good luck,
Worldvet
Posted on May 22, 2008
  • 50 Answers
SOURCE: Asrock ALiveNF6G-VSTA Motherboard. Unable to boot to OS
first disconnect ALL cables except power suppliy and frond panel switch. Startup and see if goes further.
dont forget to disconnect the front panel usb cables also !!!
if it goes better, connect he keyboard, reboot and enter bios to see.
etc etc
if it still hungs up at the start with all cables disconnected then a major chip on your motherboard is burnt (maybe the disk controller).
sorry i dont think a solution oher than buying a new motherboard.
Posted on Oct 10, 2009
  • 91 Answers
SOURCE: I am using Asus M2N68-AM Plus motherboard and AMD
dude check out if any part is overheating using speedfan software
if not check if your PSU can take the load of your PCparts
Posted on Feb 01, 2010
  • 11800 Answers
SOURCE: motherboard biostar p4m890 m7 can'toverclock intel dual core 2140
Because this is a very basic motherboard, with a very simple chipset without extra capabilities, let alone performance ones like overclocking.
Posted on Jun 01, 2010
Hi, am ganesh functions keys
If those are the only keys on the key board that are not responding, I would try to
1. boot in safe mode and check response. If you have other keys on the laptop that are not working,
2. I would boot operating system from a flash drive and check
and if both still are not working for you
3.try an external key board
Last replace the key board
Hope this helps
Sep 05, 2013 | Gateway NE56R Dual Core 2.10GHz 4GB 320GB...
Can i put dual core processors in my intel se7505vb2 motherboard?
http://www.intel.com/support/motherboards/server/se7505vb2/sb/cs-007399.htm
Page 16 of the Technical Product Specification guide;
3.1.1 Processor Support
"The Intel Server Board SE7505VB2 supports one or two processors in the 604-pin FCPGA package."
-> Socket 604,
http://en.wikipedia.org/wiki/Socket_604
-> Intel XEON processors ONLY
"When two processors are installed, all Processors MUST be of identical revision, core voltage, and bus/core speed."
-> Means you really should use two IDENTICAL processors.
"When only one Processor is installed, it should be in the socket labeled CPU1, and the other socket must be empty."
-> Self-explanatory.
That's the processor socket furthest away from the black AGP graphics expansion slot, and closest to the outside edge of the motherboard.
(Page 104, and 105)
ONLY supports Intel Xeon processors with a 400MHz, or 533MHz FSB.
Dual-Core Xeon's start at 667MHz, and wouldn't work anyway; due to different Core architecture, and Instruction Sets.
667MHz, 800MHz, 1066MHz, and 1333MHz, for dual core Xeon's,
http://en.wikipedia.org/wiki/List_of_Intel_Xeon_microprocessors#Xeon_.28UP.2FDP.29.2C_Dual_Core_2
(Scroll down just a touch, to get the Wikipedia 'banner' out of the way, or click on it's X)
Scroll down the page, look at the charts. Starts with 800MHz FSB for Dual Core, then goes 667MHz, 800MHz, 1066MHz, and 1333MHz, Front Side Bus.
Use Dual Core processors?
No.
Two Single-Core processors.
Product Guide for the Intel Server Board SE7505VB2,
(Motherboard manual),
http://download.intel.com/support/motherboards/server/se7505vb2/prod_guide.pdf
The above is a direct link to the PDF file, motherboard manual.
If it doesn't work just by clicking on it, then copy it; and paste it in your browser address bar. Press the Enter key.
(This is a PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the above link, or press the Enter key; it may take up to 30 seconds before the first page comes up.
Didn't want you to wait a few seconds, and think nothing is happening)
For additional questions please post in a Comment.
Regards,
joecoolvette
Nov 29, 2012 | Computers & Internet
My computer works normaly with an single core athlon 3200+ but when I use an Athlon 4400+ or 4000+ dual core, it just wont boot. The fans are running and lights are on but there is no signal on the monitor...
take a look at the motherboard manufacturers website and see if your motherboard will accept a 4400. You may need to update the bios on your board to accept the faster processor. You need to be careful if you flash the bios. do it wrong and you can write the board off.
Good luck
Aug 11, 2011 | Asrock ALiveNF6G-VSTA (MB-ALVNF6G)...
My DG41TX works perfectly with dual core processors, but with core 2 duo not, do 3 beeps and dont show any video, what i must do?? my core 2 duo is E8400 my dual core is E2180 Bios Version:...
The POST beep code - 3 short beeps mean RAM failure.
Try reseating the RAM modules.
If this does not solve your problem then remove all the RAM modules and insert one RAM module at a time into memory slot 0 (1st memory slot) to determine which is the faulty RAM module.
Jul 07, 2011 | Intel DG41TX Motherboard
My intel core 2 duo wont work on the motherboard
maybe incompatible or possibly your board is faulty or your processor is faulty if one is new don't think its not faulty iv had faulty components that cost me a couple of hundred that have just came out of the box so try another processor and if it works its your core duo so replace it if not its your board but first try doing a bios update this an usually solve a few problems if not replace you faulty component hope this has been of help
May 19, 2010 | ASUS motherboard P5S-MX SE LGA775 SiS671FX...
Machine is not booting
  • I know what is your problem?May be problem on your HDD you change it then solve your problem.If you are not fix,You need Fox con MX PK g31 chip mother board.It is very adjustable motherboard for pin less p4 HT processor.
Mar 19, 2010 | Intel D946GZIS Motherboard
Question about compatible cpu and motherboard
The processor will work on a dual core mb. Most DC boards are design to support both solo and dual core proccessors. Once installed, the board will adjust speed and FSB to the specs of the processor. (As long as the processor is within operating range of the board you use.
Aug 12, 2009 | Computers & Internet
Intel Dual Core 2.0 GHz Sytem hangs after boot
During your boot screen press the F8 key to boot into safe mode. If that gets you to the desktop run virus/spyware scans. Reply with any results.
Jan 12, 2009 | Bravo Intel Dual Core E2180-2.0GHz 2GB RAM...
Dual boot problem
first install win98(dont re boot for xp installtion),  while running 98, insert cd of xp and install xp from there.
Nov 18, 2008 | Biostar P4M80-M4 Motherboard
Computers & Internet Logo
16 people viewed this question
David Payne
David Payne
